1 Flash-Turtle Китай Весь мир | |
Thermostat Programmable Active High, Active Low Open Drain, Push-Pull ... Далее MCP9510HT-E/CHThermostat Programmable Active High, Active Low Open Drain, Push-Pull SOT-23-6 | запрос 7 дней склад 37766 шт |
High-Side or Low-Side Gate Driver IC Inverting SOT-23-6 | запрос 7 дней склад 42614 шт |
RC EMI Filter 1st Order Low Pass 1 Channel R = 47Ohms, C = 0.1μF ... Далее SNUB0000RC EMI Filter 1st Order Low Pass 1 Channel R = 47Ohms, C = 0.1μF Radial | запрос 7 дней склад 23524 шт |
2 Akcel Китай Весь мир | |
LED Light Pipes ORCAdapt Flexible Light Pipe System, 2mm. Fiber Optic ... Далее OR3-6.0-RED-F6PZ67PR-5LED Light Pipes ORCAdapt Flexible Light Pipe System, 2mm. Fiber Optic Core, 6.0mm. Low Profile Fresnel Lens, 6.0in. Length, Rectangular Red ... | запрос от 1 шт |
4CH LOW PWR HIGH SPD DGTL ISO | запрос от 1 шт |
LED Light Pipes Flexible Light Pipe Assembly, 2mm. Fiber Optic Core, ... Далее FV2-6.0-SRG-F6PD67PR-2LED Light Pipes Flexible Light Pipe Assembly, 2mm. Fiber Optic Core, Vertical, 6.0mm. IP67 Round Low Profile Diffused Lens, 6.0in. Length ... | запрос от 1 шт |
Еще 191 строка | |
LED Light Pipes Light Pipe, Flexible, 1mm. Fiber Optic Core, 7.0mm. ... Далее LC1-33.0-F7P-2LED Light Pipes Light Pipe, Flexible, 1mm. Fiber Optic Core, 7.0mm. Dia. Low Profile Lens, 33.0in. Length, Red | запрос от 1 шт |
LED Light Pipes ORCAdapt Flexible Light Pipe System, 2mm. Fiber Optic ... Далее OR4-2.75-RGB-F7P-5LED Light Pipes ORCAdapt Flexible Light Pipe System, 2mm. Fiber Optic Core, 7.0mm. Dia. Low Profile Lens, 2.75in. Length, Tri-Color ... | запрос от 1 шт |
LED Light Pipes Flexible Light Pipe Assembly, 2mm. Fiber Optic Core, ... Далее FV4-6.0-UR-F9PZ67PR-6LED Light Pipes Flexible Light Pipe Assembly, 2mm. Fiber Optic Core, Vertical, 9.0mm. IP67 Round Low Profile Fresnel Lens, 6.0in. Length ... | запрос от 1 шт |
LED Light Pipes Flexible Light Pipe Assembly, 2mm. Fiber Optic Core, ... Далее FV2-6.0-UB-F6PD67PR-2LED Light Pipes Flexible Light Pipe Assembly, 2mm. Fiber Optic Core, Vertical, 6.0mm. IP67 Round Low Profile Diffused Lens, 6.0in. Length ... | запрос от 1 шт |
LED Light Pipes Flexible Light Pipe Assembly, 2mm. Fiber Optic Core, ... Далее FV3-6.0-UB-F6PZ67PR-2LED Light Pipes Flexible Light Pipe Assembly, 2mm. Fiber Optic Core, Vertical, 6.0mm. IP67 Round Low Profile Fresnel Lens, 6.0in. Length Red ... | запрос от 1 шт |
LED Light Pipes Flexible Light Pipe Assembly, Vertical SMD Adapter, ... Далее SF4-3.5-F5P-2LED Light Pipes Flexible Light Pipe Assembly, Vertical SMD Adapter, 2mm. Fiber Optic Core, 5.1mm, Dia. Low Profile Lens, 3.5 in. Red | запрос от 1 шт |
LED Light Pipes Flexible Light Pipe Assembly, Vertical SMD Adapter, ... Далее SF4-3.0-F5P-2LED Light Pipes Flexible Light Pipe Assembly, Vertical SMD Adapter, 2mm. Fiber Optic Core, 5.1mm, Dia. Low Profile Lens, 3.0 in. Red | запрос от 1 шт |
LED Light Pipes Flexible Light Pipe Assembly, 1mm. Fiber Optic Core, ... Далее FV1-6.0-UR-F7P-4LED Light Pipes Flexible Light Pipe Assembly, 1mm. Fiber Optic Core, Vertical, 7mm. Low Profile Dia. Lens, 6.0in. Length Yellow, 3mm LED, ... | запрос от 1 шт |
LED Light Pipes Flexible Light Pipe Assembly, 2mm. Fiber Optic Core, ... Далее FR2-6.0-UR-F6PD67PR-5LED Light Pipes Flexible Light Pipe Assembly, 2mm. Fiber Optic Core, Vertical, 6.0mm. IP67 Round Low Profile Diffused Lens, 6.0in. Length ... | запрос от 1 шт |
LED Light Pipes Flexible Light Pipe Assembly, 2mm. Fiber Optic Core, ... Далее FR3-6.0-UR-F6PD67PR-4LED Light Pipes Flexible Light Pipe Assembly, 2mm. Fiber Optic Core, Vertical, 6.0mm. IP67 Round Low Profile Diffused Lens, 6.0in. Length ... | запрос от 1 шт |
LED Light Pipes Flexible Light Pipe Assembly, 1mm. Fiber Optic Core, ... Далее FR1-12.0-UG-F7P-2LED Light Pipes Flexible Light Pipe Assembly, 1mm. Fiber Optic Core, Vertical, 7mm. Low Profile Dia. Lens, 12.0in. Length Red, 3mm LED, ... | запрос от 1 шт |
LED Light Pipes Flexible Light Pipe Assembly, 2mm. Fiber Optic Core, ... Далее FR3-6.0-UR-F6PD67PR-9LED Light Pipes Flexible Light Pipe Assembly, 2mm. Fiber Optic Core, Vertical, 6.0mm. IP67 Round Low Profile Diffused Lens, 6.0in. Length ... | запрос от 1 шт |
LED Light Pipes ORCAdapt Flexible Light Pipe System, 1mm. Fiber Optic ... Далее OR1-24.0-RG-F4P-9LED Light Pipes ORCAdapt Flexible Light Pipe System, 1mm. Fiber Optic Core, 4.2mm. Dia. Low Profile Lens, 24.0in. Length, Bi-Color ... | запрос от 1 шт |
LED Light Pipes Flexible Light Pipe Assembly, Vertical SMD Adapter, ... Далее SF1-9.25-F4P-2LED Light Pipes Flexible Light Pipe Assembly, Vertical SMD Adapter, 1mm. Fiber Optic Core, 4.2mm. Dia. Low Profile Lens, 9.25in. Length, Red | запрос от 1 шт |
Test Jack, Low Profile, Horizontal, Silver, PC Mount, .460 OD, Body ... Далее 6067Test Jack, Low Profile, Horizontal, Silver, PC Mount, .460 OD, Body Red Nylon | запрос от 1 шт |
LOW CAP ESD HIGH SPEED 4-CH 3.3V | запрос от 1 шт |
Logic Gates Automotive 4-ch, 2-input, 2-V to 6-V low power AND gates ... Далее SN74HCS08QDYYRQ1Logic Gates Automotive 4-ch, 2-input, 2-V to 6-V low power AND gates with Schmitt-Trigger inputs | 51.4 ₽ от 1 шт 5-7 дней склад 2730 шт |
Еще 3 цен: … 43.2 ₽ | |
48.5 ₽ от 10 шт 5-7 дней склад 2730 шт | |
45.8 ₽ от 100 шт 5-7 дней склад 2730 шт | |
43.2 ₽ от 1000 шт 5-7 дней склад 2730 шт | |
3 ЭК ЗИП Москва Россия | |
Электронные модули (arduino) | 567 ₽ от 1 шт 4-5 недель |
Еще 2 цен: … 371 ₽ | |
391 ₽ от 3 шт 4-5 недель | |
371 ₽ от 26 шт 4-5 недель | |
Электронные модули (arduino) | запрос |
Электронные модули (arduino) | 1 384 ₽ от 1 шт 4-5 недель |
Еще 2 цен: … 907 ₽ | |
955 ₽ от 2 шт 4-5 недель | |
907 ₽ от 11 шт 4-5 недель | |
Еще 2 строки | |
4 Utmel Китай Весь мир | |
Analog to Digital Converters - ADC IC 24-Bit 1-ch Low Noise ADC | 786 ₽ от 1 шт 5-7 дней склад 294 шт |
Еще 3 цен: … 660 ₽ | |
741 ₽ от 10 шт 5-7 дней склад 294 шт | |
699 ₽ от 100 шт 5-7 дней склад 294 шт | |
660 ₽ от 1000 шт 5-7 дней склад 294 шт | |
ANALOG DEVICES ADG804YRMZ IC, MUX 4CH LOW VOLT, MSOP10 | 389 ₽ от 1 шт 5-7 дней склад 10 шт |
Еще 3 цен: … 326 ₽ | |
367 ₽ от 10 шт 5-7 дней склад 10 шт | |
346 ₽ от 100 шт 5-7 дней склад 10 шт | |
326 ₽ от 1000 шт 5-7 дней склад 10 шт | |
ANALOG DEVICES ADG708BRUZMUX 8CH LOW VOLT, SMD, TSSOP16, 708 | 386 ₽ от 1 шт 5-7 дней склад 17 шт |
Еще 3 цен: … 324 ₽ | |
364 ₽ от 10 шт 5-7 дней склад 17 шт | |
343 ₽ от 100 шт 5-7 дней склад 17 шт | |
324 ₽ от 1000 шт 5-7 дней склад 17 шт | |
Еще 110 строк | |
Hook-up Wire 28AWG LOW STRP FORCE 100 SPOOL RED | 3 492 ₽ от 1 шт 5-7 дней склад 7 шт |
Еще 3 цен: … 2 932 ₽ | |
3 294 ₽ от 10 шт 5-7 дней склад 7 шт | |
3 108 ₽ от 100 шт 5-7 дней склад 7 шт | |
2 932 ₽ от 1000 шт 5-7 дней склад 7 шт | |
Hook-up Wire 24AWG LOW STRP FORCE 100 SPOOL RED | 3 489 ₽ от 1 шт 5-7 дней склад 14 шт |
Еще 3 цен: … 2 929 ₽ | |
3 292 ₽ от 10 шт 5-7 дней склад 14 шт | |
3 105 ₽ от 100 шт 5-7 дней склад 14 шт | |
2 929 ₽ от 1000 шт 5-7 дней склад 14 шт | |
LED 3MM RT ANG LOW CUR RED PCMNT | 144 ₽ от 1 шт 5-7 дней склад 965 шт |
Еще 3 цен: … 121 ₽ | |
136 ₽ от 10 шт 5-7 дней склад 965 шт | |
128 ₽ от 100 шт 5-7 дней склад 965 шт | |
121 ₽ от 1000 шт 5-7 дней склад 965 шт | |
LED 3MM LOW CURR RED | 144 ₽ от 1 шт 5-7 дней склад 7467 шт |
136 ₽ от 10 шт 5-7 дней склад 7467 шт | |
128 ₽ от 100 шт 5-7 дней склад 7467 шт | |
121 ₽ от 1000 шт 5-7 дней склад 7467 шт | |
LED 5MM VERT LOW CUR RED PC MNT | 125 ₽ от 1 шт 5-7 дней склад 295 шт |
Еще 3 цен: … 105 ₽ | |
118 ₽ от 10 шт 5-7 дней склад 295 шт | |
112 ₽ от 100 шт 5-7 дней склад 295 шт | |
105 ₽ от 1000 шт 5-7 дней склад 295 шт | |
LED 3MM LOW CURR RED | 235 ₽ от 1 шт 5-7 дней склад 620 шт |
Еще 3 цен: … 197 ₽ | |
222 ₽ от 10 шт 5-7 дней склад 620 шт | |
209 ₽ от 100 шт 5-7 дней склад 620 шт | |
197 ₽ от 1000 шт 5-7 дней склад 620 шт | |
LED 3HI 3MM LOW CUR RED PC MNT | 356 ₽ от 1 шт 5-7 дней склад 406 шт |
Еще 3 цен: … 299 ₽ | |
335 ₽ от 10 шт 5-7 дней склад 406 шт | |
317 ₽ от 100 шт 5-7 дней склад 406 шт | |
299 ₽ от 1000 шт 5-7 дней склад 406 шт | |
LED 2HI 3MM LOW CUR RED PC MNT | 235 ₽ от 1 шт 5-7 дней склад 640 шт |
222 ₽ от 10 шт 5-7 дней склад 640 шт | |
209 ₽ от 100 шт 5-7 дней склад 640 шт | |
197 ₽ от 1000 шт 5-7 дней склад 640 шт | |
Gate Drivers IPS Dual Ch Low Side Driver | 146 ₽ от 1 шт 5-7 дней склад 26486 шт |
Еще 3 цен: … 122 ₽ | |
137 ₽ от 10 шт 5-7 дней склад 26486 шт | |
129 ₽ от 100 шт 5-7 дней склад 26486 шт | |
122 ₽ от 1000 шт 5-7 дней склад 26486 шт | |
INFINEON AUIRS4427STR MOSFET, DUAL CH, LOW SIDE DRIVER, SO8 | 190 ₽ от 1 шт 5-7 дней склад 8619 шт |
Еще 3 цен: … 159 ₽ | |
179 ₽ от 10 шт 5-7 дней склад 8619 шт | |
169 ₽ от 100 шт 5-7 дней склад 8619 шт | |
159 ₽ от 1000 шт 5-7 дней склад 8619 шт | |
Analog to Digital Converters - ADC 2-Ch 24-Bit ADCs w/ Ultra Low Noise ... Далее CS5532-BSZAnalog to Digital Converters - ADC 2-Ch 24-Bit ADCs w/ Ultra Low Noise PGIA | 1 749 ₽ от 1 шт 5-7 дней склад 1794 шт |
Еще 3 цен: … 1 468 ₽ | |
1 650 ₽ от 10 шт 5-7 дней склад 1794 шт | |
1 556 ₽ от 100 шт 5-7 дней склад 1794 шт | |
1 468 ₽ от 1000 шт 5-7 дней склад 1794 шт | |
Special Purpose Amplifiers Ultra Low Pwr 18MHz SGL CH VGA | запрос от 1 шт 5-7 дней склад 8279 шт |
Analog to Digital Converters - ADC 2-Ch Low-Cost 24-Bit ADC | 594 ₽ от 1 шт 5-7 дней склад 1667 шт |
Еще 3 цен: … 499 ₽ | |
561 ₽ от 10 шт 5-7 дней склад 1667 шт | |
529 ₽ от 100 шт 5-7 дней склад 1667 шт | |
499 ₽ от 1000 шт 5-7 дней склад 1667 шт | |
Analog to Digital Converters - ADC 4-Ch 24-Bit ADCs w/ Ultra Low Noise ... Далее CS5534-BSZAnalog to Digital Converters - ADC 4-Ch 24-Bit ADCs w/ Ultra Low Noise PGIA | 1 718 ₽ от 1 шт 5-7 дней склад 11144 шт |
Еще 3 цен: … 1 443 ₽ | |
1 621 ₽ от 10 шт 5-7 дней склад 11144 шт | |
1 529 ₽ от 100 шт 5-7 дней склад 11144 шт | |
1 443 ₽ от 1000 шт 5-7 дней склад 11144 шт | |
Analog to Digital Converters - ADC 4-Ch 16-Bit ADCs w/ Ultra Low Noise ... Далее CS5533-ASZAnalog to Digital Converters - ADC 4-Ch 16-Bit ADCs w/ Ultra Low Noise PGIA | 1 282 ₽ от 1 шт 5-7 дней склад 630 шт |
Еще 3 цен: … 1 076 ₽ | |
1 209 ₽ от 10 шт 5-7 дней склад 630 шт | |
1 141 ₽ от 100 шт 5-7 дней склад 630 шт | |
1 076 ₽ от 1000 шт 5-7 дней склад 630 шт | |
Analog to Digital Converters - ADC 2-Ch 16-Bit ADCs w/ Ultra Low Noise ... Далее CS5531-ASZAnalog to Digital Converters - ADC 2-Ch 16-Bit ADCs w/ Ultra Low Noise PGIA | запрос от 1 шт 5-7 дней склад 4601 шт |
Analog to Digital Converters - ADC 2-Ch 24-Bit ADCs w/ Ultra Low Noise ... Далее CS5532-ASZAnalog to Digital Converters - ADC 2-Ch 24-Bit ADCs w/ Ultra Low Noise PGIA | 1 448 ₽ от 1 шт 5-7 дней склад 11 шт |
Еще 3 цен: … 1 216 ₽ | |
1 366 ₽ от 10 шт 5-7 дней склад 11 шт | |
1 289 ₽ от 100 шт 5-7 дней склад 11 шт | |
1 216 ₽ от 1000 шт 5-7 дней склад 11 шт | |
5 DIP8.RU Москва Россия и страны ТС | |
LED; SMD; 2835,PLCC2; red; 8?13lm; 2.8x3.5x0.8mm; 120°; 1.8?2.5V | 16.0 ₽ от 10 шт 42 дня склад 4060 шт Внешний |
Еще 9 цен: … 4.07 ₽ | |
16.0 ₽ от 10 шт от 1 дня склад 31 шт Москва | |
7.21 ₽ от 50 шт 42 дня склад 4060 шт Внешний | |
7.21 ₽ от 50 шт от 1 дня склад 31 шт Москва | |
5.45 ₽ от 250 шт 42 дня склад 4060 шт Внешний | |
5.45 ₽ от 250 шт от 1 дня склад 31 шт Москва | |
4.49 ₽ от 1000 шт 42 дня склад 4060 шт Внешний | |
4.49 ₽ от 1000 шт от 1 дня склад 31 шт Москва | |
4.07 ₽ от 4000 шт 42 дня склад 4060 шт Внешний | |
4.07 ₽ от 4000 шт от 1 дня склад 31 шт Москва | |
IC: driver; low-side,MOSFET gate driver; MSOP8; -5?5A; Ch: 2; 5?20V | 190 ₽ от 1 шт 42 дня склад 20 шт Внешний |
Еще 9 цен: … 100 ₽ | |
190 ₽ от 1 шт от 1 дня склад 6 шт Москва | |
147 ₽ от 5 шт 42 дня склад 20 шт Внешний | |
147 ₽ от 5 шт от 1 дня склад 6 шт Москва | |
127 ₽ от 25 шт 42 дня склад 20 шт Внешний | |
127 ₽ от 25 шт от 1 дня склад 6 шт Москва | |
110 ₽ от 100 шт 42 дня склад 20 шт Внешний | |
110 ₽ от 100 шт от 1 дня склад 6 шт Москва | |
100 ₽ от 250 шт 42 дня склад 20 шт Внешний | |
100 ₽ от 250 шт от 1 дня склад 6 шт Москва | |
IC: driver; low-side,MOSFET gate driver; DFN8; -1.5?1.5A; Ch: 2 | 210 ₽ от 1 шт 42 дня склад 36 шт Внешний |
Еще 9 цен: … 97.9 ₽ | |
210 ₽ от 1 шт от 1 дня склад 1 шт Москва | |
145 ₽ от 5 шт 42 дня склад 36 шт Внешний | |
145 ₽ от 5 шт от 1 дня склад 1 шт Москва | |
122 ₽ от 25 шт 42 дня склад 36 шт Внешний | |
122 ₽ от 25 шт от 1 дня склад 1 шт Москва | |
110 ₽ от 100 шт 42 дня склад 36 шт Внешний | |
110 ₽ от 100 шт от 1 дня склад 1 шт Москва | |
97.9 ₽ от 500 шт 42 дня склад 36 шт Внешний | |
97.9 ₽ от 500 шт от 1 дня склад 1 шт Москва | |
Еще 8 строк | |
IC: driver; low-side,gate driver; TO220-5; -14?14A; Ch: 1; 4.5?35V | 920 ₽ от 1 шт 42 дня склад 1115 шт Внешний |
Еще 9 цен: … 590 ₽ | |
920 ₽ от 1 шт от 1 дня склад 2 шт Москва | |
792 ₽ от 3 шт 42 дня склад 1115 шт Внешний | |
792 ₽ от 3 шт от 1 дня склад 2 шт Москва | |
698 ₽ от 10 шт 42 дня склад 1115 шт Внешний | |
698 ₽ от 10 шт от 1 дня склад 2 шт Москва | |
628 ₽ от 50 шт 42 дня склад 1115 шт Внешний | |
628 ₽ от 50 шт от 1 дня склад 2 шт Москва | |
590 ₽ от 250 шт 42 дня склад 1115 шт Внешний | |
590 ₽ от 250 шт от 1 дня склад 2 шт Москва | |
IC: driver; low-side,gate driver; TO220-5; -30?30A; Ch: 1; 12.5?35V | 1 550 ₽ от 1 шт 42 дня склад 232 шт Внешний |
Еще 7 цен: … 1 036 ₽ | |
1 550 ₽ от 1 шт от 1 дня склад 1 шт Москва | |
1 342 ₽ от 3 шт 42 дня склад 232 шт Внешний | |
1 342 ₽ от 3 шт от 1 дня склад 1 шт Москва | |
1 142 ₽ от 10 шт от 1 дня склад 1 шт Москва | |
1 142 ₽ от 10 шт 42 дня склад 232 шт Внешний | |
1 036 ₽ от 50 шт 42 дня склад 232 шт Внешний | |
1 036 ₽ от 50 шт от 1 дня склад 1 шт Москва | |
IC: driver; low-side,gate driver; TO220-5; -30?30A; Ch: 1; 9?35V | 1 470 ₽ от 1 шт 42 дня склад 173 шт Внешний |
Еще 7 цен: … 1 072 ₽ | |
1 470 ₽ от 1 шт от 1 дня склад 1 шт Москва | |
1 295 ₽ от 3 шт 42 дня склад 173 шт Внешний | |
1 295 ₽ от 3 шт от 1 дня склад 1 шт Москва | |
1 144 ₽ от 10 шт от 1 дня склад 1 шт Москва | |
1 144 ₽ от 10 шт 42 дня склад 173 шт Внешний | |
1 072 ₽ от 50 шт 42 дня склад 173 шт Внешний | |
1 072 ₽ от 50 шт от 1 дня склад 1 шт Москва | |
IC: driver; low-side,gate driver; SO8-EP; -4?4A; Ch: 2; 4.5?35V | 530 ₽ от 1 шт 42 дня склад 911 шт Внешний |
Еще 7 цен: … 354 ₽ | |
530 ₽ от 1 шт от 1 дня склад 3 шт Москва | |
457 ₽ от 5 шт 42 дня склад 911 шт Внешний | |
457 ₽ от 5 шт от 1 дня склад 3 шт Москва | |
388 ₽ от 25 шт от 1 дня склад 3 шт Москва | |
388 ₽ от 25 шт 42 дня склад 911 шт Внешний | |
354 ₽ от 100 шт 42 дня склад 911 шт Внешний | |
354 ₽ от 100 шт от 1 дня склад 3 шт Москва | |
IC: driver; low-side,MOSFET gate driver; SO8; -5?3A; Ch: 2 | 320 ₽ от 1 шт 42 дня склад 61 шт Внешний |
Еще 9 цен: … 169 ₽ | |
320 ₽ от 1 шт от 1 дня склад 3 шт Москва | |
277 ₽ от 3 шт 42 дня склад 61 шт Внешний | |
277 ₽ от 3 шт от 1 дня склад 3 шт Москва | |
253 ₽ от 10 шт 42 дня склад 61 шт Внешний | |
253 ₽ от 10 шт от 1 дня склад 3 шт Москва | |
214 ₽ от 25 шт 42 дня склад 61 шт Внешний | |
214 ₽ от 25 шт от 1 дня склад 3 шт Москва | |
169 ₽ от 95 шт 42 дня склад 61 шт Внешний | |
169 ₽ от 95 шт от 1 дня склад 3 шт Москва | |
IC: driver; low-side,gate driver; SO8; -9?9A; Ch: 1; 4?15VDC | 320 ₽ от 1 шт 42 дня склад 755 шт Внешний |
Еще 9 цен: … 188 ₽ | |
320 ₽ от 1 шт от 1 дня склад 15 шт Москва | |
277 ₽ от 5 шт 42 дня склад 755 шт Внешний | |
277 ₽ от 5 шт от 1 дня склад 15 шт Москва | |
239 ₽ от 25 шт 42 дня склад 755 шт Внешний | |
239 ₽ от 25 шт от 1 дня склад 15 шт Москва | |
207 ₽ от 75 шт 42 дня склад 755 шт Внешний | |
207 ₽ от 75 шт от 1 дня склад 15 шт Москва | |
188 ₽ от 300 шт 42 дня склад 755 шт Внешний | |
188 ₽ от 300 шт от 1 дня склад 15 шт Москва | |
IC: driver; low-side,MOSFET gate driver; DFN8; -1.5?1.5A; Ch: 2 | 170 ₽ от 1 шт от 1 дня склад 50 шт Москва |
IC: power switch; low-side; 1.3A; Ch: 2; N-Channel; SMD; PG-DSO-8 | 130 ₽ от 1 шт склад 2255 шт Внешний |
Еще 7 цен: … 113 ₽ | |
130 ₽ от 1 шт от 1 дня склад 88 шт Москва | |
122 ₽ от 82 шт склад 2255 шт Внешний | |
122 ₽ от 82 шт от 1 дня склад 88 шт Москва | |
117 ₽ от 164 шт от 1 дня склад 88 шт Москва | |
117 ₽ от 164 шт склад 2255 шт Внешний | |
113 ₽ от 327 шт склад 2255 шт Внешний | |
113 ₽ от 327 шт от 1 дня склад 88 шт Москва | |
6 Энтеро Москва Россия, Белоруссия, Казахстан | |
CH-330M/RED без подлокотников красный Next-13 искусственная кожа крестовина металл Бюрократ 24 Апр 2024 02:05 Кресло Бюрократ CH-330M/RED без подлокотников красный Next-13 ... Далее CH-330M/RED без подлокотников красный Next-13 искусственная кожа крестовина металлКресло Бюрократ CH-330M/RED без подлокотников красный Next-13 искусственная кожа крестовина металл предназначен для использования на даче, ... | 6 690 ₽ Доставка: есть Локальная... Далее Доставка: есть Локальная доставка: 600 ₽ |
7 Триема Воронеж Россия Филиалы: Москва Белгород Курск Липецк Орел Тула | |
2200х16 (10х25) 105С LOW ESR MTCON конденсатор электролитический 2200х16 (10х25) 105С LOW ESR - 25 Апр 2024 04:18 2,993.83 | 3 919 ₽ Доставка: есть Самовывоз: есть на складе |
2200х16 (10х25) 105С LOW ESR Sapcon конденсатор электролитический 2200х16 (10х25) 105С LOW ESR - 25 Апр 2024 04:18 2,993.83 | 3 919 ₽ Доставка: есть Самовывоз: есть на складе |
Электронные модули (ARDUINO).Описание: Модуль твердотельных реле 4-х ... Далее 4-CH 5V Solid-state Relay (Red)Электронные модули (ARDUINO).Описание: Модуль твердотельных реле 4-х разрядный 4-CH 5VТип модуля: 4-CH 5V модуль твердотельного реле | 989 ₽ Доставка: есть Самовывоз: есть на складе |
Еще 12 строк | |
470х50 (10х25) 105С WL WL1H477M10025BB F = 5mm LOW ESR Samwha конденсатор электролитический WL1H477M10025BB - 25 Апр 2024 04:18 15,993.71 | 20 942 ₽ Доставка: есть Самовывоз: есть на складе |
Электронные модули (ARDUINO).Описание: Модуль твердотельных реле 2-х ... Далее 2-CH 5V Solid-state Relay (Red)Электронные модули (ARDUINO).Описание: Модуль твердотельных реле 2-х канальныйТип модуля: 2-CH 5V модуль твердотельного реле | 322 ₽ Доставка: есть Самовывоз: есть на складе |
49.0 ₽ Доставка: есть Самовывоз: есть на складе | |
219 ₽ Доставка: есть Самовывоз: есть на складе | |
Электронные модули (ARDUINO). | 167 ₽ Доставка: есть Самовывоз: есть на складе |
1 362 ₽ Доставка: есть Самовывоз: есть на складе | |
251 ₽ Доставка: есть Самовывоз: есть на складе | |
411 ₽ Доставка: есть Самовывоз: есть на складе | |
Features Red, Green, Blue (RGB), and Clear Light Sensing with IR ... Далее TCS34725FNFeatures Red, Green, Blue (RGB), and Clear Light Sensing with IR Blocking Filter Programmable Analog Gain and Integration Time 3,800,000:1 ... | 177 ₽ Доставка: есть Самовывоз: есть на складе |
Features Red, Green, Blue (RGB), and Clear Light Sensing with IR ... Далее TCS34725FNFeatures Red, Green, Blue (RGB), and Clear Light Sensing with IR Blocking Filter Programmable Analog Gain and Integration Time 3,800,000:1 ... | 230 ₽ Доставка: есть Самовывоз: есть на складе |
Features Red, Green, Blue (RGB), and Clear Light Sensing with IR ... Далее TCS34725FNFeatures Red, Green, Blue (RGB), and Clear Light Sensing with IR Blocking Filter Programmable Analog Gain and Integration Time 3,800,000:1 ... | 231 ₽ Доставка: есть Самовывоз: есть на складе |
Конфигурация High-Side/Low-Side, Тип канала независимый, Кол-во ... Далее IR2112Конфигурация High-Side/Low-Side, Тип канала независимый, Кол-во каналов 2, Тип управляемого затвора N-CH Напряжение питания, В 10…20, ... | 84.0 ₽ Доставка: есть Самовывоз: есть на складе |
8 МосЧип Москва Россия | |
SuperSOT?„? 80V NPN SILICON LOW SATURATION TRANSISTOR | запрос 7-14 дней |
Blade Terminal & Special Purpose Fuses - Low Voltage | запрос 7-14 дней |
Еще 106 строк | |
Low Power Ethernet Coaxial Transceiver | запрос 7-14 дней |
IC AFE 24BIT 2CH LOW PWR 32TQFP | запрос 7-14 дней |
IC SW IPS 1CH LOW SIDE DPAK | запрос 7-14 дней |
IC SW IPS 1CH LOW SIDE D2PAK | запрос 7-14 дней |
IC SW IPS 2CH LOW SIDE 8SOIC | запрос 7-14 дней |
IC SW IPS 1CH LOW SIDE SOT223 | запрос 7-14 дней |
Аналого-цифровые преобразователи (АЦП) 16-Bit 8/10-Ch Low Vtg Low Pwr | запрос 7-14 дней |
LED 2HI 5MM LOW CUR RED PC MNT | запрос 7-14 дней |
LED 5MM VERT LOW CUR RED PC MNT | запрос 7-14 дней |
LED 4HI 3MM LOW CUR RED PC MNT | запрос 7-14 дней |
LED GaP/GaP Hi-Eff Red Low current requirement. | запрос 7-14 дней |
LED AlGaInP/GaAs Super Red Low current requirement. | запрос 7-14 дней |
9 ЧипСити Москва Россия | |
Multi-Directional Switches Hat Press Fit Low-Level Red | 8 540 ₽ 3-7 дней склад 1030 шт |
Multi-Directional Switches Castle Threaded Low-Level Red | 14 059 ₽ 3-7 дней склад 878 шт |
4-Ch Low Capacitance TVS Diode Array | 27.8 ₽ 3-7 дней склад 10387 шт |
Еще 107 строк | |
Comparator 1CH Low Power CMOS DMP8 | 235 ₽ 3-7 дней склад 954 шт |
Op AMP 4CH Low Noise SSOP14 | 604 ₽ 3-7 дней склад 7891 шт |
Gate Drivers 1CH Low Side Switch 0.2A 0.75Ω 45V | 37.6 ₽ 3-7 дней склад 908 шт |
Gate Drivers 1CH Low Side Switch Wide Input 0.2A | 36.9 ₽ 3-7 дней склад 1039 шт |
Op AMP 4CH Low Noise DIP14 | 176 ₽ 3-7 дней склад 967 шт |
SP7121 Series 5.5V 20kHz 2CH Low Dropout High Side Linear LED Driver ... Далее SP7121EK-LSP7121 Series 5.5V 20kHz 2CH Low Dropout High Side Linear LED Driver SOT-23-6 | 70.8 ₽ 3-7 дней склад 886 шт |
Raised No Low Force 12V Red Red Bezel Red Button | 1 465 ₽ 3-7 дней склад 996 шт |
FLV-DL15060R 21 Апр 2024 02:14 Low Agl Ring 150mm 60deg Red | 155 665 ₽ 3-7 дней склад 1271 шт |
3Z4S-LT MLRL-CR48 21 Апр 2024 02:14 Low Angle Ring Light Red | 107 691 ₽ 3-7 дней склад 924 шт |
CCSA-QLA-074050-66 21 Апр 2024 02:14 Low Angle Ring-74mm Red | 95 251 ₽ 3-7 дней склад 1111 шт |
CCSA-QLA-208172-66 21 Апр 2024 02:14 Low Angle Ring-208mm Red | 279 531 ₽ 3-7 дней склад 1204 шт |
Screw/Low Ter, Red Rocker, Mom-On Off Mom-On | 1 210 ₽ 3-7 дней склад 1161 шт |
Illuminated Pushbutton Switches Stnls 12V Red LED Low profile Curved | 4 472 ₽ 3-7 дней склад 1199 шт |
Illuminated Pushbutton Switches Stnls 2V Red LED Low profile Flat | 4 192 ₽ 3-7 дней склад 1161 шт |
Flush Matte, Threaded Solder, n.o., Low Frc Snap, 2vred, Blk, Red | 1 465 ₽ 3-7 дней склад 1170 шт |
Illuminated Pushbutton Switches Stnls 12V Red LED Low profile Curved | 4 472 ₽ 3-7 дней склад 908 шт |
Led-Red t-3/4 Subminiature Low Profile Surface Mount, 3/Pkg | 145 ₽ 3-7 дней склад 1013 шт |
10 Acme Chip Китай Весь мир | |
IC GATE DVR 2CH LOW SIDE 8SOIC | запрос 7 дней склад 2245 шт |
IC AFE 24BIT 2CH LOW PWR 32TQFP | запрос 7 дней склад 2892 шт |
IC SW IPS 2CH LOW SIDE 8SOIC | запрос 7 дней склад 2170 шт |
Еще 74 строки | |
IC SWITCH IPS 1CH LOW SIDE DPAK | запрос 7 дней склад 1179 шт |
IC SW IPS 2CH LOW SIDE 8SOIC | запрос 7 дней склад 1877 шт |
Analog to Digital Converters - ADC 2-Ch Low-Cost 24-Bit ADC | запрос 7 дней склад 861 шт |
Gate Drivers 4A/4A Sgl Ch Hi-Spd Low-side Gate Driver | запрос 7 дней склад 1456 шт |
Analog to Digital Converters - ADC 2-Ch 24-Bit ADCs w/ Ultra Low Noise ... Далее CS5532-BSZAnalog to Digital Converters - ADC 2-Ch 24-Bit ADCs w/ Ultra Low Noise PGIA | запрос 7 дней склад 403 шт |
IC SW LOW SIDE 1CH 5A SOT-223 | запрос 7 дней склад 1563 шт |
IC GATE DVR LOW SIDE 1CH SOT23-5 | запрос 7 дней склад 1712 шт |
IC GATE DVR LOW SIDE 1CH SOT23-5 | запрос 7 дней склад 2506 шт |
IC GATE DVR LOW SIDE 1CH SOT23-6 | запрос 7 дней склад 2698 шт |
IC GATE DVR LOW SIDE 1CH 6SON | запрос 7 дней склад 1899 шт |
IC SW LOW SIDE 1CH 5A 8SOIC | запрос 7 дней склад 158 шт |
IC GATE DVR LOW SIDE 1CH SOT23-5 | запрос 7 дней склад 2886 шт |
IC GATE DVR LOW SIDE 1CH SOT23-5 | запрос 7 дней склад 1047 шт |
IC GATE DVR LOW SIDE 1CH SOT23-5 | запрос 7 дней склад 1259 шт |
IC GATE DVR LOW SIDE 1CH 6WSON | запрос 7 дней склад 2466 шт |
IC PWR SW USB 1CH 1.0A LOW 6DFN | запрос 7 дней склад 932 шт |
16 MHz Ultra-Low-Power Microcontroller With 2 KB FRAM, 1 KB SRAM, 12 ... Далее MSP430FR2110IPW16R16 MHz Ultra-Low-Power Microcontroller With 2 KB FRAM, 1 KB SRAM, 12 IO, 8 ch 10-bit ADC 16-TSSOP -40 to 85 | запрос 7 дней склад 1039 шт |
11 T-electron Раменское, Московская обл. Россия и страны СНГ | |
43.7 ₽ склад 395 шт | |
12 Элитан Ижевск Россия Безнал. расчет Филиалы: Москва Санкт-Петербург Екатеринбург Новосибирск | |
BF1012R MOSFET N-Ch 16V 25mA 0.2W 1GHz for low noise, high gain controlled input stages Infineon 26 Апр 2024 02:24 | 116 ₽ |
13 Онлайн Компоненты Москва Россия | |
MOSFET Driver, N-Ch, High Side and Low Side, 4.5V to 5.5V Supply, 4A, ... Далее HIP2105FRZMOSFET Driver, N-Ch, High Side and Low Side, 4.5V to 5.5V Supply, 4A, 20ns Delay, 4Ohm On, DFN-10 | 95.3 ₽ от 1 шт |
68.5 ₽ от 10 шт | |
LED, Low Power, Red, Water Clear Lens, Through Hole, T-1 3/4 (5mm), 20 ... Далее L-7113SRC-J4LED, Low Power, Red, Water Clear Lens, Through Hole, T-1 3/4 (5mm), 20 mA, 2.1 V, 640 nm | 107 ₽ от 5 шт 5-12 дней склад 3241 шт |
Еще 7 цен: … 75.4 ₽ | |
105 ₽ от 10 шт 5-12 дней склад 3241 шт | |
103 ₽ от 25 шт 5-12 дней склад 3241 шт | |
96.6 ₽ от 50 шт 5-12 дней склад 3241 шт | |
88.2 ₽ от 100 шт 5-12 дней склад 3241 шт | |
82.7 ₽ от 150 шт 5-12 дней склад 3241 шт | |
77.0 ₽ от 200 шт 5-12 дней склад 3241 шт | |
75.4 ₽ от 250 шт 5-12 дней склад 3241 шт | |
14 ТМ Электроникс Санкт-Петербург Россия | |
IC: driver; low-side,контроллер затвора; TSSOP8; -2÷2А; Ch: 2 | 487 ₽ от 1 шт 5-10 дней склад 6 шт |
Еще 4 цен: … 324 ₽ | |
436 ₽ от 3 шт 5-10 дней склад 6 шт | |
386 ₽ от 10 шт 5-10 дней склад 6 шт | |
348 ₽ от 25 шт 5-10 дней склад 6 шт | |
324 ₽ от 150 шт 5-10 дней склад 6 шт | |
IC: driver; low-side,контроллер затвора; SO8; -2÷2А; Ch: 2; 4÷14ВDC | 569 ₽ от 1 шт 5-10 дней склад 47 шт |
Еще 4 цен: … 380 ₽ | |
513 ₽ от 3 шт 5-10 дней склад 47 шт | |
452 ₽ от 10 шт 5-10 дней склад 47 шт | |
407 ₽ от 25 шт 5-10 дней склад 47 шт | |
380 ₽ от 150 шт 5-10 дней склад 47 шт | |
IC: driver; low-side,контроллер затвора; DIP8; -2÷2А; Ch: 2; 8÷40В | 643 ₽ от 1 шт 5-10 дней склад 30 шт |
Еще 4 цен: … 428 ₽ | |
577 ₽ от 3 шт 5-10 дней склад 30 шт | |
510 ₽ от 10 шт 5-10 дней склад 30 шт | |
460 ₽ от 25 шт 5-10 дней склад 30 шт | |
428 ₽ от 150 шт 5-10 дней склад 30 шт | |
Еще 200 строк | |
IC: driver; low-side,контроллер затвора; SOT23-5; -2÷2А; Ch: 1 | 657 ₽ от 1 шт 5-10 дней склад 285 шт |
Еще 4 цен: … 389 ₽ | |
589 ₽ от 10 шт 5-10 дней склад 285 шт | |
556 ₽ от 25 шт 5-10 дней склад 285 шт | |
445 ₽ от 250 шт 5-10 дней склад 285 шт | |
389 ₽ от 500 шт 5-10 дней склад 285 шт | |
IC: driver; low-side,контроллер затвора; SOT23-5; -2÷2А; Ch: 1 | 569 ₽ от 1 шт 5-10 дней склад 12597 шт |
Еще 4 цен: … 337 ₽ | |
510 ₽ от 10 шт 5-10 дней склад 12597 шт | |
481 ₽ от 25 шт 5-10 дней склад 12597 шт | |
385 ₽ от 250 шт 5-10 дней склад 12597 шт | |
337 ₽ от 500 шт 5-10 дней склад 12597 шт | |
IC: driver; low-side,контроллер затвора; HVSSOP8; 9А; Ch: 1 | 593 ₽ от 1 шт 5-10 дней склад 451 шт |
Еще 4 цен: … 352 ₽ | |
532 ₽ от 10 шт 5-10 дней склад 451 шт | |
428 ₽ от 80 шт 5-10 дней склад 451 шт | |
402 ₽ от 320 шт 5-10 дней склад 451 шт | |
352 ₽ от 560 шт 5-10 дней склад 451 шт | |
IC: driver; low-side,контроллер затвора; DIP8; 9А; Ch: 1; 4,5÷15ВDC | 590 ₽ от 1 шт 5-10 дней склад 22922 шт |
Еще 4 цен: … 400 ₽ | |
529 ₽ от 10 шт 5-10 дней склад 22922 шт | |
499 ₽ от 50 шт 5-10 дней склад 22922 шт | |
426 ₽ от 100 шт 5-10 дней склад 22922 шт | |
400 ₽ от 250 шт 5-10 дней склад 22922 шт | |
IC: driver; low-side,контроллер затвора; SO8; 9А; Ch: 1; 4,5÷15ВDC | 396 ₽ от 1 шт 5-10 дней склад 102 шт |
Еще 3 цен: … 237 ₽ | |
362 ₽ от 5 шт 5-10 дней склад 102 шт | |
303 ₽ от 25 шт 5-10 дней склад 102 шт | |
237 ₽ от 75 шт 5-10 дней склад 102 шт | |
IC: driver; low-side,контроллер затвора; DIP8; 9А; Ch: 1; 4,5÷15ВDC | 524 ₽ от 1 шт 5-10 дней склад 89 шт |
Еще 4 цен: … 354 ₽ | |
470 ₽ от 10 шт 5-10 дней склад 89 шт | |
443 ₽ от 50 шт 5-10 дней склад 89 шт | |
378 ₽ от 100 шт 5-10 дней склад 89 шт | |
354 ₽ от 250 шт 5-10 дней склад 89 шт | |
IC: driver; low-side,контроллер затвора; SO8; 4,5А; Ch: 2 | 500 ₽ от 1 шт 5-10 дней склад 420 шт |
Еще 4 цен: … 338 ₽ | |
448 ₽ от 10 шт 5-10 дней склад 420 шт | |
423 ₽ от 75 шт 5-10 дней склад 420 шт | |
360 ₽ от 150 шт 5-10 дней склад 420 шт | |
338 ₽ от 300 шт 5-10 дней склад 420 шт | |
IC: driver; low-side,контроллер затвора; SO8; 4,5А; Ch: 2 | 457 ₽ от 1 шт 5-10 дней склад 100 шт |
Еще 4 цен: … 306 ₽ | |
412 ₽ от 5 шт 5-10 дней склад 100 шт | |
367 ₽ от 25 шт 5-10 дней склад 100 шт | |
327 ₽ от 75 шт 5-10 дней склад 100 шт | |
306 ₽ от 300 шт 5-10 дней склад 100 шт | |
IC: driver; low-side,контроллер затвора; DIP8; 4А; Ch: 2; 4÷15ВDC | 604 ₽ от 1 шт 5-10 дней склад 81 шт |
Еще 4 цен: … 372 ₽ | |
550 ₽ от 3 шт 5-10 дней склад 81 шт | |
479 ₽ от 10 шт 5-10 дней склад 81 шт | |
425 ₽ от 25 шт 5-10 дней склад 81 шт | |
372 ₽ от 100 шт 5-10 дней склад 81 шт | |
IC: driver; low-side,контроллер затвора; SO8; -4÷4А; Ch: 2; 4÷15ВDC | 346 ₽ от 1 шт 5-10 дней склад 142 шт |
Еще 3 цен: … 205 ₽ | |
290 ₽ от 5 шт 5-10 дней склад 142 шт | |
239 ₽ от 25 шт 5-10 дней склад 142 шт | |
205 ₽ от 75 шт 5-10 дней склад 142 шт | |
IC: driver; low-side,контроллер затвора; HVSSOP8; -4÷4А; Ch: 2 | 518 ₽ от 1 шт 5-10 дней склад 10322 шт |
Еще 4 цен: … 308 ₽ | |
467 ₽ от 10 шт 5-10 дней склад 10322 шт | |
375 ₽ от 80 шт 5-10 дней склад 10322 шт | |
352 ₽ от 320 шт 5-10 дней склад 10322 шт | |
308 ₽ от 560 шт 5-10 дней склад 10322 шт | |
IC: driver; low-side,контроллер затвора; DIP8; -4÷4А; Ch: 2 | 503 ₽ от 1 шт 5-10 дней склад 38 шт |
Еще 3 цен: … 362 ₽ | |
455 ₽ от 3 шт 5-10 дней склад 38 шт | |
401 ₽ от 10 шт 5-10 дней склад 38 шт | |
362 ₽ от 25 шт 5-10 дней склад 38 шт | |
IC: driver; low-side,контроллер затвора; SO8; 4А; Ch: 2; 4÷15ВDC | 612 ₽ от 1 шт 5-10 дней склад 110 шт |
Еще 3 цен: … 439 ₽ | |
550 ₽ от 3 шт 5-10 дней склад 110 шт | |
492 ₽ от 10 шт 5-10 дней склад 110 шт | |
439 ₽ от 25 шт 5-10 дней склад 110 шт | |
IC: driver; low-side,контроллер затвора; DIP8; 4А; Ch: 2; 4÷15ВDC | 566 ₽ от 1 шт 5-10 дней склад 30 шт |
Еще 3 цен: … 404 ₽ | |
510 ₽ от 3 шт 5-10 дней склад 30 шт | |
449 ₽ от 10 шт 5-10 дней склад 30 шт | |
404 ₽ от 25 шт 5-10 дней склад 30 шт | |
IC: driver; low-side,контроллер затвора; SO8; 5А; Ch: 2; 4,5÷18ВDC | 678 ₽ от 1 шт 5-10 дней склад 351 шт |
Еще 4 цен: … 459 ₽ | |
608 ₽ от 10 шт 5-10 дней склад 351 шт | |
574 ₽ от 75 шт 5-10 дней склад 351 шт | |
489 ₽ от 150 шт 5-10 дней склад 351 шт | |
459 ₽ от 300 шт 5-10 дней склад 351 шт | |
IC: driver; low-side,контроллер затвора; SO8; 5А; Ch: 2; 4,5÷18ВDC | 678 ₽ от 1 шт 5-10 дней склад 590 шт |
608 ₽ от 10 шт 5-10 дней склад 590 шт | |
574 ₽ от 75 шт 5-10 дней склад 590 шт | |
489 ₽ от 150 шт 5-10 дней склад 590 шт | |
459 ₽ от 300 шт 5-10 дней склад 590 шт | |
IC: driver; low-side,контроллер затвора; HVSSOP8; 5А; Ch: 2 | 678 ₽ от 1 шт 5-10 дней склад 72605 шт |
Еще 4 цен: … 330 ₽ | |
608 ₽ от 10 шт 5-10 дней склад 72605 шт | |
489 ₽ от 80 шт 5-10 дней склад 72605 шт | |
459 ₽ от 320 шт 5-10 дней склад 72605 шт | |
330 ₽ от 243 шт 5-10 дней склад 72605 шт | |
15 ЭИК Санкт-Петербург Россия | |
LED 3MM 2-HI RED/RED LOW I PCMNT | 254 ₽ от 1 шт 21-42 дня склад 1283 шт |
Еще 3 цен: … 82.0 ₽ | |
161 ₽ от 10 шт 21-42 дня склад 1283 шт | |
90.0 ₽ от 1000 шт 21-42 дня склад 1283 шт | |
82.0 ₽ от 10000 шт 21-42 дня склад 1283 шт | |
LED 3MM RT ANG LOW CUR RED PCMNT | 331 ₽ от 1 шт 21-42 дня склад 665 шт |
Еще 3 цен: … 107 ₽ | |
210 ₽ от 10 шт 21-42 дня склад 665 шт | |
117 ₽ от 1000 шт 21-42 дня склад 665 шт | |
107 ₽ от 10000 шт 21-42 дня склад 665 шт | |
LED 5MM RT ANG LOW CUR RED PCMNT | 301 ₽ от 1 шт 21-42 дня склад 2843 шт |
Еще 3 цен: … 97.0 ₽ | |
190 ₽ от 10 шт 21-42 дня склад 2843 шт | |
107 ₽ от 1000 шт 21-42 дня склад 2843 шт | |
97.0 ₽ от 10000 шт 21-42 дня склад 2843 шт | |
Еще 54 строки | |
LED 5MM RT ANG LOW CUR RED PCMNT | 331 ₽ от 1 шт 21-42 дня склад 1138 шт |
210 ₽ от 10 шт 21-42 дня склад 1138 шт | |
117 ₽ от 1000 шт 21-42 дня склад 1138 шт | |
107 ₽ от 10000 шт 21-42 дня склад 1138 шт | |
LED 3MM LOW CURR RED | 331 ₽ от 1 шт 21-42 дня склад 3716 шт |
210 ₽ от 10 шт 21-42 дня склад 3716 шт | |
117 ₽ от 1000 шт 21-42 дня склад 3716 шт | |
107 ₽ от 10000 шт 21-42 дня склад 3716 шт | |
LED 3HI 3MM LOW CUR RED PC MNT | 818 ₽ от 1 шт 21-42 дня склад 406 шт |
Еще 4 цен: … 344 ₽ | |
578 ₽ от 10 шт 21-42 дня склад 406 шт | |
473 ₽ от 100 шт 21-42 дня склад 406 шт | |
366 ₽ от 1000 шт 21-42 дня склад 406 шт | |
344 ₽ от 5000 шт 21-42 дня склад 406 шт | |
LED 4HI 3MM LOW CUR RED PC MNT | 1 017 ₽ от 1 шт 21-42 дня склад 744 шт |
Еще 3 цен: … 455 ₽ | |
719 ₽ от 10 шт 21-42 дня склад 744 шт | |
589 ₽ от 100 шт 21-42 дня склад 744 шт | |
455 ₽ от 1000 шт 21-42 дня склад 744 шт | |
LED 5MM VERT LOW CUR RED PC MNT | 288 ₽ от 1 шт 21-42 дня склад 294 шт |
Еще 3 цен: … 92.0 ₽ | |
182 ₽ от 25 шт 21-42 дня склад 294 шт | |
102 ₽ от 1000 шт 21-42 дня склад 294 шт | |
92.0 ₽ от 10000 шт 21-42 дня склад 294 шт | |
LED 3MM QUAD LOW CUR RED PC MNT | 890 ₽ от 1 шт 21-42 дня склад 469 шт |
Еще 4 цен: … 375 ₽ | |
629 ₽ от 10 шт 21-42 дня склад 469 шт | |
515 ₽ от 100 шт 21-42 дня склад 469 шт | |
399 ₽ от 1000 шт 21-42 дня склад 469 шт | |
375 ₽ от 5000 шт 21-42 дня склад 469 шт | |
LED 5MM VERT LOW CUR RED PCMNT | 356 ₽ от 1 шт 21-42 дня склад 1038 шт |
Еще 3 цен: … 117 ₽ | |
225 ₽ от 10 шт 21-42 дня склад 1038 шт | |
167 ₽ от 100 шт 21-42 дня склад 1038 шт | |
117 ₽ от 5000 шт 21-42 дня склад 1038 шт | |
LED 3MM LOW CURR RED | 540 ₽ от 1 шт 21-42 дня склад 615 шт |
Еще 4 цен: … 199 ₽ | |
360 ₽ от 50 шт 21-42 дня склад 615 шт | |
277 ₽ от 100 шт 21-42 дня склад 615 шт | |
215 ₽ от 1000 шт 21-42 дня склад 615 шт | |
199 ₽ от 5000 шт 21-42 дня склад 615 шт | |
LED 2HI 3MM LOW CUR RED PC MNT | 540 ₽ от 1 шт 21-42 дня склад 640 шт |
360 ₽ от 50 шт 21-42 дня склад 640 шт | |
277 ₽ от 100 шт 21-42 дня склад 640 шт | |
215 ₽ от 1000 шт 21-42 дня склад 640 шт | |
199 ₽ от 5000 шт 21-42 дня склад 640 шт | |
INDICATOR LOW PRO STR RED LED | 591 ₽ от 1 шт 21-42 дня склад 63 шт |
Еще 4 цен: … 532 ₽ | |
561 ₽ от 10 шт 21-42 дня склад 63 шт | |
546 ₽ от 25 шт 21-42 дня склад 63 шт | |
539 ₽ от 50 шт 21-42 дня склад 63 шт | |
532 ₽ от 100 шт 21-42 дня склад 63 шт | |
LED 5MM VERT LOW CUR RED PC MNT | 305 ₽ от 1 шт 21-42 дня склад 1497 шт |
Еще 3 цен: … 98.0 ₽ | |
193 ₽ от 25 шт 21-42 дня склад 1497 шт | |
108 ₽ от 1000 шт 21-42 дня склад 1497 шт | |
98.0 ₽ от 10000 шт 21-42 дня склад 1497 шт | |
LED CBI 5MM RED 635NM LOW CURR | 218 ₽ от 70 шт 21-42 дня склад 800 шт |
174 ₽ от 490 шт 21-42 дня склад 800 шт | |
LED CBI 3MM RED LOW CURR .250 | 364 ₽ от 1 шт 21-42 дня склад 1171 шт |
Еще 3 цен: … 120 ₽ | |
230 ₽ от 10 шт 21-42 дня склад 1171 шт | |
170 ₽ от 100 шт 21-42 дня склад 1171 шт | |
120 ₽ от 5000 шт 21-42 дня склад 1171 шт | |
LED CBI 3MM RED LOW CURR RA | 364 ₽ от 1 шт 21-42 дня склад 2700 шт |
230 ₽ от 10 шт 21-42 дня склад 2700 шт | |
170 ₽ от 100 шт 21-42 дня склад 2700 шт | |
120 ₽ от 5000 шт 21-42 дня склад 2700 шт | |
LED 5MM QUAD LOW CUR RED PC MNT | 784 ₽ от 20 шт 21-42 дня склад 222 шт |
619 ₽ от 160 шт 21-42 дня склад 222 шт | |
LED RED 1/4" HOLE LOW CUR PNLMNT | 636 ₽ от 1 шт 21-42 дня склад 269 шт |
Еще 4 цен: … 268 ₽ | |
449 ₽ от 10 шт 21-42 дня склад 269 шт | |
368 ₽ от 100 шт 21-42 дня склад 269 шт | |
285 ₽ от 1000 шт 21-42 дня склад 269 шт | |
268 ₽ от 5000 шт 21-42 дня склад 269 шт | |
Микросхема: 4A ULTRA LOW CURRENT N-CH ROAD S | 151 ₽ от 10 шт 21-42 дня склад 6020 шт |
Еще 4 цен: … 52.0 ₽ | |
124 ₽ от 30 шт 21-42 дня склад 6020 шт | |
80.0 ₽ от 250 шт 21-42 дня склад 6020 шт | |
58.0 ₽ от 1000 шт 21-42 дня склад 6020 шт | |
52.0 ₽ от 6000 шт 21-42 дня склад 6020 шт | |
16 ВсеИнструменты.ру Москва Россия | |
Матовый полироль пластика RED с губкой "ЧЕРНЫЙ ЛЕД" Low ... Далее Полироль пластика RED - R4263Матовый полироль пластика RED с губкой "ЧЕРНЫЙ ЛЕД" Low Gloss 250мл в бл. R4263 | 278 ₽ на складе |
Матовый полироль пластика RED с губкой "Классик" Low Gloss ... Далее Полироль пластика RED - R4260Матовый полироль пластика RED с губкой "Классик" Low Gloss 250мл в бл. R4260 | 178 ₽ на складе |
Матовый полироль пластика RED с губкой ОКЕАН Low Gloss 250мл в бл. ... Далее Полироль пластика RED - R4266Матовый полироль пластика RED с губкой ОКЕАН Low Gloss 250мл в бл. R4266 | 278 ₽ на складе |
Еще 9 строк | |
Матовый полироль пластика RED с губкой "МУСКАТЕЛЬ" Low Gloss ... Далее Матовый полироль пластика REDМатовый полироль пластика RED с губкой "МУСКАТЕЛЬ" Low Gloss 250мл в бл. R4262 | 178 ₽ на складе |
Полироль пластика RED Low Gloss Тутти Фрутти, матовый с губкой 250мл ... Далее Полироль пластика RED - R4268Полироль пластика RED Low Gloss Тутти Фрутти, матовый с губкой 250мл R4268 | 278 ₽ на складе |
Полироль пластика RED набор с губкой Low Gloss проф. состав матовый ... Далее Профессиональный полироль пластика REDПолироль пластика RED набор с губкой Low Gloss проф. состав матовый 500мл R4502 | 405 ₽ на складе |
Полироль пластика RED Антитабак Low Gloss матовый с губкой, 250 мл в ... Далее Полироль пластика RED - R4267Полироль пластика RED Антитабак Low Gloss матовый с губкой, 250 мл в блистере R4267 | 278 ₽ на складе |
Матовый полироль пластика RED с губкой "ЛИМОН" Low Gloss ... Далее Матовый полироль пластика REDМатовый полироль пластика RED с губкой "ЛИМОН" Low Gloss 250мл в бл. R4265 | 178 ₽ на складе |
Матовый полироль пластика RED с губкой "Ваниль" Low Gloss ... Далее Матовый полироль пластика REDМатовый полироль пластика RED с губкой "Ваниль" Low Gloss 250мл в бл. R4261 | 278 ₽ на складе |
Матовый полироль пластика RED с губкой "ЯБЛОКО" Low Gloss ... Далее Полироль пластика RED - R4264Матовый полироль пластика RED с губкой "ЯБЛОКО" Low Gloss 250мл в бл. R4264 | 178 ₽ на складе |
Компьютерное кресло Бюрократ CH-330M красный искусственная кожа ... Далее Компьютерное кресло Бюрократ - CH-330M/REDКомпьютерное кресло Бюрократ CH-330M красный искусственная кожа крестовина металл CH-330M/RED | 4 738 ₽ на складе |
Матовый полироль пластика RED с губкой ОКЕАН Low Gloss 250мл в бл. ... Далее Полироль пластика REDМатовый полироль пластика RED с губкой ОКЕАН Low Gloss 250мл в бл. R4266 | запрос на складе |
17 LifeElectronics Санкт-Петербург Россия | |
BINDING POST,CH | запрос 7-14 дней |
Appliance inlet for low voltage, Snap-in Mounting, Front Side, Solder ... Далее 1200127L1/CHSAppliance inlet for low voltage, Snap-in Mounting, Front Side, Solder or Quick-connect Terminal | запрос 7-14 дней |
Еще 11 строк | |
Low voltage fast-switching PNP power transistor | запрос 7-14 дней |
3.5 GHz Low Power CMOS Divide-by-8 Prescaler For RAD-Hard Applications | запрос 7-14 дней |
CSX1-CH-18 27 Апр 2024 07:48 5X7 mm Low Profile SMD Crystal | запрос 7-14 дней |
Quartz Crystal 5X7 mm Low Profile SMD Crystal | запрос 7-14 дней |
Ultra-low Current 2.4V precision analog temperature sensor | запрос 7-14 дней |
Low-Voltage Input Boost Regulator for PIC?® Microcontrollers | запрос 7-14 дней |
Low-Cost 64-Step Volatile Digital POT | запрос 7-14 дней |
Low-Cost NV Digital POT with WiperLock?„? Technology | запрос 7-14 дней |
18 TradeElectronics Москва Россия | |
BINDING POST CH | запрос 7-14 дней |
Low Value Metal Film Resistors | запрос 7-14 дней |
Еще 6 строк | |
19 ТаймЧипс Санкт-Петербург Россия | |
Insulated Low Thermal EMF Spade Lug | запрос 7-14 дней |
Еще 8 строк | |
CSX1-CH-32 27 Апр 2024 07:48 5X7 mm Low Profile SMD Crystal | запрос 7-14 дней |
Поворотные переключатели SP 11 POS LOW SHAFT PC GRAY TIPPED KNOB | запрос 7-14 дней |
20 ЭлектроПласт Санкт-Петербург Россия | |
Blade Terminal & Special Purpose Fuses -Low Voltage | запрос 7-14 дней |
Low-Cost, Versatile, 10/100kHz Frequency to Voltage Converters | запрос 7-14 дней |
Еще 8 строк | |
CSX1-CH-25 27 Апр 2024 07:48 5X7 mm Low Profile SMD Crystal | запрос 7-14 дней |
LOW COST, ONE WIRE DIGITAL THERMOMETER WITH SHUTDOWN | запрос 7-14 дней |
CH-LTLGLX-RED 27 Апр 2024 07:48 | запрос 7-14 дней |
21 ЭлектроПласт- Екатеринбург Екатеринбург Россия | |
Spade Lug Patch Cord For Low Voltage Measurements | запрос 7-14 дней |
C1350XBBLACK/RED 27 Апр 2024 07:48 Large, low-cost 31/2 Digit Backlit Bezel Mount LCD Display Digital ... Далее C1350XBBLACK/REDLarge, low-cost 31/2 Digit Backlit Bezel Mount LCD Display Digital Panel Meters | запрос 7-14 дней |
Еще 6 строк | |
CSX1-CH-22 27 Апр 2024 07:48 5X7 mm Low Profile SMD Crystal | запрос 7-14 дней |
PRECISION LOW NOISE OPERATIONAL AMPLIFIERS | запрос 7-14 дней |
22 Океан Электроники Санкт-Петербург Россия | |
Low-Power Quad Operational Amplifier | запрос 7-14 дней |
Low-Profile Plug-in Smoke Detectors | запрос 7-14 дней |
Еще 17 строк | |
INTERCONNECTS .100?€? Grid (.030?€? dia.) Low Profile Headers & ... Далее 800T-D6A/REDINTERCONNECTS .100?€? Grid (.030?€? dia.) Low Profile Headers & Versatile Sockets Single and Double Row | запрос 7-14 дней |
Ultra Low Profile - 4.3mm | запрос 7-14 дней |
CSX1-CH-16 27 Апр 2024 07:48 5X7 mm Low Profile SMD Crystal | запрос 7-14 дней |
60-CHS-RED 27 Апр 2024 07:48 | запрос 7-14 дней |
23 Зенер Москва Россия и страны ТС | |
BINDING POST CH | запрос 5-15 дней |
BINDING POST,CH | запрос 5-15 дней склад 22 шт |
24 Десси Москва Россия | |
YIHUA 993D+ паяльная станция 1300Вт (питание 220В-240В; мощность 1300Вт; температурный режим: 100° - 500°С; 10 термопрофилей CH0 - CH9 с шестью шагами) 02 Апр 2024 09:03 YIHUA 993D+ паяльная станция 1300Вт (питание 220В-240В; мощность ... Далее YIHUA 993D+ паяльная станция 1300Вт (питание 220В-240В; мощность 1300Вт; температурный режим: 100° - 500°С; 10 термопрофилей CH0 - CH9 с шестью шагами)YIHUA 993D+ паяльная станция 1300Вт (питание 220В-240В; мощность 1300Вт; температурный режим: 100° - 500°С; 10 термопрофилей CH0 - ... | 43 140 ₽ |
25 Romstore Москва Россия, Беларусь | |
TD62308APG 25 Апр 2024 02:14 4ch low input active high-current darlington sink driver | 320 ₽ розница |
248 ₽ опт | |
PMV65XP 25 Апр 2024 02:14 P-ch TrenchMOS extremely low level FET | 30.0 ₽ розница |
19.0 ₽ опт | |
TLE5216G 25 Апр 2024 02:14 smart 4-ch low-side switch | 1 600 ₽ розница |
1 328 ₽ опт | |
26 Стандарт СИЗ Москва Россия Только юр.лица Безнал. расчет Заказ от 5000 руб. Строка от 400 руб. | |
3mm round low current led lamp/red 640nm/red diffused/8-20mcd/2mA/40& ... Далее L-934LSRD3mm round low current led lamp/red 640nm/red diffused/8-20mcd/2mA/40° | 2.86 ₽ от 5000 ₽ |
3mm round low current led lamp/red 625nm/red diffused/0.7-3mcd/40° | 1.88 ₽ от 5000 ₽ |
5mm round low current led lamp/red 617nm/red diffused/0.7-2mcd/2mA/30& ... Далее L-7113LID5mm round low current led lamp/red 617nm/red diffused/0.7-2mcd/2mA/30° | 1.88 ₽ от 5000 ₽ |
Еще 1 строка | |
3mm round low current led lamp/red 640nm/red diffused/8-20mcd/2mA/40& ... Далее L-7104LSRD3mm round low current led lamp/red 640nm/red diffused/8-20mcd/2mA/40° | 1.83 ₽ от 5000 ₽ |
27 Контест Москва Россия | |
LED 5MM 645NM RED DIFF LOW CURR | запрос склад 37 шт |
TVS ARRAY ESD LOW 1CH SOT23-3 | запрос склад 183 шт |
TVS ARRAY ESD LOW 1CH SOT23-3 | запрос склад 1777 шт |
Еще 3 строки | |
TVS ARRAY ESD LOW 2CH SOT23-5 | запрос склад 10642 шт |
CM1223-02SR 25 Апр 2024 02:08 TVS ARRAY ESD LOW 2CH SOT143-4 | 173 ₽ склад 8 шт |
TVS ARRAY ESD LOW 4CH SOT23-6 | запрос склад 1008 шт |
Искать "CH-993-LOW/RED" в других поисковых системах: Везде-РадиоЛоцман DataSheet.ru Google
USD | 92.1314 |
EUR | 98.7079 |
