1 AiPCBA Китай Весь мир | |
374 ₽ 2-7 дней отгрузка со склада в Китае склад 95 шт | |
2 Akcel Китай Весь мир | |
запрос от 1 шт 5-7 дней | |
... : 12, unshielded, moulded cable, IP69K, Ecolab, FDA compliant, Special ... Далее 77 3727 0000 40912-0500M12-A male angled connector, Contacts: 12, unshielded, moulded cable, IP69K, Ecolab, FDA compliant, Special TPE grey, 12 x 0.25 ... | запрос от 1 шт |
... : 3, unshielded, moulded cable, IP69K, Ecolab, FDA compliant, Special ... Далее 77 3727 0000 40403-0500M12-A male angled connector, Contacts: 3, unshielded, moulded cable, IP69K, Ecolab, FDA compliant, Special TPE grey, 3 x 0.34 ... | запрос от 1 шт |
Еще 164 строки | |
Iec, Conn, 3P4W, 60A 3P 480V4X/IP69K, Pilot | запрос от 1 шт |
... Plated Alum;12-30VDC;IP68g, IP69K / Banner Engineering WLC60CW340GFAR Далее WLC60CW340GFARWLC60 Work Light;340mm;Flush Mount;Nickel Plated Alum;12-30VDC;IP68g, IP69K / Banner Engineering WLC60CW340GFAR | запрос от 1 шт |
... OV10640 Waterproof: IP67 (Up to IP69K) Active Pixels: 1280H x 1080V ... Далее LI-USB30-OV10640-GMSL2 -060H ... CMOS 1.3M Image Sensor OV10640 Waterproof: IP67 (Up to IP69K) Active Pixels: 1280H x 1080V Lens: FOV H 60 | запрос от 1 шт |
... ,Illuminated, Green, Red, NPN, IP68, IP69K [blank] Далее CPB2110000NGSSCapacitive Switch Momentary,Illuminated, Green, Red, NPN, IP68, IP69K [blank] | запрос от 1 шт |
... Rating: Ip66; Ip67; Ip69K; Color: White; Cascadable; Euro ... Далее WLS27CW850DSQ-93354 ... Mm; Voltage: 12-30 V Dc; Environmental Rating: Ip66; Ip67; Ip69K; Color: White; Cascadable; Euro 4-Pin Quick Disconnect; Lowered Power ... | запрос от 1 шт |
... dc; Housing: Polycarbonate; IP66 IP67 IP69K; Input: Bimodal; Colors ... Далее K50PCLRGB7A ... Indicator; Voltage: 12-30 V dc; Housing: Polycarbonate; IP66 IP67 IP69K; Input: Bimodal; Colors: Multicolor; 2 m (6.5 ft) Cable | запрос от 1 шт |
... Mount, SPST, 22mm Cutout, IP67, IP69K Далее 181083 C22-DR-S-K01-P5Eaton Eaton Moeller Series Push Button, Panel Mount, SPST, 22mm Cutout, IP67, IP69K | запрос от 1 шт |
... Mount, SPST, 22mm Cutout, IP67, IP69K Далее 181624 C22-DL-B-K10-24-P3Eaton Eaton Moeller Series Illuminated Push Button, Panel Mount, SPST, 22mm Cutout, IP67, IP69K | запрос от 1 шт |
... DC, HOUSING: POLYCARBONATE, IP66 IP67 IP69K, INPUT: BIMODAL, COLORS ... Далее K30L2FRGB7QP ... FDA, VOLTAGE: 10-30 V DC, HOUSING: POLYCARBONATE, IP66 IP67 IP69K, INPUT: BIMODAL, COLORS: MULTICOLOR, EURO 5-PIN 150 MM (6 ... | запрос от 1 шт |
... 12-30V dc; Housing: Polycarbonate; IP69K; Input: PNP; Colors: Green; 2 ... Далее K50BCLXGXP ... Perimeter AND Top View ; Voltage: 12-30V dc; Housing: Polycarbonate; IP69K; Input: PNP; Colors: Green; 2 m (6.5 ft) cable | запрос от 1 шт |
... -30V dc; Housing: Polycarbonate; IP67 IP69K; Input: PNP (NO); Colors ... Далее K50APTGREQ ... Overrides Touch Light; Voltage: 12-30V dc; Housing: Polycarbonate; IP67 IP69K; Input: PNP (NO); Colors: Green Red; Euro-style Quick ... | запрос от 1 шт |
... -30V dc; Environmental Rating: IP67; IP69K; Input: PNP; Colors: Green ... Далее K50FLGBYPQ ... Flat Pack Indicator; Voltage: 18-30V dc; Environmental Rating: IP67; IP69K; Input: PNP; Colors: Green Blue Yellow ; Euro-style Quick ... | запрос от 1 шт |
... 12-30Vdc; FDA Copolyester; IP67 IP69K; NPN (NO); Colors: Red - Power ... Далее K30ANT2FRGF2QP ... -Color Touch Sensor Gen2 FDA;; 12-30Vdc; FDA Copolyester; IP67 IP69K; NPN (NO); Colors: Red - Power applied, Green - Input Active; Euro ... | запрос от 1 шт |
... dc; Housing: FDA Copolyester; IP67 IP69K; Input: NPN (NO); Colors ... Далее K30ANT2FGXDQP ... Only; Voltage: 12-30 V dc; Housing: FDA Copolyester; IP67 IP69K; Input: NPN (NO); Colors: Green; Euro 150 mm (6 in ... | запрос от 1 шт |
... V Dc; Housing: Polycarbonate; Ip67 Ip69K; Input: Pnp (No); Colors ... Далее K50APT2YGCQ ... Job Light; Voltage: 12-30 V Dc; Housing: Polycarbonate; Ip67 Ip69K; Input: Pnp (No); Colors: Yellow Green; Euro 5-Pin Integral ... | запрос от 1 шт |
... V dc; Housing: Polycarbonate; IP67 IP69K; Input: NPN (NO); Colors ... Далее K30ANTGYCQ ... Job Light; Voltage: 12-30 V dc; Housing: Polycarbonate; IP67 IP69K; Input: NPN (NO); Colors: Green Yellow; Euro 4-pin Integral ... | запрос от 1 шт |
... -130 V ac; Housing: Polycarbonate; IP69K; Colors: White; 2 m (6 ... Далее K50BCLWA120 ... Perimeter & Top View; Voltage: 85-130 V ac; Housing: Polycarbonate; IP69K; Colors: White; 2 m (6.5 ft) Cable (800899) | запрос от 1 шт |
3 Flash-Turtle Китай Весь мир | |
... Side Entry PG16 3 IP68/IP69K - Dust Tight, Water Resistant, Waterproof Далее 2-1102631-5Hood Connector Side Entry PG16 3 IP68/IP69K - Dust Tight, Water Resistant, Waterproof | запрос 7 дней склад 9185 шт |
... Side Entry M32 4 IP68/IP69K - Dust Tight, Water Resistant, Waterproof Далее 1106426-2Base - Box Mount Connector Side Entry M32 4 IP68/IP69K - Dust Tight, Water Resistant, Waterproof | запрос 7 дней склад 24053 шт |
... Side Entry M32 3 IP68/IP69K - Dust Tight, Water Resistant, Waterproof Далее 1106424-1Base - Box Mount Connector Side Entry M32 3 IP68/IP69K - Dust Tight, Water Resistant, Waterproof | запрос 7 дней склад 22278 шт |
Еще 73 строки | |
... Side Entry M25 4 IP68/IP69K - Dust Tight, Water Resistant, Waterproof Далее 1106436-2Hood Connector Side Entry M25 4 IP68/IP69K - Dust Tight, Water Resistant, Waterproof | запрос 7 дней склад 24253 шт |
... Entry PG13.5 3A IP68/IP69K - Dust Tight, Water Resistant, Waterproof Далее Molex 0936010611Base - Panel Mount 90° Connector Side Entry PG13.5 3A IP68/IP69K - Dust Tight, Water Resistant, Waterproof | запрос 7 дней склад 14325 шт |
... Side Entry M32 6B IP68/IP69K - Dust Tight, Water Resistant, Waterproof Далее Molex 0936010776Base - Box Mount Connector Side Entry M32 6B IP68/IP69K - Dust Tight, Water Resistant, Waterproof | запрос 7 дней склад 41630 шт |
... Entry, Dual M25 6B IP66/IP69K - Dust Tight, Water Resistant ... Далее Molex 0936010785Base - Box Mount Connector Side Entry, Dual M25 6B IP66/IP69K - Dust Tight, Water Resistant, Waterproof | запрос 7 дней склад 13803 шт |
... Top Entry PG21 6B IP66/IP69K - Dust Tight, Water Resistant, Waterproof Далее Molex 0936010800Hood Connector Top Entry PG21 6B IP66/IP69K - Dust Tight, Water Resistant, Waterproof | запрос 7 дней склад 49645 шт |
... Top Entry M25 6B IP66/IP69K - Dust Tight, Water Resistant, Waterproof Далее Molex 0936010860Hood Connector Top Entry M25 6B IP66/IP69K - Dust Tight, Water Resistant, Waterproof | запрос 7 дней склад 21359 шт |
... Top Entry M32 6B IP66/IP69K - Dust Tight, Water Resistant, Waterproof Далее Molex 0936010867Hood Connector Top Entry M32 6B IP66/IP69K - Dust Tight, Water Resistant, Waterproof | запрос 7 дней склад 33223 шт |
... Side Entry M32 6B IP66/IP69K - Dust Tight, Water Resistant, Waterproof Далее Molex 0936010890Hood Connector Side Entry M32 6B IP66/IP69K - Dust Tight, Water Resistant, Waterproof | запрос 7 дней склад 31530 шт |
... Bottom Entry M25 6B IP66/IP69K - Dust Tight, Water Resistant ... Далее Molex 0936011016Base - Box Mount Connector Bottom Entry M25 6B IP66/IP69K - Dust Tight, Water Resistant, Waterproof | запрос 7 дней склад 8648 шт |
... Connector Top Entry M25 IP66/IP69K - Dust Tight, Water Resistant, ... Далее Molex 0936011033Hood Connector Top Entry M25 IP66/IP69K - Dust Tight, Water Resistant, Waterproof | запрос 7 дней склад 46589 шт |
... Top Entry M25 10B IP68/IP69K - Dust Tight, Water Resistant, Waterproof Далее Molex 0936011059Hood Connector Top Entry M25 10B IP68/IP69K - Dust Tight, Water Resistant, Waterproof | запрос 7 дней склад 35632 шт |
... Top Entry M32 10B IP68/IP69K - Dust Tight, Water Resistant, Waterproof Далее Molex 0936011060Hood Connector Top Entry M32 10B IP68/IP69K - Dust Tight, Water Resistant, Waterproof | запрос 7 дней склад 36137 шт |
... Top Entry M40 10B IP68/IP69K - Dust Tight, Water Resistant, Waterproof Далее Molex 0936011061Hood Connector Top Entry M40 10B IP68/IP69K - Dust Tight, Water Resistant, Waterproof | запрос 7 дней склад 14883 шт |
... Side Entry M20 10B IP68/IP69K - Dust Tight, Water Resistant ... Далее Molex 0936011066Hood Connector Side Entry M20 10B IP68/IP69K - Dust Tight, Water Resistant, Waterproof | запрос 7 дней склад 25772 шт |
... Side Entry PG21 10B IP68/IP69K - Dust Tight, Water Resistant ... Далее Molex 0936011071Hood Connector Side Entry PG21 10B IP68/IP69K - Dust Tight, Water Resistant, Waterproof | запрос 7 дней склад 37093 шт |
... Side Entry M40 10B IP68/IP69K - Dust Tight, Water Resistant ... Далее Molex 0936011081Base - Box Mount Connector Side Entry M40 10B IP68/IP69K - Dust Tight, Water Resistant, Waterproof | запрос 7 дней склад 44511 шт |
... Entry, Dual PG29 10B IP68/IP69K - Dust Tight, Water Resistant ... Далее Molex 0936011119Base - Box Mount Connector Side Entry, Dual PG29 10B IP68/IP69K - Dust Tight, Water Resistant, Waterproof | запрос 7 дней склад 43625 шт |
4 Utmel Китай Весь мир | |
A22NE-MP-P212-N-69K 02 Мар 2024 14:35 ... -Stop Switches Estp 40mm PulRst2NC1NOPI IP69K Далее A22NE-MP-P212-N-69KEmergency Stop Switches / E-Stop Switches Estp 40mm PulRst2NC1NOPI IP69K | запрос от 1 шт 5-7 дней склад 7899 шт |
A22NE-MP-P002-N-69K 02 Мар 2024 14:35 Emergency Stop Switches / E-Stop Switches Estp 40mm PulRst1NC PI IP69K | запрос от 1 шт 5-7 дней склад 4129 шт |
D40ML-SS1-B-5M 02 Мар 2024 14:35 Magnetic / Reed Switches SuS IP69K, 950N, Mast., 5M | запрос от 1 шт 5-7 дней склад 2756 шт |
Еще 158 строк | |
F3SG-4SRB0960-14-K 02 Мар 2024 14:35 Safety Light Curtains GLC Basic Finger Safe IP69K | запрос от 1 шт 5-7 дней склад 4609 шт |
D40ML-SS2-U-10M 02 Мар 2024 14:35 Magnetic / Reed Switches SuS IP69K, 600N, Uniq., 10M | запрос от 1 шт 5-7 дней склад 291 шт |
F3SG-4SRB0320-25-K 02 Мар 2024 14:35 Safety Light Curtains GLC Basic Hand Safe IP69K | запрос от 1 шт 5-7 дней склад 1414 шт |
F39-LSGTB-K 02 Мар 2024 14:35 Safety Light Curtains F3SGSRB IP69K Bracket | запрос от 1 шт 5-7 дней склад 6533 шт |
A22NE-MP-P222-N-69K 02 Мар 2024 14:35 Emergency Stop Switches / E-Stop Switches Estp PulRst3NC PI IP69K | запрос от 1 шт 5-7 дней склад 7335 шт |
F3SG-4SRB1520-25-K 02 Мар 2024 14:35 Safety Light Curtains GLC Basic Hand Safe IP69K | запрос от 1 шт 5-7 дней склад 2080 шт |
... , Ball, 4-Wire, Tach/PWM, IP69K Далее 09225VE-24L-CU-02DC Fans Axial Fan, 92x92x25mm, 24VDC, 63.6CFM, 4.56W, Rib, Ball, 4-Wire, Tach/PWM, IP69K | 2 502 ₽ от 1 шт 5-7 дней склад 14 шт |
Еще 3 цен: … 2 101 ₽ | |
2 360 ₽ от 10 шт 5-7 дней склад 14 шт | |
2 227 ₽ от 100 шт 5-7 дней склад 14 шт | |
2 101 ₽ от 1000 шт 5-7 дней склад 14 шт | |
... , 105W, 68.2dBA, Ball, Wire, IP69K Далее OA200AP-22-1WB1869KAC Fans Axial Fan, 200x200x70mm, 230VAC, 485CFM, 105W, 68.2dBA, Ball, Wire, IP69K | 13 825 ₽ от 1 шт 5-7 дней склад 10 шт |
Еще 3 цен: … 11 607 ₽ | |
13 042 ₽ от 10 шт 5-7 дней склад 10 шт | |
12 304 ₽ от 100 шт 5-7 дней склад 10 шт | |
11 607 ₽ от 1000 шт 5-7 дней склад 10 шт | |
... .12A, 33dBA, 3300RPM, Ball, Wire, IP69K Далее OD8025-24HBIP69KDC Fans DC Fan, 80x80x25mm, 24VDC, 40CFM, 0.12A, 33dBA, 3300RPM, Ball, Wire, IP69K | 2 104 ₽ от 1 шт 5-7 дней склад 729 шт |
Еще 3 цен: … 1 766 ₽ | |
1 985 ₽ от 10 шт 5-7 дней склад 729 шт | |
1 872 ₽ от 100 шт 5-7 дней склад 729 шт | |
1 766 ₽ от 1000 шт 5-7 дней склад 729 шт | |
... .45A, 42dBA, 3100RPM, Ball, Wire, IP69K Далее OD1225-12HBIP69KDC Fans DC Fan, 120x120x25mm, 12VDC, 120CFM, 0.45A, 42dBA, 3100RPM, Ball, Wire, IP69K | запрос от 1 шт 5-7 дней склад 66 шт |
... , 105W, 68.2dBA, Ball, Terminal, IP69K Далее OA200AP-22-1TB1869KAC Fans Axial Fan, 200x200x70mm, 230VAC, 485CFM, 105W, 68.2dBA, Ball, Terminal, IP69K | 13 825 ₽ от 1 шт 5-7 дней склад 10 шт |
... .1A, 44dBA, 2900RPM, Ball, Wire, IP69K Далее OD1238-48HBIP69KDC Fans DC Fan, 120x120x38mm, 48VDC, 124CFM, 0.1A, 44dBA, 2900RPM, Ball, Wire, IP69K | 4 387 ₽ от 1 шт 5-7 дней склад 98 шт |
Еще 3 цен: … 3 683 ₽ | |
4 138 ₽ от 10 шт 5-7 дней склад 98 шт | |
3 904 ₽ от 100 шт 5-7 дней склад 98 шт | |
3 683 ₽ от 1000 шт 5-7 дней склад 98 шт | |
... , 1300CFM, 210W, 73dBA, Ball, Terminal, IP69K Далее OA280AP-22-1TB1869KAC Fans Axial Fan, 280x280x89mm, 230VAC, 1300CFM, 210W, 73dBA, Ball, Terminal, IP69K | 23 607 ₽ от 1 шт 5-7 дней склад 24 шт |
Еще 3 цен: … 19 821 ₽ | |
22 270 ₽ от 10 шт 5-7 дней склад 24 шт | |
21 010 ₽ от 100 шт 5-7 дней склад 24 шт | |
19 821 ₽ от 1000 шт 5-7 дней склад 24 шт | |
... .07A, 30dBA, 4200RPM, Ball, Wire, IP69K Далее OD6025-48HBIP69KDC Fans DC Fan, 60x60x25mm, 48VDC, 28CFM, 0.07A, 30dBA, 4200RPM, Ball, Wire, IP69K | 2 411 ₽ от 1 шт 5-7 дней склад 158 шт |
Еще 3 цен: … 2 025 ₽ | |
2 275 ₽ от 10 шт 5-7 дней склад 158 шт | |
2 146 ₽ от 100 шт 5-7 дней склад 158 шт | |
2 025 ₽ от 1000 шт 5-7 дней склад 158 шт | |
... , 105W, 68.2dBA, Ball, Wire, IP69K Далее OA200AP-11-1WB1869KAC Fans Axial Fan, 200x200x70mm, 115VAC, 485CFM, 105W, 68.2dBA, Ball, Wire, IP69K | запрос от 1 шт 5-7 дней склад 5 шт |
... .3A, 49dBA, 5000RPM, Ball, Wire, IP69K Далее OD8038-24HBIP69KDC Fans DC Fan, 80x80x38mm, 24VDC, 71CFM, 0.3A, 49dBA, 5000RPM, Ball, Wire, IP69K | 2 972 ₽ от 1 шт 5-7 дней склад 1046 шт |
Еще 3 цен: … 2 495 ₽ | |
2 804 ₽ от 10 шт 5-7 дней склад 1046 шт | |
2 645 ₽ от 100 шт 5-7 дней склад 1046 шт | |
2 495 ₽ от 1000 шт 5-7 дней склад 1046 шт | |
... , 105W, 67dBA, 3300RPM, Ball, Wire, IP69K Далее OA2543AP-22-1WB1869KAC Fans Axial Fan, 254x254x89mm, 230VAC, 930CFM, 105W, 67dBA, 3300RPM, Ball, Wire, IP69K | 16 341 ₽ от 1 шт 5-7 дней склад 12 шт |
Еще 3 цен: … 13 721 ₽ | |
15 416 ₽ от 10 шт 5-7 дней склад 12 шт | |
14 544 ₽ от 100 шт 5-7 дней склад 12 шт | |
13 721 ₽ от 1000 шт 5-7 дней склад 12 шт | |
5 Industrial Module Москва Россия | |
IP69K LITEON QCNFA324 WIFI/BT KIT1x1 ... Далее IP69K LITEON QCNFA324 WIFI/BT KITIP69K LITEON QCNFA324 WIFI/BT KIT1x1 WiFi + Bluetooth4.1 with miniPCIe ... | 9 698 ₽ 7-28 дней на складе |
Intel AtomR D2550 1.86 GHz , 19 LCD, LED Backlight, SXGA (1280x1024), ... Далее FOOD-C19 IP69K, AC, PENTA LOGOIntel AtomR D2550 1.86 GHz , 19 LCD, LED Backlight, SXGA (1280x1024), internal wide range power supply 110V/240V | запрос 7-28 дней на складе |
Intel AtomR D2550 1.86 GHz , 17 LCD, LED Backlight, SXGA (1280x1024), ... Далее FOOD-C17 IP69K, AC, PENTA LOGOIntel AtomR D2550 1.86 GHz , 17 LCD, LED Backlight, SXGA (1280x1024), internal wide range power supply 110V/240V | запрос 7-28 дней на складе |
Еще 49 строк | |
Intel AtomR D2550 1.86 GHz, 15" LCD, LED Backlight, XGA (1024x768 ... Далее FOOD-C15 IP69K, AC, PENTA LOGOIntel AtomR D2550 1.86 GHz, 15" LCD, LED Backlight, XGA (1024x768), internal wide range power supply 110V/240V | запрос 7-28 дней на складе |
15" Stainless Steel Panel PC w/ i3-6100U / IP69k | запрос 7-28 дней на складе |
... ;Gasket:RubberFinish: Nickel PlatedFor Titan IP69K Connector use Далее M12 FEMALE CAPMaterial:Body:Copper Alloy;Gasket:RubberFinish: Nickel PlatedFor Titan IP69K Connector use | 280 ₽ 7-28 дней на складе |
Датчик IFM ProcessLine 8 SB IP69K | запрос 7-28 дней на складе |
Датчик IFM ProcessLine 8 SB IP69K | 596 ₽ 7-28 дней на складе |
Датчики IFM ProcessLine 4AI C IP69K | запрос 7-28 дней на складе |
Датчики IFM ProcessLine 4AI C IP69K | 1 789 ₽ 7-28 дней на складе |
Датчик IFM ProcessLine 4AI C IP69K | запрос 7-28 дней на складе |
Датчик IFM ProcessLine 4AI C IP69K | 1 789 ₽ 7-28 дней на складе |
Датчик IFM ProcessLine 4DI 3DOT IP69K | запрос 7-28 дней на складе |
Датчик IFM ProcessLine 4DI 3DOT IP69K | 1 292 ₽ 7-28 дней на складе |
Датчик IFM ProcessLine 8DI IP69K | запрос 7-28 дней на складе |
Датчик IFM ProcessLine 8DI IP69K | 1 192 ₽ 7-28 дней на складе |
AE Шкаф IP69K нерж.сталь 400x400x250mm | запрос 7-28 дней на складе |
AE Распред.шкаф IP69K 400x650x250mm | запрос 7-28 дней на складе |
AE Распред.шкаф IP69K 230x330x155mm | запрос 7-28 дней на складе |
AE Шкаф IP69K нерж.сталь 230x330x155mm | запрос 7-28 дней на складе |
6 ЧипСити Москва Россия | |
AC FAN, IP69K, 176X176X89MM, 230 | 11 436 ₽ 3-7 дней склад 415 шт |
DC FAN, IP69K, 172X150X51MM, 48V | 9 343 ₽ 3-7 дней склад 138 шт |
DC FAN, IP69K, 172X150X51MM, 24V | 8 477 ₽ 3-7 дней склад 286 шт |
Еще 202 строки | |
DC FAN, IP69K, 60X60X25MM, 24VDC | 1 755 ₽ 3-7 дней склад 721 шт |
AC FAN, IP69K, 180X180X65MM, 230 | 9 988 ₽ 3-7 дней склад 431 шт |
AC FAN, IP69K, 180X180X65MM, 230 | 10 501 ₽ 3-7 дней склад 205 шт |
AC FAN, IP69K, 176X176X89MM, 115 | 10 471 ₽ 3-7 дней склад 239 шт |
DC FAN, IP69K, 92X92X25MM, 48VDC | 2 325 ₽ 3-7 дней склад 514 шт |
DC FAN, HIGH PERFORMANCE, IP69K, | 9 282 ₽ 3-7 дней склад 556 шт |
DC FAN, HIGH PERFORMANCE, IP69K, | 8 114 ₽ 3-7 дней склад 401 шт |
DC FAN, IP69K, 60X60X25MM, 48VDC | 2 245 ₽ 3-7 дней склад 933 шт |
DC FAN, IP69K, 80X80X32MM, 12VDC | 2 865 ₽ 3-7 дней склад 929 шт |
DC FAN, IP69K, 80X80X32MM, 48VDC | 2 865 ₽ 3-7 дней склад 497 шт |
DC FAN, IP69K, 120X120X25MM, 48V | 3 782 ₽ 3-7 дней склад 760 шт |
DC FAN, IP69K, 120X120X38MM, 48V | 3 726 ₽ 3-7 дней склад 979 шт |
DC FAN, IP69K, 80X80X25MM, 48VDC | 2 452 ₽ 3-7 дней склад 129 шт |
DC FAN, IP69K, 120X120X25MM, 12V | 2 954 ₽ 3-7 дней склад 506 шт |
DC FAN, IP69K, 80X80X38MM, 12VDC | 2 380 ₽ 3-7 дней склад 544 шт |
DC FAN, IP69K, 80X80X38MM, 24VDC | 2 830 ₽ 3-7 дней склад 447 шт |
DC FAN, IP69K, 92X92X25MM, 24VDC | 1 958 ₽ 3-7 дней склад 1280 шт |
7 ТМ Электроникс Санкт-Петербург Россия | |
Элемент компенсации давления; IP68,IP69K; Корпус: черный; 6,4мм | 788 ₽ от 1 шт 5-10 дней склад 486 шт |
Еще 2 цен: … 477 ₽ | |
633 ₽ от 50 шт 5-10 дней склад 486 шт | |
477 ₽ от 100 шт 5-10 дней склад 486 шт | |
Элемент компенсации давления; IP68,IP69K; Корпус: черный; 6,4мм | 1 568 ₽ от 1 шт 5-10 дней склад 499 шт |
Еще 2 цен: … 946 ₽ | |
1 260 ₽ от 50 шт 5-10 дней склад 499 шт | |
946 ₽ от 100 шт 5-10 дней склад 499 шт | |
Элемент компенсации давления; IP68,IP69K; Корпус: черный; 6,4мм | 1 196 ₽ от 1 шт 5-10 дней склад 198 шт |
Еще 2 цен: … 721 ₽ | |
960 ₽ от 50 шт 5-10 дней склад 198 шт | |
721 ₽ от 100 шт 5-10 дней склад 198 шт | |
Еще 168 строк | |
Элемент компенсации давления; IP68,IP69K; Корпус: серый; 6,4мм | 788 ₽ от 1 шт 5-10 дней склад 221 шт |
633 ₽ от 50 шт 5-10 дней склад 221 шт | |
477 ₽ от 100 шт 5-10 дней склад 221 шт | |
Элемент компенсации давления; IP68,IP69K; Корпус: серый; 6,4мм | 1 568 ₽ от 1 шт 5-10 дней склад 498 шт |
1 260 ₽ от 50 шт 5-10 дней склад 498 шт | |
946 ₽ от 100 шт 5-10 дней склад 498 шт | |
Элемент компенсации давления; IP68,IP69K; Корпус: серый; 6,4мм | 1 094 ₽ от 1 шт 5-10 дней склад 505 шт |
Еще 2 цен: … 660 ₽ | |
879 ₽ от 50 шт 5-10 дней склад 505 шт | |
660 ₽ от 100 шт 5-10 дней склад 505 шт | |
Элемент компенсации давления; IP68,IP69K; Корпус: серый; 6,4мм | 1 196 ₽ от 1 шт 5-10 дней склад 500 шт |
960 ₽ от 50 шт 5-10 дней склад 500 шт | |
721 ₽ от 100 шт 5-10 дней склад 500 шт | |
Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 89,4мм; ... Далее 45-410.2403Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 89,4мм; Z: 64мм | 11 885 ₽ от 1 шт 5-10 дней склад 1 шт |
Еще 2 цен: … 10 397 ₽ | |
11 140 ₽ от 5 шт 5-10 дней склад 1 шт | |
10 397 ₽ от 10 шт 5-10 дней склад 1 шт | |
Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 85мм; Z: ... Далее 45-420.1401Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 85мм; Z: 64мм | 12 673 ₽ от 1 шт 5-10 дней склад 5 шт |
Еще 2 цен: … 11 099 ₽ | |
11 901 ₽ от 5 шт 5-10 дней склад 5 шт | |
11 099 ₽ от 10 шт 5-10 дней склад 5 шт | |
Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 85мм; Z: ... Далее 45-420.2403Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 85мм; Z: 64мм | 24 413 ₽ от 1 шт 5-10 дней склад 1 шт |
Еще 2 цен: … 21 359 ₽ | |
22 888 ₽ от 5 шт 5-10 дней склад 1 шт | |
21 359 ₽ от 10 шт 5-10 дней склад 1 шт | |
Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 89,4мм; ... Далее 45-420.2803Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 89,4мм; Z: 64мм | 38 550 ₽ от 1 шт 5-10 дней склад 1 шт |
Еще 2 цен: … 33 732 ₽ | |
36 142 ₽ от 5 шт 5-10 дней склад 1 шт | |
33 732 ₽ от 10 шт 5-10 дней склад 1 шт | |
Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 85мм; Z: ... Далее 45-430.1801Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 85мм; Z: 64мм | 3 166 ₽ от 1 шт 5-10 дней склад 5 шт |
Еще 2 цен: … 2 845 ₽ | |
2 971 ₽ от 5 шт 5-10 дней склад 5 шт | |
2 845 ₽ от 10 шт 5-10 дней склад 5 шт | |
Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 89,4мм; ... Далее 45-430.2803Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 89,4мм; Z: 64мм | 10 231 ₽ от 1 шт 5-10 дней склад 1 шт |
Еще 2 цен: … 8 952 ₽ | |
9 593 ₽ от 5 шт 5-10 дней склад 1 шт | |
8 952 ₽ от 10 шт 5-10 дней склад 1 шт | |
Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 114мм; Z: ... Далее 45-440.1801Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 114мм; Z: 64мм | 4 319 ₽ от 1 шт 5-10 дней склад 6 шт |
Еще 2 цен: … 3 783 ₽ | |
4 078 ₽ от 5 шт 5-10 дней склад 6 шт | |
3 783 ₽ от 10 шт 5-10 дней склад 6 шт | |
Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 118мм; Z: ... Далее 45-440.2803Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 118мм; Z: 64мм | 12 437 ₽ от 1 шт 5-10 дней склад 2 шт |
Еще 2 цен: … 10 882 ₽ | |
11 662 ₽ от 5 шт 5-10 дней склад 2 шт | |
10 882 ₽ от 10 шт 5-10 дней склад 2 шт | |
Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 158мм; Z: ... Далее 45-450.2803Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 158мм; Z: 64мм | 16 839 ₽ от 1 шт 5-10 дней склад 5 шт |
Еще 2 цен: … 14 737 ₽ | |
15 788 ₽ от 5 шт 5-10 дней склад 5 шт | |
14 737 ₽ от 10 шт 5-10 дней склад 5 шт | |
Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 194мм; Z: ... Далее 45-460.1802Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 194мм; Z: 64мм | 6 440 ₽ от 1 шт 5-10 дней склад 2 шт |
Еще 2 цен: … 5 635 ₽ | |
6 040 ₽ от 5 шт 5-10 дней склад 2 шт | |
5 635 ₽ от 10 шт 5-10 дней склад 2 шт | |
Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 285мм; Z: ... Далее 45-460.2804Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 285мм; Z: 64мм | 22 606 ₽ от 1 шт 5-10 дней склад 2 шт |
21 657 ₽ от 5 шт 5-10 дней склад 2 шт | |
Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 280мм; Z: ... Далее 45-470.1802Корпус: для пультов; IP66,IP67,IP69K; Х: 85мм; Y: 280мм; Z: 64мм | 9 453 ₽ от 1 шт 5-10 дней склад 1 шт |
Еще 2 цен: … 8 271 ₽ | |
8 863 ₽ от 5 шт 5-10 дней склад 1 шт | |
8 271 ₽ от 10 шт 5-10 дней склад 1 шт | |
Монтажный соединитель; пластик; IP66,IP67,IP69K; для корпусов | 5 968 ₽ от 1 шт 5-10 дней склад 2 шт |
5 826 ₽ от 5 шт 5-10 дней склад 2 шт | |
8 Онлайн Компоненты Москва Россия | |
Аксессуар корпуса, класс IP66/IP69K, PA6, светло-серый, Элемент ... Далее JDAE12PA7035Аксессуар корпуса, класс IP66/IP69K, PA6, светло-серый, Элемент вентиляции, Корпусами | 1 629 ₽ от 1 шт 5-12 дней склад 2292 шт |
Еще 5 цен: … 913 ₽ | |
1 241 ₽ от 10 шт 5-12 дней склад 2292 шт | |
1 043 ₽ от 100 шт 5-12 дней склад 2292 шт | |
989 ₽ от 250 шт 5-12 дней склад 2292 шт | |
932 ₽ от 500 шт 5-12 дней склад 2292 шт | |
913 ₽ от 1000 шт 5-12 дней склад 2292 шт | |
Аксессуар корпуса, класс IP66/IP69K, PA6, черный, M12 x 1. ... Далее JDAE12PA/SWАксессуар корпуса, класс IP66/IP69K, PA6, черный, M12 x 1.5, Элемент вентиляции | 1 629 ₽ от 1 шт 5-12 дней склад 1274 шт |
1 241 ₽ от 10 шт 5-12 дней склад 1274 шт | |
1 043 ₽ от 100 шт 5-12 дней склад 1274 шт | |
989 ₽ от 250 шт 5-12 дней склад 1274 шт | |
932 ₽ от 500 шт 5-12 дней склад 1274 шт | |
913 ₽ от 1000 шт 5-12 дней склад 1274 шт | |
... устойчивый, 30В DC IP67, IP69K, диаметр 30мм, увеличение 27мм глубина Далее K30LGRYPQИндикатор, EZ-LIGHT, устойчивый, 30В DC IP67, IP69K, диаметр 30мм, увеличение 27мм глубина | 16 882 ₽ от 1 шт |
Еще 2 цен: … 16 208 ₽ | |
16 544 ₽ от 5 шт | |
16 208 ₽ от 10 шт | |
Еще 153 строки | |
... -NO, Разъем, IP65, IP66, IP67, IP69K Далее XCSRC10M12Дверной выключатель безопасности, Preventa XCS Series, DPST-NO, Разъем, IP65, IP66, IP67, IP69K | 28 608 ₽ от 1 шт 5-12 дней склад 12 шт |
Еще 5 цен: … 25 747 ₽ | |
28 036 ₽ от 5 шт 5-12 дней склад 12 шт | |
27 464 ₽ от 10 шт 5-12 дней склад 12 шт | |
26 890 ₽ от 25 шт 5-12 дней склад 12 шт | |
26 318 ₽ от 50 шт 5-12 дней склад 12 шт | |
25 747 ₽ от 100 шт 5-12 дней склад 12 шт | |
... -NO, Разъем, IP65, IP66, IP67, IP69K Далее XCSRC30M12Дверной выключатель безопасности, Preventa XCS Series, DPST-NO, Разъем, IP65, IP66, IP67, IP69K | 14 025 ₽ от 1 шт |
... -NO, Разъем, IP65, IP66, IP67, IP69K Далее XCSRC31AM12Дверной выключатель безопасности, Preventa XCS Series, DPST-NO, Разъем, IP65, IP66, IP67, IP69K | 19 158 ₽ от 1 шт |
... -NO, Разъем, IP65, IP66, IP67, IP69K Далее XCSRC11AM12Дверной выключатель безопасности, Preventa XCS Series, DPST-NO, Разъем, IP65, IP66, IP67, IP69K | 19 158 ₽ от 1 шт |
Fibre Optic Cable, IP66/IP68/IP69K, 25m, 9µm / 125& ... Далее PXF4055AACFibre Optic Cable, IP66/IP68/IP69K, 25m, 9µm / 125µm, Singlemode, 1 Fibre, LC to LC | 11 382 ₽ от 1 шт |
Еще 2 цен: … 8 219 ₽ | |
9 486 ₽ от 5 шт | |
8 219 ₽ от 10 шт | |
Fibre Optic Cable, IP66/IP68/IP69K, 10m, 9µm / 125& ... Далее PXF4051AABFibre Optic Cable, IP66/IP68/IP69K, 10m, 9µm / 125µm, Singlemode, 1 Fibre, LC to LC | 7 483 ₽ от 1 шт |
Fibre Optic Cable, IP66/IP68/IP69K, 10m, 50µm / 125& ... Далее PXF4055CABFibre Optic Cable, IP66/IP68/IP69K, 10m, 50µm / 125µm, Multimode, 1 Fibre, LC to LC | 12 196 ₽ от 1 шт |
Еще 3 цен: … 11 038 ₽ | |
11 837 ₽ от 5 шт | |
11 478 ₽ от 10 шт | |
11 038 ₽ от 25 шт | |
Fibre Optic Cable, IP66/IP68/IP69K, 25m, 62.5µm / ... Далее PXF4050BACFibre Optic Cable, IP66/IP68/IP69K, 25m, 62.5µm / 125µm, Multimode, 1 Fibre, LC to LC | 10 908 ₽ от 1 шт |
Еще 2 цен: … 10 011 ₽ | |
10 459 ₽ от 5 шт | |
10 011 ₽ от 10 шт | |
Fibre Optic Cable, IP66/IP68/IP69K, 10m, 62.5µm / ... Далее PXF4050BABFibre Optic Cable, IP66/IP68/IP69K, 10m, 62.5µm / 125µm, Multimode, 1 Fibre, LC to LC | 6 570 ₽ от 1 шт |
Еще 3 цен: … 5 798 ₽ | |
6 300 ₽ от 5 шт | |
6 029 ₽ от 10 шт | |
5 798 ₽ от 25 шт | |
Fibre Optic Cable, IP66/IP68/IP69K, 1m, 50µm / 125& ... Далее PXF4053CAAFibre Optic Cable, IP66/IP68/IP69K, 1m, 50µm / 125µm, Multimode, 1 Fibre, LC to LC | 7 924 ₽ от 1 шт |
Еще 2 цен: … 7 456 ₽ | |
7 690 ₽ от 5 шт | |
7 456 ₽ от 10 шт | |
Fibre Optic Cable, IP66/IP68/IP69K, 10m, 50µm / 125& ... Далее PXF4054CABFibre Optic Cable, IP66/IP68/IP69K, 10m, 50µm / 125µm, Multimode, 1 Fibre, LC to LC | 11 854 ₽ от 1 шт |
Еще 3 цен: … 10 728 ₽ | |
11 505 ₽ от 5 шт | |
11 154 ₽ от 10 шт | |
10 728 ₽ от 25 шт | |
Fibre Optic Cable, IP66/IP68/IP69K, 25m, 62.5µm / ... Далее PXF4055BACFibre Optic Cable, IP66/IP68/IP69K, 25m, 62.5µm / 125µm, Multimode, 1 Fibre, LC to LC | 11 027 ₽ от 1 шт 5-12 дней склад 5 шт |
Fibre Optic Cable, IP66/IP68/IP69K, 10m, 62.5µm / ... Далее PXF4055BABFibre Optic Cable, IP66/IP68/IP69K, 10m, 62.5µm / 125µm, Multimode, 1 Fibre, LC to LC | 8 571 ₽ от 1 шт |
Еще 3 цен: … 7 565 ₽ | |
8 221 ₽ от 5 шт | |
7 868 ₽ от 10 шт | |
7 565 ₽ от 25 шт | |
Fibre Optic Cable, IP66/IP68/IP69K, 5m, 62.5µm / ... Далее PXF4055BAAFibre Optic Cable, IP66/IP68/IP69K, 5m, 62.5µm / 125µm, Multimode, 1 Fibre, LC to LC | 6 933 ₽ от 1 шт |
Еще 3 цен: … 6 117 ₽ | |
6 648 ₽ от 5 шт | |
6 363 ₽ от 10 шт | |
6 117 ₽ от 25 шт | |
Fibre Optic Cable, IP66/IP68/IP69K, 25m, 62.5µm / ... Далее PXF4054BACFibre Optic Cable, IP66/IP68/IP69K, 25m, 62.5µm / 125µm, Multimode, 1 Fibre, LC to LC | 18 030 ₽ от 1 шт |
Еще 2 цен: … 16 971 ₽ | |
17 501 ₽ от 5 шт | |
16 971 ₽ от 10 шт | |
Fibre Optic Cable, IP66/IP68/IP69K, 10m, 62.5µm / ... Далее PXF4054BABFibre Optic Cable, IP66/IP68/IP69K, 10m, 62.5µm / 125µm, Multimode, 1 Fibre, LC to LC | 8 332 ₽ от 1 шт |
Еще 3 цен: … 7 352 ₽ | |
7 989 ₽ от 5 шт | |
7 645 ₽ от 10 шт | |
7 352 ₽ от 25 шт | |
Fibre Optic Cable, IP66/IP68/IP69K, 1m, 62.5µm / ... Далее PXF4053BAAFibre Optic Cable, IP66/IP68/IP69K, 1m, 62.5µm / 125µm, Multimode, 1 Fibre, LC to LC | 6 339 ₽ от 1 шт |
Еще 3 цен: … 4 346 ₽ | |
5 252 ₽ от 5 шт | |
4 709 ₽ от 10 шт | |
4 346 ₽ от 25 шт | |
9 Элитан Ижевск Россия Безнал. расчет Филиалы: Москва Санкт-Петербург Екатеринбург Новосибирск | |
3 730 ₽ | |
10 DIP8.RU Москва Россия и страны ТС | |
... , DTM, вилка, мама, PIN 8, IP69K, на провод Далее DTM06-08SAРазъем провод-провод, DTM, вилка, мама, PIN 8, IP69K, на провод | 580 ₽ от 1 шт 42 дня склад 177 шт Внешний |
Еще 7 цен: … 344 ₽ | |
580 ₽ от 1 шт от 1 дня склад 45 шт Москва | |
507 ₽ от 20 шт 42 дня склад 177 шт Внешний | |
507 ₽ от 20 шт от 1 дня склад 45 шт Москва | |
402 ₽ от 100 шт от 1 дня склад 45 шт Москва | |
402 ₽ от 100 шт 42 дня склад 177 шт Внешний | |
344 ₽ от 500 шт 42 дня склад 177 шт Внешний | |
344 ₽ от 500 шт от 1 дня склад 45 шт Москва | |
... , размер 104.27, IP66, IP67, IP69K Далее C7I 24Корпус: для разъемов HDC, размер 104.27, IP66, IP67, IP69K | 4 210 ₽ от 1 шт 42 дня склад 73 шт Внешний |
Еще 7 цен: … 2 732 ₽ | |
4 210 ₽ от 1 шт от 1 дня склад 5 шт Москва | |
3 558 ₽ от 5 шт 42 дня склад 73 шт Внешний | |
3 558 ₽ от 5 шт от 1 дня склад 5 шт Москва | |
3 193 ₽ от 20 шт от 1 дня склад 5 шт Москва | |
3 193 ₽ от 20 шт 42 дня склад 73 шт Внешний | |
2 732 ₽ от 100 шт 42 дня склад 73 шт Внешний | |
2 732 ₽ от 100 шт от 1 дня склад 5 шт Москва | |
... разъемов, размер 77.27, IP66,IP69K Далее CHI 16 LКорпус для прямоугольных разъемов, размер 77.27, IP66,IP69K | 3 230 ₽ от 1 шт 42 дня склад 69 шт Внешний |
Еще 7 цен: … 2 113 ₽ | |
3 230 ₽ от 1 шт от 1 дня склад 3 шт Москва | |
2 752 ₽ от 5 шт 42 дня склад 69 шт Внешний | |
2 752 ₽ от 5 шт от 1 дня склад 3 шт Москва | |
2 456 ₽ от 20 шт от 1 дня склад 3 шт Москва | |
2 456 ₽ от 20 шт 42 дня склад 69 шт Внешний | |
2 113 ₽ от 100 шт 42 дня склад 69 шт Внешний | |
2 113 ₽ от 100 шт от 1 дня склад 3 шт Москва | |
Еще 2 строки | |
... .2, вилка, мама, PIN: 2, IP69K, черный Далее 1-1670916-1Разъем: automotive, MCON 1.2, вилка, мама, PIN: 2, IP69K, черный | 280 ₽ от 1 шт 42 дня склад 119 шт Внешний |
Еще 5 цен: … 152 ₽ | |
280 ₽ от 1 шт от 1 дня склад 5 шт Москва | |
205 ₽ от 50 шт 42 дня склад 119 шт Внешний | |
205 ₽ от 50 шт от 1 дня склад 5 шт Москва | |
152 ₽ от 200 шт 42 дня склад 119 шт Внешний | |
152 ₽ от 200 шт от 1 дня склад 5 шт Москва | |
... ввод, M16, 1,5, IP68, IP69K, Мат-л: полиамид, SKINTOP® Далее 53111510Кабельный ввод, M16, 1,5, IP68, IP69K, Мат-л: полиамид, SKINTOP® | 250 ₽ от 1 шт 42 дня склад 104 шт Внешний |
Еще 7 цен: … 115 ₽ | |
250 ₽ от 1 шт от 1 дня склад 2 шт Москва | |
140 ₽ от 5 шт 42 дня склад 104 шт Внешний | |
140 ₽ от 5 шт от 1 дня склад 2 шт Москва | |
129 ₽ от 25 шт от 1 дня склад 2 шт Москва | |
129 ₽ от 25 шт 42 дня склад 104 шт Внешний | |
115 ₽ от 100 шт 42 дня склад 104 шт Внешний | |
115 ₽ от 100 шт от 1 дня склад 2 шт Москва | |
11 ЭлектроПласт- Екатеринбург Екатеринбург Россия | |
XS2F-E421-J80-E 23 Апр 2024 22:47 CABLE M12 IP69K CABLE 4P 10M HT | запрос 7-14 дней |
XS3F-E421-402-A 23 Апр 2024 22:47 CABLE M8 IP69K CABLE 4P 2M | запрос 7-14 дней |
12 Океан Электроники Санкт-Петербург Россия | |
XS2F-E422-D80-E 23 Апр 2024 22:47 CABLE M12 IP69K CBL 4P ANG 2M HT | запрос 7-14 дней |
XS3F-E422-402-A 23 Апр 2024 22:47 CABLE M8 IP69K CABLE 4P ANG 2M | запрос 7-14 дней |
13 TradeElectronics Москва Россия | |
CONN ADAPT IP69K USB A-5POS CONN | запрос 7-14 дней |
XS2F-E421-D80-F 23 Апр 2024 22:47 CABLE M12 IP69K CABLE 4P 2M | запрос 7-14 дней |
XS2F-E422-G80-F 23 Апр 2024 22:47 CABLE M12 IP69K CABLE 4P ANG 5M | запрос 7-14 дней |
14 ТаймЧипс Санкт-Петербург Россия | |
CONN ADAPT IP69K USB A-B PNL MNT | запрос 7-14 дней |
XS2F-E422-D80-F 23 Апр 2024 22:47 CABLE M12 IP69K CABLE 4P ANG 2M | запрос 7-14 дней |
XS3F-E422-405-A 23 Апр 2024 22:47 CABLE M8 IP69K CABLE 4P ANG 5M | запрос 7-14 дней |
15 ЭлектроПласт Санкт-Петербург Россия | |
E3ZM-B61 5M 23 Апр 2024 22:47 Фотоэлектрические датчики E3ZM IP69K SS Photo | запрос 7-14 дней |
XS2F-E421-L80-E 23 Апр 2024 22:47 CABLE M12 IP69K CABLE 4P 20M HT | запрос 7-14 дней |
16 МосЧип Москва Россия | |
CONN ADAPT IP69K USB B-5POS CONN | запрос 7-14 дней |
XS2F-E421-G80-E 23 Апр 2024 22:47 CABLE M12 IP69K CABLE 4P 5M HT | запрос 7-14 дней |
XS2F-E422-J80-E 23 Апр 2024 22:47 CBL M12 IP69K CBL 4P ANG 10M HT | запрос 7-14 дней |
17 LifeElectronics Санкт-Петербург Россия | |
CONN ADAPT IP69K USB B-A PNL MNT | запрос 7-14 дней |
XS2F-E421-D80-E 23 Апр 2024 22:47 CABLE M12 IP69K CABLE 4P 2M HT | запрос 7-14 дней |
XS2F-E422-G80-E 23 Апр 2024 22:47 CABLE M12 IP69K CBL 4P ANG 5M HT | запрос 7-14 дней |
Еще 1 строка | |
XS3F-E422-410-A 23 Апр 2024 22:47 CABLE M8 IP69K CABLE 4P ANG 10M | запрос 7-14 дней |
18 Триема Воронеж Россия Филиалы: Москва Белгород Курск Липецк Орел Тула | |
Каб.ввод IP68 (IP69K); резьба: PG13 x 40 мм; ... Далее 1100.13.50Каб.ввод IP68 (IP69K); резьба: PG13 x 40 мм; каб. d: 15~8 мм; ... | 2 305 ₽ Доставка: есть Самовывоз: есть на складе |
Каб.ввод IP68 (IP69K); резьба: M20 x 1.5 ... Далее 1100.20.50Каб.ввод IP68 (IP69K); резьба: M20 x 1.5 x 40 мм; каб. d: ... | 2 143 ₽ Доставка: есть Самовывоз: есть на складе |
Каб.ввод IP68 (IP69K); резьба: PG21 x 40 мм; ... Далее 1100.21.50Каб.ввод IP68 (IP69K); резьба: PG21 x 40 мм; каб. d: 20.5~12. ... | 2 915 ₽ Доставка: есть Самовывоз: есть на складе |
Еще 23 строки | |
Каб.ввод IP68 (IP69K); резьба: PG29 x 40 мм; ... Далее 1100.29.50Каб.ввод IP68 (IP69K); резьба: PG29 x 40 мм; каб. d: 27.5~19 ... | 3 950 ₽ Доставка: есть Самовывоз: есть на складе |
Каб.ввод IP68 (IP69K); резьба: M40 x 1.5 ... Далее 1100.40.50Каб.ввод IP68 (IP69K); резьба: M40 x 1.5 x 40 мм; каб. d: ... | 4 487 ₽ Доставка: есть Самовывоз: есть на складе |
Каб.ввод EX IP68 (IP69K); резьба: PG11 x 10 мм; ... Далее EX1100.11.085Каб.ввод EX IP68 (IP69K); резьба: PG11 x 10 мм; каб. d: 8.5~5. ... | 656 ₽ Доставка: есть Самовывоз: есть на складе |
Каб.ввод EX IP68 (IP69K); резьба: PG16 x 10 мм; ... Далее EX1100.16.110Каб.ввод EX IP68 (IP69K); резьба: PG16 x 10 мм; каб. d: 11~8 мм; ... | 774 ₽ Доставка: есть Самовывоз: есть на складе |
Каб.ввод EX IP68 (IP69K); резьба: M20 x 1.5 ... Далее EX1100.20.110Каб.ввод EX IP68 (IP69K); резьба: M20 x 1.5 x 10 мм; каб. d: ... | 752 ₽ Доставка: есть Самовывоз: есть на складе |
Каб.ввод EX IP68 (IP69K); резьба: PG21 x 12 мм; ... Далее EX1100.21.160Каб.ввод EX IP68 (IP69K); резьба: PG21 x 12 мм; каб. d: 16~12.5 ... | 1 105 ₽ Доставка: есть Самовывоз: есть на складе |
Каб.ввод EX IP68 (IP69K); резьба: M25 x 1.5 ... Далее EX1100.25.160Каб.ввод EX IP68 (IP69K); резьба: M25 x 1.5 x 11 мм; каб. d: ... | 1 044 ₽ Доставка: есть Самовывоз: есть на складе |
Каб.ввод EX IP68 (IP69K); резьба: M32 x 1.5 ... Далее EX1100.32.210Каб.ввод EX IP68 (IP69K); резьба: M32 x 1.5 x 13 мм; каб. d: ... | 1 534 ₽ Доставка: есть Самовывоз: есть на складе |
Каб.ввод EX IP68 (IP69K); резьба: PG29 x 12 мм; ... Далее EX1100.29.230Каб.ввод EX IP68 (IP69K); резьба: PG29 x 12 мм; каб. d: 23~19 мм; ... | 1 697 ₽ Доставка: есть Самовывоз: есть на складе |
Каб.ввод EX IP68 (IP69K); резьба: PG36 x 12 мм; ... Далее EX1100.36.260Каб.ввод EX IP68 (IP69K); резьба: PG36 x 12 мм; каб. d: 26~21.5 ... | 2 730 ₽ Доставка: есть Самовывоз: есть на складе |
Каб.ввод EX IP68 (IP69K); резьба: PG36 x 12 мм; ... Далее EX1100.36.305Каб.ввод EX IP68 (IP69K); резьба: PG36 x 12 мм; каб. d: 30.5~26 ... | 2 730 ₽ Доставка: есть Самовывоз: есть на складе |
Каб.ввод EX IP68 (IP69K); резьба: M40 x 1.5 ... Далее EX1100.40.285Каб.ввод EX IP68 (IP69K); резьба: M40 x 1.5 x 13 мм; каб. d: ... | 2 489 ₽ Доставка: есть Самовывоз: есть на складе |
... *1,0. -40 +100С, IP68, IP69K, Ключ=8, H=12, L ... Далее 1100.06.035 ... кабельный ввод компрессионного типа, М6*1,0. -40 +100С, IP68, IP69K, Ключ=8, H=12, L=8, Диапазон кабеля 3,0 ... | 208 ₽ Доставка: есть Самовывоз: есть на складе |
... типа, PG7. -40 +100С, IP68, IP69K, Ключ=15, H=17, L ... Далее 1100.07.065Никелированный латунный кабельный ввод компрессионного типа, PG7. -40 +100С, IP68, IP69K, Ключ=15, H=17, L=10, Диапазон кабеля 5,0~ ... | 259 ₽ Доставка: есть Самовывоз: есть на складе |
... типа, PG7. -40 +100С, IP68, IP69K, Ключ=15, H=17, L ... Далее 1100.07.050Никелированный латунный кабельный ввод компрессионного типа, PG7. -40 +100С, IP68, IP69K, Ключ=15, H=17, L=10, Диапазон кабеля 6,5~ ... | 259 ₽ Доставка: есть Самовывоз: есть на складе |
... *1,5. -40 +100С, IP68, IP69K, Ключ=18, H=20, L ... Далее 1100.17.080 ... кабельный ввод компрессионного типа, М16*1,5. -40 +100С, IP68, IP69K, Ключ=18, H=20, L=10, Диапазон кабеля 6,0 ... | 322 ₽ Доставка: есть Самовывоз: есть на складе |
... *1,5. -40 +100С, IP68, IP69K, Ключ=18, H=20, L ... Далее 1100.17.045 ... кабельный ввод компрессионного типа, М16*1,5. -40 +100С, IP68, IP69K, Ключ=18, H=20, L=10, Диапазон кабеля 4,5 ... | 322 ₽ Доставка: есть Самовывоз: есть на складе |
19 ЭИК Санкт-Петербург Россия | |
AC FAN, IP69K, 176X176X89MM, 115 | 28 906 ₽ от 1 шт 21-42 дня склад 3 шт |
Еще 3 цен: … 23 966 ₽ | |
25 979 ₽ от 10 шт 21-42 дня склад 3 шт | |
25 613 ₽ от 25 шт 21-42 дня склад 3 шт | |
23 966 ₽ от 50 шт 21-42 дня склад 3 шт | |
AC FAN, IP69K, 176X176X89MM, 230 | 28 906 ₽ от 1 шт 21-42 дня склад 4 шт |
25 979 ₽ от 10 шт 21-42 дня склад 4 шт | |
25 613 ₽ от 25 шт 21-42 дня склад 4 шт | |
23 966 ₽ от 50 шт 21-42 дня склад 4 шт | |
AC FAN, IP69K, 176X176X89MM, 115 | 28 906 ₽ от 1 шт 21-42 дня склад 1 шт |
25 979 ₽ от 10 шт 21-42 дня склад 1 шт | |
25 613 ₽ от 25 шт 21-42 дня склад 1 шт | |
23 966 ₽ от 50 шт 21-42 дня склад 1 шт | |
Еще 131 строка | |
CIR BRKR THRM 120A IP69K LIGHTED | 7 797 ₽ от 1 шт 21-42 дня склад 36 шт |
Еще 4 цен: … 6 823 ₽ | |
7 407 ₽ от 5 шт 21-42 дня склад 36 шт | |
7 213 ₽ от 9 шт 21-42 дня склад 36 шт | |
7 018 ₽ от 36 шт 21-42 дня склад 36 шт | |
6 823 ₽ от 72 шт 21-42 дня склад 36 шт | |
CIR BRKR THRM 100A IP69K LIGHTED | 7 797 ₽ от 1 шт 21-42 дня склад 9 шт |
7 407 ₽ от 5 шт 21-42 дня склад 9 шт | |
7 213 ₽ от 9 шт 21-42 дня склад 9 шт | |
7 018 ₽ от 36 шт 21-42 дня склад 9 шт | |
6 823 ₽ от 72 шт 21-42 дня склад 9 шт | |
CIR BRKR THRM 150A IP69K LIGHTED | 7 797 ₽ от 1 шт 21-42 дня склад 9 шт |
CIR BRKR THRM 200A IP69K LIGHTED | 8 721 ₽ от 1 шт 21-42 дня склад 10 шт |
Еще 4 цен: … 7 631 ₽ | |
8 285 ₽ от 5 шт 21-42 дня склад 10 шт | |
8 067 ₽ от 9 шт 21-42 дня склад 10 шт | |
7 849 ₽ от 36 шт 21-42 дня склад 10 шт | |
7 631 ₽ от 72 шт 21-42 дня склад 10 шт | |
SENSOR PROX INDUCT 2MM IP69K CYL | 21 542 ₽ от 1 шт 21-42 дня склад 21 шт |
Еще 2 цен: … 16 754 ₽ | |
17 951 ₽ от 10 шт 21-42 дня склад 21 шт | |
16 754 ₽ от 100 шт 21-42 дня склад 21 шт | |
SENSOR PROX INDUCT 4MM IP69K CYL | 13 664 ₽ от 1 шт 21-42 дня склад 21 шт |
Еще 2 цен: … 10 427 ₽ | |
11 506 ₽ от 10 шт 21-42 дня склад 21 шт | |
10 427 ₽ от 100 шт 21-42 дня склад 21 шт | |
SENSOR PROX INDUCT 8MM IP69K CYL | 14 244 ₽ от 1 шт 21-42 дня склад 13 шт |
Еще 2 цен: … 10 871 ₽ | |
11 995 ₽ от 10 шт 21-42 дня склад 13 шт | |
10 871 ₽ от 100 шт 21-42 дня склад 13 шт | |
SENSOR PROX INDUCT 2MM IP69K CYL | 13 100 ₽ от 1 шт 21-42 дня склад 2 шт |
12 090 ₽ от 5 шт 21-42 дня склад 2 шт | |
Датчик: SENSOR PROX INDUCT 2MM IP69K CYL | 19 622 ₽ от 1 шт 21-42 дня склад 3 шт |
Еще 2 цен: … 14 975 ₽ | |
16 524 ₽ от 10 шт 21-42 дня склад 3 шт | |
14 975 ₽ от 100 шт 21-42 дня склад 3 шт | |
SENSOR PROX INDUCT 8MM IP69K CYL | 18 066 ₽ от 1 шт 21-42 дня склад 3 шт |
Еще 2 цен: … 13 787 ₽ | |
15 213 ₽ от 10 шт 21-42 дня склад 3 шт | |
13 787 ₽ от 100 шт 21-42 дня склад 3 шт | |
SENSOR PROX INDUCT 8MM IP69K CYL | 18 066 ₽ от 1 шт 21-42 дня склад 5 шт |
15 213 ₽ от 10 шт 21-42 дня склад 5 шт | |
13 787 ₽ от 100 шт 21-42 дня склад 5 шт | |
SENSOR PROX INDUCT 8MM IP69K CYL | 14 244 ₽ от 1 шт 21-42 дня склад 10 шт |
11 995 ₽ от 10 шт 21-42 дня склад 10 шт | |
10 871 ₽ от 100 шт 21-42 дня склад 10 шт | |
Датчик: SENSOR PROX INDUCT 8MM IP69K CYL | 19 622 ₽ от 1 шт 21-42 дня склад 1 шт |
Еще 3 цен: … 14 975 ₽ | |
16 524 ₽ от 10 шт 21-42 дня склад 1 шт | |
15 492 ₽ от 25 шт 21-42 дня склад 1 шт | |
14 975 ₽ от 100 шт 21-42 дня склад 1 шт | |
SENSOR PROX INDUCT 2MM IP69K CYL | 19 622 ₽ от 1 шт 21-42 дня склад 10 шт |
16 524 ₽ от 10 шт 21-42 дня склад 10 шт | |
14 975 ₽ от 100 шт 21-42 дня склад 10 шт | |
SENSOR PROX INDUCT 4MM IP69K CYL | 12 131 ₽ от 1 шт 21-42 дня склад 7 шт |
11 198 ₽ от 5 шт 21-42 дня склад 7 шт | |
Датчик: SENSOR PROX INDUCT 4MM IP69K CYL | 14 560 ₽ от 1 шт 21-42 дня склад 7 шт |
Еще 2 цен: … 11 111 ₽ | |
12 261 ₽ от 10 шт 21-42 дня склад 7 шт | |
11 111 ₽ от 100 шт 21-42 дня склад 7 шт | |
20 Оптулс Москва Россия | |
3240874 WP-G HF IP69K PG7 BK Резьбовые элементы Phoenix ... Далее PHC-3240874 PHOENIX CONTACT3240874 WP-G HF IP69K PG7 BK Резьбовые элементы Phoenix Contact | 465 ₽ Розница, Скидки для Дилеров - |
3240881 WP-G HF IP69K M10 BK Резьбовые элементы Phoenix ... Далее PHC-3240881 PHOENIX CONTACT3240881 WP-G HF IP69K M10 BK Резьбовые элементы Phoenix Contact | 465 ₽ Розница, Скидки для Дилеров - |
3240875 WP-G HF IP69K PG9 BK Резьбовые элементы Phoenix ... Далее PHC-3240875 PHOENIX CONTACT3240875 WP-G HF IP69K PG9 BK Резьбовые элементы Phoenix Contact | 483 ₽ Розница, Скидки для Дилеров - |
Еще 38 строк | |
3240882 WP-G HF IP69K M12 BK Резьбовые элементы Phoenix ... Далее PHC-3240882 PHOENIX CONTACT3240882 WP-G HF IP69K M12 BK Резьбовые элементы Phoenix Contact | 483 ₽ Розница, Скидки для Дилеров - |
3240883 WP-G HF IP69K M16 BK Резьбовые элементы Phoenix ... Далее PHC-3240883 PHOENIX CONTACT3240883 WP-G HF IP69K M16 BK Резьбовые элементы Phoenix Contact | 488 ₽ Розница, Скидки для Дилеров - |
3240876 WP-G HF IP69K PG11 BK Резьбовые элементы Phoenix ... Далее PHC-3240876 PHOENIX CONTACT3240876 WP-G HF IP69K PG11 BK Резьбовые элементы Phoenix Contact | 488 ₽ Розница, Скидки для Дилеров - |
3240884 WP-G HF IP69K M20 BK Резьбовые элементы Phoenix ... Далее PHC-3240884 PHOENIX CONTACT3240884 WP-G HF IP69K M20 BK Резьбовые элементы Phoenix Contact | 510 ₽ Розница, Скидки для Дилеров - |
3240877 WP-G HF IP69K PG16 BK Резьбовые элементы Phoenix ... Далее PHC-3240877 PHOENIX CONTACT3240877 WP-G HF IP69K PG16 BK Резьбовые элементы Phoenix Contact | 510 ₽ Розница, Скидки для Дилеров - |
3240885 WP-G HF IP69K M25 BK Резьбовые элементы Phoenix ... Далее PHC-3240885 PHOENIX CONTACT3240885 WP-G HF IP69K M25 BK Резьбовые элементы Phoenix Contact | 869 ₽ Розница, Скидки для Дилеров - |
3240902 WP-GA HF IP69K PG7 BK Резьбовые элементы Phoenix ... Далее PHC-3240902 PHOENIX CONTACT3240902 WP-GA HF IP69K PG7 BK Резьбовые элементы Phoenix Contact | 840 ₽ Розница, Скидки для Дилеров - |
3240909 WP-GA HF IP69K M10 BK Резьбовые элементы Phoenix ... Далее PHC-3240909 PHOENIX CONTACT3240909 WP-GA HF IP69K M10 BK Резьбовые элементы Phoenix Contact | 840 ₽ Розница, Скидки для Дилеров - |
3240910 WP-GA HF IP69K M12 BK Резьбовые элементы Phoenix ... Далее PHC-3240910 PHOENIX CONTACT3240910 WP-GA HF IP69K M12 BK Резьбовые элементы Phoenix Contact | 880 ₽ Розница, Скидки для Дилеров - |
3240903 WP-GA HF IP69K PG9 BK Резьбовые элементы Phoenix ... Далее PHC-3240903 PHOENIX CONTACT3240903 WP-GA HF IP69K PG9 BK Резьбовые элементы Phoenix Contact | 880 ₽ Розница, Скидки для Дилеров - |
3240878 WP-G HF IP69K PG21 BK Резьбовые элементы Phoenix ... Далее PHC-3240878 PHOENIX CONTACT3240878 WP-G HF IP69K PG21 BK Резьбовые элементы Phoenix Contact | 902 ₽ Розница, Скидки для Дилеров - |
3240911 WP-GA HF IP69K M16 BK Резьбовые элементы Phoenix ... Далее PHC-3240911 PHOENIX CONTACT3240911 WP-GA HF IP69K M16 BK Резьбовые элементы Phoenix Contact | 912 ₽ Розница, Скидки для Дилеров - |
3240904 WP-GA HF IP69K PG11 BK Резьбовые элементы Phoenix ... Далее PHC-3240904 PHOENIX CONTACT3240904 WP-GA HF IP69K PG11 BK Резьбовые элементы Phoenix Contact | 912 ₽ Розница, Скидки для Дилеров - |
3240905 WP-GA HF IP69K PG16 BK Резьбовые элементы Phoenix ... Далее PHC-3240905 PHOENIX CONTACT3240905 WP-GA HF IP69K PG16 BK Резьбовые элементы Phoenix Contact | 941 ₽ Розница, Скидки для Дилеров - |
3240912 WP-GA HF IP69K M20 BK Резьбовые элементы Phoenix ... Далее PHC-3240912 PHOENIX CONTACT3240912 WP-GA HF IP69K M20 BK Резьбовые элементы Phoenix Contact | 1 009 ₽ Розница, Скидки для Дилеров - |
3240886 WP-G HF IP69K M32 BK Резьбовые элементы Phoenix ... Далее PHC-3240886 PHOENIX CONTACT3240886 WP-G HF IP69K M32 BK Резьбовые элементы Phoenix Contact | 1 138 ₽ Розница, Скидки для Дилеров - |
3240879 WP-G HF IP69K PG29 BK Резьбовые элементы Phoenix ... Далее PHC-3240879 PHOENIX CONTACT3240879 WP-G HF IP69K PG29 BK Резьбовые элементы Phoenix Contact | 1 214 ₽ Розница, Скидки для Дилеров - |
21 Стандарт СИЗ Москва Россия Только юр.лица Безнал. расчет Заказ от 5000 руб. Строка от 400 руб. | |
... шт. Каб.ввод EX IP68 (IP69K); резьба: M32 x 1.5 ... Далее EX1100.32.170Кабельный ввод, 1 шт. Каб.ввод EX IP68 (IP69K); резьба: M32 x 1.5 x 13 мм; каб. d: ... | 540 ₽ от 5000 ₽ |
... ввод Progress® IP68 (IP69K) с цельным коротким уплотнением; резьба ... Далее 1100.32.255Кабельный ввод, 1 шт.. Каб.ввод Progress® IP68 (IP69K) с цельным коротким уплотнением; резьба длинная: M32 x 1.5 ... | 368 ₽ от 5000 ₽ |
... ввод Progress® IP68 (IP69K) с цельным коротким уплотнением; резьба ... Далее 1100.25.125Кабельный ввод, 1 шт.. Каб.ввод Progress® IP68 (IP69K) с цельным коротким уплотнением; резьба длинная: M25 x 1.5 ... | 245 ₽ от 5000 ₽ |
Еще 47 строк | |
... ввод Progress® IP68 (IP69K) с цельным коротким уплотнением; резьба ... Далее 1100.20.110Кабельный ввод, 1 шт.. Каб.ввод Progress® IP68 (IP69K) с цельным коротким уплотнением; резьба длинная: M20 x 1.5 ... | 145 ₽ от 5000 ₽ |
... ввод Progress® IP68 (IP69K) с цельным коротким уплотнением; резьба ... Далее 1100.25.205Кабельный ввод, 1 шт.. Каб.ввод Progress® IP68 (IP69K) с цельным коротким уплотнением; резьба длинная: M25 x 1.5 ... | 245 ₽ от 5000 ₽ |
... ввод Progress® IP68 (IP69K) с цельным коротким уплотнением; резьба ... Далее 1100.32.170Кабельный ввод, 1 шт.. Каб.ввод Progress® IP68 (IP69K) с цельным коротким уплотнением; резьба длинная: M32 x 1.5 ... | 368 ₽ от 5000 ₽ |
... e II, ATEX 1022X, IP68 (IP69K); резьба: M40 x 1.5 ... Далее EX1700.40.36.285 ... , 1 шт. Каб.ввод Ex e II, ATEX 1022X, IP68 (IP69K); резьба: M40 x 1.5 x 8 мм; каб. d ... | 1 917 ₽ от 5000 ₽ |
... e II, ATEX 1022X, IP68 (IP69K); резьба: M32 x 1.5 ... Далее EX1700.32.27.210 ... , 1 шт. Каб.ввод Ex e II, ATEX 1022X, IP68 (IP69K); резьба: M32 x 1.5 x 8 мм; каб. d ... | 1 464 ₽ от 5000 ₽ |
... e II, ATEX 1022X, IP68 (IP69K); резьба: M25 x 1.5 ... Далее EX1700.25.27.205 ... , 1 шт. Каб.ввод Ex e II, ATEX 1022X, IP68 (IP69K); резьба: M25 x 1.5 x 7 мм; каб. d ... | 767 ₽ от 5000 ₽ |
... e II, ATEX 1022X, IP68 (IP69K); резьба: M20 x 1.5 ... Далее EX1700.20.21.150 ... , 1 шт. Каб.ввод Ex e II, ATEX 1022X, IP68 (IP69K); резьба: M20 x 1.5 x 6 мм; каб. d ... | 616 ₽ от 5000 ₽ |
... e II, ATEX 1022X, IP68 (IP69K); резьба: M20 x 1.5 ... Далее EX1700.20.21.110 ... , 1 шт. Каб.ввод Ex e II, ATEX 1022X, IP68 (IP69K); резьба: M20 x 1.5 x 6 мм; каб. d ... | 616 ₽ от 5000 ₽ |
... e II, ATEX 1022X, IP68 (IP69K); резьба: M20 x 1.5 ... Далее EX1700.20.21.080 ... , 1 шт. Каб.ввод Ex e II, ATEX 1022X, IP68 (IP69K); резьба: M20 x 1.5 x 6 мм; каб. d ... | 616 ₽ от 5000 ₽ |
... e II, ATEX 1022X, IP68 (IP69K); резьба: M16 x 1.5 ... Далее EX1700.17.14.105 ... , 1 шт. Каб.ввод Ex e II, ATEX 1022X, IP68 (IP69K); резьба: M16 x 1.5 x 5 мм; каб. d ... | 487 ₽ от 5000 ₽ |
... e II, ATEX 1022X, IP68 (IP69K); резьба: M16 x 1.5 ... Далее EX1700.17.14.080 ... , 1 шт. Каб.ввод Ex e II, ATEX 1022X, IP68 (IP69K); резьба: M16 x 1.5 x 5 мм; каб. d ... | 487 ₽ от 5000 ₽ |
... *1,5. -40 +200С, IP68, IP69K, Ключ=24, H=23, L ... Далее 1000.20.92 ... кабельный ввод, уплотнитель FPM, М20*1,5. -40 +200С, IP68, IP69K, Ключ=24, H=23, L=6, Диапазон кабеля 8,0 ... | 371 ₽ от 5000 ₽ |
... *1,5. -40 +100С, IP68, IP69K, Ключ=24, H=21, L ... Далее 1100.20.080 ... кабельный ввод компрессионного типа, М20*1,5. -40 +100С, IP68, IP69K, Ключ=24, H=21, L=10, Диапазон кабеля 6,0 ... | 145 ₽ от 5000 ₽ |
... *1,5. -40 +100С, IP68, IP69K, Ключ=24, H=23, L ... Далее 1100.20.150 ... кабельный ввод компрессионного типа, М20*1,5. -40 +100С, IP68, IP69K, Ключ=24, H=23, L=10, Диапазон кабеля 11,0 ... | 145 ₽ от 5000 ₽ |
... *1,5. -40 +100С, IP68, IP69K, Ключ=18, H=20, L ... Далее 1100.17.045 ... кабельный ввод компрессионного типа, М16*1,5. -40 +100С, IP68, IP69K, Ключ=18, H=20, L=10, Диапазон кабеля 4,5 ... | 113 ₽ от 5000 ₽ |
... *1,5. -40 +100С, IP68, IP69K, Ключ=18, H=20, L ... Далее 1100.17.080 ... кабельный ввод компрессионного типа, М16*1,5. -40 +100С, IP68, IP69K, Ключ=18, H=20, L=10, Диапазон кабеля 6,0 ... | 113 ₽ от 5000 ₽ |
... *1,5. -40 +100С, IP68, IP69K, Ключ=15, H=17, L ... Далее 1100.12.080 ... кабельный ввод компрессионного типа, М12*1,5. -40 +100С, IP68, IP69K, Ключ=15, H=17, L=10, Диапазон кабеля 6,5 ... | 87.6 ₽ от 5000 ₽ |
22 ЭКиТ Москва Россия Только юр.лица Безнал. расчет Филиалы: Санкт-Петербург Ростов-на-Дону Челябинск | |
Каб.ввод IP68 (IP69K); резьба: PG13 x 40 мм; ... Далее 1100.13.50Каб.ввод IP68 (IP69K); резьба: PG13 x 40 мм; каб. d: 15~8 мм; ... | 1 773 ₽ склад 8 шт |
Каб.ввод IP68 (IP69K); резьба: M20 x 1.5 ... Далее 1100.20.50Каб.ввод IP68 (IP69K); резьба: M20 x 1.5 x 40 мм; каб. d: ... | 1 647 ₽ склад 1 шт |
Каб.ввод IP68 (IP69K); резьба: PG21 x 40 мм; ... Далее 1100.21.50Каб.ввод IP68 (IP69K); резьба: PG21 x 40 мм; каб. d: 20.5~12. ... | 2 242 ₽ склад 2 шт |
Еще 16 строк | |
Каб.ввод IP68 (IP69K); резьба: M40 x 1.5 ... Далее 1100.40.50Каб.ввод IP68 (IP69K); резьба: M40 x 1.5 x 40 мм; каб. d: ... | 3 450 ₽ склад 6 шт |
Каб.ввод EX IP68 (IP69K); резьба: PG11 x 10 мм; ... Далее EX1100.11.085Каб.ввод EX IP68 (IP69K); резьба: PG11 x 10 мм; каб. d: 8.5~5. ... | 504 ₽ склад 50 шт |
Каб.ввод EX IP68 (IP69K); резьба: PG16 x 10 мм; ... Далее EX1100.16.110Каб.ввод EX IP68 (IP69K); резьба: PG16 x 10 мм; каб. d: 11~8 мм; ... | 594 ₽ склад 169 шт |
Каб.ввод EX IP68 (IP69K); резьба: M20 x 1.5 ... Далее EX1100.20.110Каб.ввод EX IP68 (IP69K); резьба: M20 x 1.5 x 10 мм; каб. d: ... | 577 ₽ склад 3 шт |
Каб.ввод EX IP68 (IP69K); резьба: PG21 x 12 мм; ... Далее EX1100.21.160Каб.ввод EX IP68 (IP69K); резьба: PG21 x 12 мм; каб. d: 16~12.5 ... | 850 ₽ склад 20 шт |
Каб.ввод EX IP68 (IP69K); резьба: M25 x 1.5 ... Далее EX1100.25.160Каб.ввод EX IP68 (IP69K); резьба: M25 x 1.5 x 11 мм; каб. d: ... | 802 ₽ склад 6 шт |
Каб.ввод EX IP68 (IP69K); резьба: PG36 x 12 мм; ... Далее EX1100.36.260Каб.ввод EX IP68 (IP69K); резьба: PG36 x 12 мм; каб. d: 26~21.5 ... | 2 099 ₽ склад 10 шт |
Каб.ввод EX IP68 (IP69K); резьба: PG36 x 12 мм; ... Далее EX1100.36.305Каб.ввод EX IP68 (IP69K); резьба: PG36 x 12 мм; каб. d: 30.5~26 ... | 2 099 ₽ склад 10 шт |
Каб.ввод EX IP68 (IP69K); резьба: M40 x 1.5 ... Далее EX1100.40.285Каб.ввод EX IP68 (IP69K); резьба: M40 x 1.5 x 13 мм; каб. d: ... | 1 913 ₽ склад 7 шт |
... *1,0. -40 +100С, IP68, IP69K, Ключ=8, H=12, L ... Далее 1100.06.035 ... кабельный ввод компрессионного типа, М6*1,0. -40 +100С, IP68, IP69K, Ключ=8, H=12, L=8, Диапазон кабеля 3,0 ... | 160 ₽ склад 37 шт |
... типа, PG7. -40 +100С, IP68, IP69K, Ключ=15, H=17, L ... Далее 1100.07.065Никелированный латунный кабельный ввод компрессионного типа, PG7. -40 +100С, IP68, IP69K, Ключ=15, H=17, L=10, Диапазон кабеля 5,0~ ... | 199 ₽ склад 78 шт |
... типа, PG7. -40 +100С, IP68, IP69K, Ключ=15, H=17, L ... Далее 1100.07.050Никелированный латунный кабельный ввод компрессионного типа, PG7. -40 +100С, IP68, IP69K, Ключ=15, H=17, L=10, Диапазон кабеля 6,5~ ... | 199 ₽ склад 39 шт |
... *1,5. -40 +100С, IP68, IP69K, Ключ=18, H=20, L ... Далее 1100.17.080 ... кабельный ввод компрессионного типа, М16*1,5. -40 +100С, IP68, IP69K, Ключ=18, H=20, L=10, Диапазон кабеля 6,0 ... | 246 ₽ склад 66 шт |
... *1,5. -40 +100С, IP68, IP69K, Ключ=18, H=20, L ... Далее 1100.17.045 ... кабельный ввод компрессионного типа, М16*1,5. -40 +100С, IP68, IP69K, Ключ=18, H=20, L=10, Диапазон кабеля 4,5 ... | 246 ₽ склад 98 шт |
... *1,5. -40 +100С, IP68, IP69K, Ключ=24, H=21, L ... Далее 1100.20.080 ... кабельный ввод компрессионного типа, М20*1,5. -40 +100С, IP68, IP69K, Ключ=24, H=21, L=10, Диапазон кабеля 6,0 ... | 318 ₽ склад 7 шт |
Каб.ввод Progress® IP68 (IP69K) с цельным коротким уплотнением; ... Далее 1100.32.170Каб.ввод Progress® IP68 (IP69K) с цельным коротким уплотнением; резьба длинная: M32 x 1.5 ... | 806 ₽ склад 7 шт |
23 Зенер Москва Россия и страны ТС | |
CBL M12-4 R/A NPN LED 2M IP69K | запрос 5-15 дней |
CBL M12-4 R/A NPN LED 5M IP69K | запрос 5-15 дней |
CBL M12-4 R/A PNP LED 2M IP69K | запрос 5-15 дней |
Еще 40 строк | |
CBL M12-4 R/A PNP LED 5M IP69K | запрос 5-15 дней |
CBL M12-4 STR NPN LED 2M IP69K | запрос 5-15 дней |
CBL M12-4 STR NPN LED 5M IP69K | запрос 5-15 дней |
CBL M12-4 STR PNP LED 2M IP69K | запрос 5-15 дней |
CBL M12-4 STR PNP LED 5M IP69K | запрос 5-15 дней |
CBL M8 10M R/A LED IP69K | запрос 5-15 дней |
CBL M8 2M R/A LED IP69K | запрос 5-15 дней |
CBL M8 5M R/A LED IP69K | запрос 5-15 дней |
CBL M8 10M STR IP69K | запрос 5-15 дней |
CBL M8 2M STR IP69K | запрос 5-15 дней |
CBL M8 5M STR IP69K | запрос 5-15 дней |
CABLE M12 IP69K CABLE 4P 2M HT | 6 757 ₽ от 1 шт |
Еще 5 цен: … 5 445 ₽ | |
6 558 ₽ от 5 шт | |
6 360 ₽ от 10 шт | |
6 160 ₽ от 25 шт | |
5 763 ₽ от 50 шт | |
5 445 ₽ от 100 шт | |
CABLE M12 IP69K CABLE 4P 2M | запрос 5-15 дней склад 14 шт |
CABLE M12 IP69K CABLE 4P 5M HT | запрос 5-15 дней |
CABLE M12 IP69K CABLE 4P 5M | 4 763 ₽ от 1 шт 5-15 дней склад 10 шт |
Еще 5 цен: … 3 726 ₽ | |
4 371 ₽ от 10 шт 5-15 дней склад 10 шт | |
4 203 ₽ от 25 шт 5-15 дней склад 10 шт | |
4 063 ₽ от 50 шт 5-15 дней склад 10 шт | |
3 838 ₽ от 100 шт 5-15 дней склад 10 шт | |
3 726 ₽ от 250 шт 5-15 дней склад 10 шт | |
CABLE M12 IP69K CABLE 4P 10M HT | 18 562 ₽ от 1 шт |
Еще 4 цен: … 16 458 ₽ | |
18 333 ₽ от 5 шт | |
17 942 ₽ от 10 шт | |
16 704 ₽ от 25 шт | |
16 458 ₽ от 50 шт | |
CABLE M12 IP69K CABLE 4P 15M HT | запрос 5-15 дней |
Искать "IP69K" в других поисковых системах: Везде-РадиоЛоцман DataSheet.ru Google
USD | 93.2519 |
EUR | 99.3648 |
