Datasheet NTE156 - NTE Electronics Даташит STANDARD диод, 2 А, 1 кВ, DO-15 — Даташит
NTE Electronics NTE156
Наименование модели: NTE156
Силовой диод, NTE ELECTRONICS NTE156A Standard Power Diode, 1kV, 3A, Single, 1.2V, 200A
NTE156A
NTE Electronics
357 ₽
Элитан
NTE156
NTE Electronics
2 172 ₽
МосЧип
NTE-156A
ТаймЧипс
NTE-156
Производитель: NTE Electronics
Описание: STANDARD диод, 2 А, 1 кВ, DO-15
data sheetСкачать Data Sheet
NTE156 General Purpose Silicon Rectifier
Features: D Low Leakage D Low Forward Voltage Drop D High Current Capability Maximum Ratings: (TA = +25°C unless otherwise specified.
Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%) Peak Repetitive Reverse Voltage, VRRM . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1000V DC Blocking Voltage, VR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1000V RMS Reverse Voltage, VR(RMS) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 700V Average Rectified Forward Current. IO (.375" (9.5mm) lead length, TA = +50°C) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2A Non­Repetitive Peak Surge Current, IFSM (8.3ms single half sine­wave superimposed on rated load) . . . . . . . . . . . . . . . . . . . .
  • Diode Type: Standard Recovery
  • Repetitive Reverse Voltage Vrrm Max: 1 кВ
  • Forward Current If(AV): 2 А
  • Forward Voltage VF Max: 1.1 В
  • Forward Surge Current Ifsm Max: 70 А
На английском языке: Datasheet NTE156 - NTE Electronics STANDARD DIODE, 2 A, 1 kV, DO-15
