Datasheet NTE5801 - NTE Electronics Даташит STANDARD диод, 3 А, 100 В, DO-27 — Даташит
Наименование модели: NTE5801
![]() 18 предложений от 12 поставщиков Силовой диод, Rectifier; 3A IF; 1.2V (Max.); 100V; 200A Ifms; 500uA (Max.) IR; Axial Leaded | |||
NTE580-1 NTE Electronics | 1.54 ₽ | ||
NTE5801 NTE Electronics | 23 ₽ | ||
NTE5801 | по запросу | ||
NTE580-1 | по запросу |
Производитель: NTE Electronics
Описание: STANDARD диод, 3 А, 100 В, DO-27
NTE5800 thru NTE5809 Axial Lead Standard Recovery Silicon Rectifiers, 3 Amp, DO27
Description: The NTE5800 through NTE5809 silicon rectifiers are designed for use in power supplies and other applications having need of a device with the following features: D High Current to Small Size D High Surge Current Capability D Low Forward Voltage Drop Absolute Maximum Ratings: (Note 1) Peak Repetitive Reverse Voltage, VRRM Working Peak Reverse Voltage, VRWM DC Blocking Voltage, VR NTE5800 .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 50V NTE5801 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 100V NTE5802 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 200V NTE5803 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
- Diode Type: Standard Recovery
- Repetitive Reverse Voltage Vrrm Max: 100 В
- Forward Current If(AV): 3 А
- Forward Voltage VF Max: 1.2 В
- Forward Surge Current Ifsm Max: 200 А
