Datasheet NTE5809 - NTE Electronics Даташит STANDARD диод, 3 А, 1 кВ, DO-27 — Даташит
NTE Electronics NTE5809
Наименование модели: NTE5809
15 предложений от 11 поставщиков
Силовой диод, NTE ELECTRONICS NTE5809 Standard Power Diode, 1.2kV, 3A, Single, 1.4V, 200A
NTE5809
NTE Electronics
68 ₽
NTE5809
от 84 ₽
NTE5809
101 ₽
NTE5809
Производитель: NTE Electronics
Описание: STANDARD диод, 3 А, 1 кВ, DO-27
data sheetСкачать Data Sheet
NTE5800 thru NTE5809 Axial Lead Standard Recovery Silicon Rectifiers, 3 Amp, DO27
Description: The NTE5800 through NTE5809 silicon rectifiers are designed for use in power supplies and other applications having need of a device with the following features: D High Current to Small Size D High Surge Current Capability D Low Forward Voltage Drop Absolute Maximum Ratings: (Note 1) Peak Repetitive Reverse Voltage, VRRM Working Peak Reverse Voltage, VRWM DC Blocking Voltage, VR NTE5800 .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 50V NTE5801 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 100V NTE5802 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 200V NTE5803 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
  • Diode Type: Standard Recovery
  • Repetitive Reverse Voltage Vrrm Max: 1 кВ
  • Forward Current If(AV): 3 А
  • Forward Voltage VF Max: 1.2 В
  • Forward Surge Current Ifsm Max: 200 А
На английском языке: Datasheet NTE5809 - NTE Electronics STANDARD DIODE, 3 A, 1 kV, DO-27
