Datasheet NTE6002 - NTE Electronics Даташит STANDARD диод, 40 А, 1 кВ, DO-5 — Даташит
NTE Electronics NTE6002
Наименование модели: NTE6002
Silicon Complementary Transistors High Power Audio, Disk Head Positioner for Linear Applications
NTE6002
NTE Electronics
4 787 ₽
Hi-Tech Circuit Group
NTE6002
NTE6002
NTE Electronics
ТаймЧипс
NTE6002/DSI
NTE Electronics
Производитель: NTE Electronics
Описание: STANDARD диод, 40 А, 1 кВ, DO-5
data sheetСкачать Data Sheet
NTE5906, NTE5907, NTE5980 thru NTE6005 Silicon Power Rectifier Diode, 40 Amp, DO5
Features: D High Surge Current Capability D High Voltage Available D Designed for a Wide Range of Applications D Available in Anode-to-Case or Cathode-to-Case Style Ratings and Characteristics: Average Forward Current (TC = +140°C Max), IF(AV) .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 40A Maximum Forward Surge Current, IFSM 50Hz . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 480A 60Hz . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 500A Fusing Current, I2t 50Hz . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1150A2s 60Hz . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
  • Diode Type: Standard Recovery
  • Repetitive Reverse Voltage Vrrm Max: 1 кВ
  • Forward Current If(AV): 40 А
  • Forward Voltage VF Max: 1.3 В
  • Forward Surge Current Ifsm Max: 500 А
На английском языке: Datasheet NTE6002 - NTE Electronics STANDARD DIODE, 40 A, 1 kV, DO-5
