Datasheet NTE6070 - NTE Electronics Даташит STANDARD диод, 85 А, 1.6 кВ, DO-5 — Даташит
NTE Electronics NTE6070
Наименование модели: NTE6070
10 предложений от 6 поставщиков
Силовой диод, Diode 1.6kV 85A 2Pin DO-5
NTE6070
от 523 ₽
NTE6070
NTE Electronics
1 905 ₽
NTE6070
NTE Electronics
Hi-Tech Circuit Group
NTE6070
Производитель: NTE Electronics
Описание: STANDARD диод, 85 А, 1.6 кВ, DO-5
data sheetСкачать Data Sheet
NTE6070 thru NTE6079 Industrial Silicon Rectifiers
85 Amp, DO5
Description: The NTE6070 thru NTE6079 series of 85 Amp power rectifiers are stud mounted DO5 packages.
Because the silicon junction is carefully fitted within a glass to-metal hermetically sealed case, reliable operation is assured, even with extreme humidity and under other severe environmental conditions. A double diffused, passivated junction technique is utilized to provide stable uniform electrical characteristics. Inherent in their design are very low leakage currents and excellent surge handling capability. These devices are available in standard and reverse polarities and in voltage ratings from 200 to 1600 volts PRV. NTE silicon power rectifiers are ideal for a broad range of commercial and military uses including power supplies, ultrasonic systems, inverters, welders, emergency generators, battery chargers, DC motors, and motor controls. Electrical Ratings: Peak Reverse Voltage, PRV NTE6074, NTE6075* . . . . . . .
  • Diode Type: Standard Recovery
  • Repetitive Reverse Voltage Vrrm Max: 1.6 В
  • Forward Current If(AV): 85 А
  • Forward Voltage VF Max: 1.15 В
  • Forward Surge Current Ifsm Max: 1.5 кА
На английском языке: Datasheet NTE6070 - NTE Electronics STANDARD DIODE, 85 A, 1.6 kV, DO-5
