Datasheet NTE6079 - NTE Electronics Даташит STANDARD диод, 85 А, 1.2 кВ, DO-5 — Даташит
Наименование модели: NTE6079
Купить NTE6079 на РадиоЛоцман.Цены — от 1 191 до 7 650 ₽13 предложений от 9 поставщиков Диоды - Одиночные Стабилитроны | |||
| NTE6079 | от 1 432 ₽ | ||
| NTE6079 NTE Electronics | 2 840 ₽ | ||
| NTE6079 NTE Electronics | 7 650 ₽ | ||
| NTE6079 | по запросу | ||
Производитель: NTE Electronics
Описание: STANDARD диод, 85 А, 1.2 кВ, DO-5
NTE6070 thru NTE6079 Industrial Silicon Rectifiers
85 Amp, DO5
Description: The NTE6070 thru NTE6079 series of 85 Amp power rectifiers are stud mounted DO5 packages.
Because the silicon junction is carefully fitted within a glass to-metal hermetically sealed case, reliable operation is assured, even with extreme humidity and under other severe environmental conditions. A double diffused, passivated junction technique is utilized to provide stable uniform electrical characteristics. Inherent in their design are very low leakage currents and excellent surge handling capability. These devices are available in standard and reverse polarities and in voltage ratings from 200 to 1600 volts PRV. NTE silicon power rectifiers are ideal for a broad range of commercial and military uses including power supplies, ultrasonic systems, inverters, welders, emergency generators, battery chargers, DC motors, and motor controls. Electrical Ratings: Peak Reverse Voltage, PRV NTE6074, NTE6075* . . . . . . .
- Diode Type: Standard Recovery
- Repetitive Reverse Voltage Vrrm Max: 1.2 кВ
- Forward Current If(AV): 85 А
- Forward Voltage VF Max: 1.15 В
- Forward Surge Current Ifsm Max: 1.5 кА
