Datasheet NTE6155 - NTE Electronics Даташит STANDARD диод, 150 А, 400 В, DO-8 — Даташит
Наименование модели: NTE6155
Купить NTE6155 на РадиоЛоцман.Цены — от 587 до 10 240 ₽14 предложений от 10 поставщиков Integrated Circuit Voltage Stabilizer for Electronic Tuner | |||
| NTE6155 NTE Electronics | 1 618 ₽ | ||
| NTE6155 NTE Electronics | 10 240 ₽ | ||
| NTE6155. NTE Electronics | по запросу | ||
Производитель: NTE Electronics
Описание: STANDARD диод, 150 А, 400 В, DO-8
NTE6154 thru NTE6165
Silicon Industrial Rectifier 150 Amp, DO8
Description: The NTE6154 through NTE6165 power rectifiers are stud mounted DO8 type packages.
Because the silicon junction is carefully fitted within a glass-to-metal hermetically sealed case, reliable operation is assured even with extreme humidity and under other severe environmental conditions. These power rectifiers are ideal for a broad range of commercial uses including power supplies, ultrasonic systems, inverters, welders, emergency generators, battery chargers, DC motors, and motor controls. Features: D Standard DO8 Type Package D Available in Standard (Cathode to Case) and Reverse (Anode to Case) Polarity D Recommended Stud Mounting Torque: 120in. lbs. Lubricated. Electrical Ratings: Peak Reverse Voltage, PRV NTE6154, NTE6155* . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 400V NTE6158, NTE6159* . . . . . . . . . . . . . . . . . . . . . . . . . . .
- Diode Type: Standard Recovery
- Repetitive Reverse Voltage Vrrm Max: 400 В
- Forward Current If(AV): 150 А
- Forward Voltage VF Max: 1.1 В
- Forward Surge Current Ifsm Max: 2.1 кА
