Datasheet NTE6162 - NTE Electronics Даташит Standard Recovery мощность выпрямитель — Даташит
Наименование модели: NTE6162
Купить NTE6162 на РадиоЛоцман.Цены — от 1 246 до 5 005 ₽10 предложений от 6 поставщиков Силовой диод, Diode 1.4kV 150A 2Pin DO-8 | |||
| NTE6162 NTE Electronics | 3 438 ₽ | ||
| NTE6162 NTE Electronics | 4 849 ₽ | ||
| NTE6162 | 5 005 ₽ | ||
| NTE6162 NTE Electronics | по запросу | ||
Производитель: NTE Electronics
Описание: Standard Recovery мощность выпрямитель
NTE6154 thru NTE6165
Silicon Industrial Rectifier 150 Amp, DO8
Description: The NTE6154 through NTE6165 power rectifiers are stud mounted DO8 type packages.
Because the silicon junction is carefully fitted within a glass-to-metal hermetically sealed case, reliable operation is assured even with extreme humidity and under other severe environmental conditions. These power rectifiers are ideal for a broad range of commercial uses including power supplies, ultrasonic systems, inverters, welders, emergency generators, battery chargers, DC motors, and motor controls. Features: D Standard DO8 Type Package D Available in Standard (Cathode to Case) and Reverse (Anode to Case) Polarity D Recommended Stud Mounting Torque: 120in. lbs. Lubricated. Electrical Ratings: Peak Reverse Voltage, PRV NTE6154, NTE6155* . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 400V NTE6158, NTE6159* . . . . . . . . . . . . . . . . . . . . . . . . . . .
