Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet MC100EP40DTG - ON Semiconductor Даташит Диод, ULTRA-FAST — Даташит
ON Semiconductor MC100EP40DTG
Наименование модели: MC100EP40DTG
Производитель: ON Semiconductor
Описание: Диод, ULTRA-FAST
data sheetСкачать Data Sheet
MC100EP40 3.3V / 5V ECL Differential Phase-Frequency Detector
Description
The MC100EP40 is a three-state phase-frequency detector intended for phase-locked loop applications which require a minimum amount of phase and frequency difference at lock.
Advanced design significantly reduces the dead zone of the detector. For proper operation, the input edge rate of the R and V inputs should be less than 5 ns. The device is designed to work with a 3.3 V / 5 V power supply. When Reference (R) and Feedback (FB) inputs are unequal in frequency and/or phase the differential UP (U) and DOWN (D) outputs will provide pulse streams which when subtracted and integrated provide an error voltage for control of a VCO. When Reference (R) and Feedback (FB) inputs are 80 ps or less in phase difference, the Phase Lock Detect pin will indicate lock by a high state (VOH). The VTX (VTR, VTR, VTFB, VTFB) pins offer an internal termination network for 50 W line impedance environment shown in Figure 2. An externa
  • Diode Type: Standard Recovery
  • Тип корпуса: SC-74R
  • Количество выводов: 6
  • SVHC: No SVHC (15-Dec-2010)
  • Температура перехода максимальная: 150°C
  • Способ монтажа: SMD
Дополнительные аксессуары:
  • Roth Elektronik - RE933-04
  • STANNOL - 631954
На английском языке: Datasheet MC100EP40DTG - ON Semiconductor DIODE, ULTRA-FAST
Политика конфиденциальности
