Datasheet MMUN2233LT1G - ON Semiconductor Даташит Транзистор, SMD NPN — Даташит
Наименование модели: MMUN2233LT1G
Купить MMUN2233LT1G на РадиоЛоцман.Цены — от 0.69 до 15 ₽67 предложений от 25 поставщиков TRANS PREBIAS NPN 246MW SOT23-3. Pre-Biased Bipolar Transistor (BJT) NPN - Pre-Biased 50V 100mA 246mW Surface Mount SOT-23-3 (TO-236). Transistors -... | |||
| MMUN2233LT1G ON Semiconductor | от 0.69 ₽ | ||
| MMUN2233LT1G ONS ON Semiconductor | от 1.74 ₽ | ||
| MMUN2233LT1G ON Semiconductor | от 3.57 ₽ | ||
| MMUN2233LT1G-O# ON Semiconductor | по запросу | ||
Производитель: ON Semiconductor
Описание: Транзистор, SMD NPN
MMUN2211LT1G Series Bias Resistor Transistor
NPN Silicon Surface Mount Transistor with Monolithic Bias Resistor Network
This new series of digital transistors is designed to replace a single device and its external resistor bias network.
The BRT (Bias Resistor Transistor) contains a single transistor with a monolithic bias network consisting of two resistors; a series base resistor and a base-emitter resistor. The BRT eliminates these individual components by integrating them into a single device. The use of a BRT can reduce both system cost and board space. The device is housed in the SOT-23 package which is designed for low power surface mount applications.
Features http://onsemi.com
R1 PIN 1 BASE (INPUT) R2
- Рабочий диапазон температрур: -55°C ... +150°C
- Тип корпуса: SOT-23
- Количество выводов: 3
- SVHC: No SVHC (20-Jun-2011)
- Способ монтажа: SMD
Дополнительные аксессуары:
- NXP - PDTC143ZT
- Roth Elektronik - RE901
- STANNOL - 631954
