Datasheet STPS12045TV - STMicroelectronics Даташит Диод, Шоттки, лампа 10 — Даташит
STMicroelectronics STPS12045TV
Наименование модели: STPS12045TV
63 предложений от 27 поставщиков
DIODE MODULE 45V 60A ISOTOP. Diode Array 2 Independent Schottky 45V 60A Chassis Mount ISOTOP. Diodes - Rectifiers - Arrays
STPS12045TV
1 195 ₽
Зенер
Россия и страны ТС
STPS12045TV
от 3 104 ₽
STPS12045TV
Xinhuo Future
STPS12045TV
Описание: Диод, Шоттки, лампа 10
data sheetСкачать Data Sheet
STPS12045TV
POWER SCHOTTKY RECTIFIER
MAIN PRODUCT CHARACTERISTICS IF(AV) VRRM Tj (max) VF (max) FEATURES AND BENEFITS VERY SMALL CONDUCTION LOSSES NEGLIGIBLE SWITCHING LOSSES EXTREMELY FAST SWITCHING LOW THERMAL RESISTANCE INSULATED PACKAGE: Insulating voltage = 2500 V(RMS) Capacitance = 45 pF DESCRIPTION Dual power Schottky rectifier suited for Switched Mode Power Supplies and high frequency DC to DC converters.
Packaged in ISOTOP, this device is especially intended for use in low voltage, high frequency inverters, free wheeling and polarity protection applications. ABSOLUTE RATINGS (limiting values) per diode Symbol VRRM IF(RMS) IF(AV) IFSM IRRM IRSM Tstg Tj dV/dt * : RMS forward current Average forward current Surge non repetitive forward current Repetitive peak reverse current Non repetitive peak reverse current Storage temperature range Maximum operating junction temperature * Critical rate of rise of reverse voltage Tc = 95°C = 0.5 Per diode Per device Parameter Repetitive p
  • Diode Type: Schottky
  • Repetitive Reverse Voltage Vrrm Max: 45 В
  • Forward Current If(AV): 60 А
  • Forward Voltage VF Max: 670 мВ
  • Forward Surge Current Ifsm Max: 900 А
  • Тип корпуса: ISOTOP
  • Количество выводов: 4
  • SVHC: No SVHC (15-Dec-2010)
  • Current If @ Vf: 60 А
  • Current Ifsm: 900 А
  • Прямой ток максимальный: 60 А
  • Температура перехода максимальная: 150°C
  • RMS Current If: 125 А
  • Способ монтажа: Screw
На английском языке: Datasheet STPS12045TV - STMicroelectronics DIODE, SCHOTTKY, TUBE 10
