Datasheet STPS16045TV - STMicroelectronics Даташит Диод, Шоттки, лампа 10 — Даташит
Наименование модели: STPS16045TV
|  Купить STPS16045TV на РадиоЛоцман.Цены — от 438 до 4 187 ₽ 49 предложений от 24 поставщиков DIODE MODULE 45V 80A ISOTOP. Diode Array 2 Independent Schottky 45V 80A Chassis Mount ISOTOP. Diodes - Rectifiers - Arrays | |||
| STPS16045TV STMicroelectronics | 1 551 ₽ | ||
| STPS16045TV STMicroelectronics | от 2 597 ₽ | ||
| STPS16045TV STMicroelectronics | от 3 799 ₽ | ||
| STPS16045TV STMicroelectronics | по запросу | ||
Описание: Диод, Шоттки, лампа 10
STPS16045TV
POWER SCHOTTKY RECTIFIER
MAIN PRODUCT CHARACTERISTICS IF(AV) VRRM Tj (max) VF (max) FEATURES AND BENEFITS VERY SMALL CONDUCTION LOSSES NEGLIGIBLE SWITCHING LOSSES EXTREMELY FAST SWITCHING LOW THERMAL RESISTANCE INSULATED PACKAGE: Insulating voltage = 2500 V(RMS) Capacitance = 45 pF DESCRIPTION Dual power Schottky rectifier suited for Switched Mode Power Supplies and high frequency DC to DC converters.
Packaged in ISOTOP, this device is especially intended for use in low voltage, high frequency inverters, free wheeling and polarity protection applications. ABSOLUTE RATINGS (limiting values, per diode) Symbol VRRM IF(RMS) IF(AV) IFSM IRRM IRSM Tstg Tj dV/dt * : RMS forward current Average forward current Surge non repetitive forward current Repetitive peak reverse current Non repetitive peak reverse current Storage temperature range Maximum operating junction temperature * Critical rate of rise of reverse voltage Tc = 75°C = 0.5 Per diode Per device Parameter Repetitive
- Diode Type: Schottky
- Repetitive Reverse Voltage Vrrm Max: 45 В
- Forward Current If(AV): 80 А
- Forward Voltage VF Max: 690 мВ
- Forward Surge Current Ifsm Max: 900 А
- Тип корпуса: ISOTOP
- Количество выводов: 4
- SVHC: No SVHC (15-Dec-2010)
- Current If @ Vf: 80 А
- Current Ifsm: 900 А
- Прямой ток максимальный: 80 А
- Температура перехода максимальная: 150°C
- RMS Current If: 125 А
- Способ монтажа: Screw
 Скачать Data Sheet
Скачать Data Sheet
