Datasheet ES1PC-M3/84A - Vishay Даташит Диод, выпрямитель, UFAST, 1 А, 150 В, SMP — Даташит
Наименование модели: ES1PC-M3/84A
37 предложений от 16 поставщиков Выпрямительные диоды, VISHAY ES1PC-M3/84A Fast / Ultrafast Diode, Single, 150V, 1A, 920mV, 25ns, 30A | |||
| ES1PC-M3/84A Vishay | 9.64 ₽ | ||
| ES1PC-M3/84A Vishay | от 21 ₽ | ||
| ES1PC-M3/84A | 38 ₽ | ||
| ES1PC-M3/84A Vishay | по запросу | ||
Производитель: Vishay
Описание: Диод, выпрямитель, UFAST, 1 А, 150 В, SMP
New Product
ES1PB, ES1PC & ES1PD
Vishay General Semiconductor
High Current Density Surface Mount Ultrafast Rectifiers
FEATURES · Very low profile - typical height of 1.0 mm · Ideal for automated placement · Glass passivated chip junction · Ultrafast recovery times for high efficiency · Low forward voltage, low power losses · Low thermal resistance · Meets MSL level 1 per J-STD-020, LF maximum peak of 260 °C · AEC-Q101 qualified · Compliant to RoHS directive 2002/95/EC and in accordance to WEEE 2002/96/EC · Halogen-free according to IEC 61249-2-21 definition · Find out more about Vishay's Automotive Grade Product requirements at: www.vishay.com/applications MECHANICAL DATA Case: DO-220AA (SMP) Molding compound meets UL 94 V-0 flammability rating Base P/N-M3 - halogen-free and RoHS compliant, commercial grade Base P/NHM3 - halogen-free and RoHS compliant, automotive grade Terminals: Matte tin plated leads, solderable per J-STD-002 and JESD 22-B102 M3 suffix meets JESD 201 class 1A whis
- Diode Type: Fast Recovery
- Repetitive Reverse Voltage Vrrm Max: 150 В
- Forward Current If(AV): 1 А
- Forward Voltage VF Max: 920 мВ
- Reverse Recovery Time trr Max: 15 нс
- Forward Surge Current Ifsm Max: 30 А
+150°C
- Тип корпуса: SMP
- Количество выводов: 2
ES1PCM3/84A, ES1PC M3/84A
