Datasheet LL101A-GS08 - Vishay Даташит Диод, Шоттки, 60 В 0.03 А, SOD80 — Даташит
Наименование модели: LL101A-GS08
![]() 52 предложений от 17 поставщиков Дискретные полупроводники Диоды — выпрямители — одиночные | |||
LL101A-GS08 Vishay | от 8.80 ₽ | ||
LL101A-GS08 Vishay | от 9.92 ₽ | ||
LL101A-GS08 Vishay | от 12 ₽ | ||
LL101A-GS08 | 29 ₽ |
Производитель: Vishay
Описание: Диод, Шоттки, 60 В 0.03 А, SOD80
LL101A, LL101B, LL101C
Vishay Semiconductors
Small Signal Schottky Diodes
Features
· For general purpose applications · The LL101 series is a metal-on-silicon Schottky barrier device which is protected by a PN junction guard ring.
· The low forward voltage drop and fast switching make it ideal for protection of MOS devices, steering, biasing and coupling diodes for fast switching and low logic level applications. · Integrated protection ring against static discharge · Low capacitance · Low leakage current · This diode is also available in the DO-35 case with type designation SD101A, B, C and in the SOD-123 case with type designation SD101AW-V, SD101BW-V, SD101CW-V · AEC-Q101 qualified · Compliant to RoHS directive 2002/95/EC and in accordance to WEEE 2002/96/EC
- Diode Type: Schottky
- Repetitive Reverse Voltage Vrrm Max: 60 В
- Forward Current If(AV): 15 мА
- Forward Voltage VF Max: 1 В
- Reverse Recovery Time trr Max: 1 нс
- Forward Surge Current Ifsm Max: 2 А
- Тип корпуса: SOD-80
- Количество выводов: 2
LL101AGS08, LL101A GS08
