Datasheet MURS160-E3/52T - Vishay Даташит FAST диод, 1 А, 600 В, DO-214AA — Даташит
Наименование модели: MURS160-E3/52T
![]() 34 предложений от 17 поставщиков VISHAY - MURS160-E3/52T - Diodo Veloce / Ultraveloce, 600 V, 1 A, Singolo, 1.25 V, 50 ns, 35 A | |||
MURS160-E3/52T | от 3.47 ₽ | ||
MURS160-E3/52T | от 6.54 ₽ | ||
MURS160E352T Diodes | по запросу | ||
MURS160-E3/52T Vishay | по запросу |
Производитель: Vishay
Описание: FAST диод, 1 А, 600 В, DO-214AA
MURS140 & MURS160
Vishay General Semiconductor
Surface Mount Ultrafast Plastic Rectifier
FEATURES · Glass passivated chip junction · Ideal for automated placement · Ultrafast reverse recovery time · Low switching losses, high efficiency · High forward surge capability · Meets MSL level 1, per J-STD-020C, LF max peak of 260 °C · Solder Dip 260 °C, 40 seconds · Component in accordance to RoHS 2002/95/EC and WEEE 2002/96/EC TYPICAL APPLICATIONS For use in high frequency rectification and freewheeling application in switching mode converters and inverters for consumer, computer and telecommunication.
MECHANICAL DATA Case: DO-214AA (SMB) Epoxy meets UL 94V-0 flammability rating Terminals: Matte tin plated leads, solderable per J-STD-002B and JESD22-B102D E3 suffix for commercial grade, HE3 suffix for high reliability grade (AEC Q101 qualified) Polarity: Color band denotes cathode end MAXIMUM RATINGS (TA = 25 °C unless otherwise noted)
PARAMETER Device marking code Maximum repetitive peak r
- Diode Type: Fast Recovery
- Repetitive Reverse Voltage Vrrm Max: 600 В
- Forward Current If(AV): 1 А
- Forward Voltage VF Max: 1.05 В
- Reverse Recovery Time trr Max: 50 нс
- Forward Surge Current Ifsm Max: 35 А
RoHS: Y-Ex
MURS160E3/52T, MURS160 E3/52T
