Datasheet SR306 - Taiwan Semiconductor Даташит Диод, Шоттки, 3 А, 60 В — Даташит
Taiwan Semiconductor SR306
Наименование модели: SR306
62 предложений от 34 поставщиков
Microfind
SR306 DO-27
Micra
4.27 ₽
ICdarom.ru
SR306
Master Instruments
от 5.22 ₽
SR306
TradeElectronics
SR306R0
Производитель: Taiwan Semiconductor
Описание: Диод, Шоттки, 3 А, 60 В
data sheetСкачать Data Sheet
SR302 THRU SR310
3.0 AMPS.
Schottky Barrier Rectifiers
Voltage Range 20 to 100 Volts Current 3.0 Amperes
Features
Low forward voltage drop High current capability High reliability High surge current capability
Указания по применениюУказания по применению
Introduction To SCHOTTKY Rectifier and Application Guidelines
Kevin Wu, AE Manager Taiwan Semiconductor Why SCHOTTKY? For Silicon devices, the forward voltage drop of the pn-junction rectifier can not be reduced below about 0.8 volts even if the device is not required to block higher reverse voltage. In the case of the output rectifiers used in power supplies for computers and telecommunications, this voltage drop is a large fraction of the output voltage of 5V or less. This results in a loss in the power supply efficiency by 20% - 30%. For Schottky barrier rectifier they can exhibit a very low forward voltage drop leading a smaller conduction loss than that of pn-junction rectifier, and switching speeds approaching zero-time. This combination hence makes Schottky barrier rectifiers ideal for the output stages of switching power supplies. Schottky diodes Presently the breakdown voltage of the Silicon Schottky diode cannot be reliably made larger than 200V. However, the drawback
of the
  • Diode Type: Schottky
  • Repetitive Reverse Voltage Vrrm Max: 60 В
  • Forward Current If(AV): 3 А
  • Forward Voltage VF Max: 700 мВ
  • Forward Surge Current Ifsm Max: 80 А
  • Рабочий диапазон температрур: -65°C ... +150°C
  • Тип корпуса: DO-201AD
  • Количество выводов: 2
  • SVHC: No SVHC (15-Dec-2010)
  • Current If @ Vf: 3 А
  • Current Ifsm: 80 А
  • Маркировка: SR306
  • External Diameter: 5.8 мм
  • Внешняя длина / высота: 9.5 мм
  • Прямой ток максимальный: 3 А
  • Forward Voltage: 700 мВ
  • Температура перехода максимальная: 150°C
  • Способ монтажа: Axial Leaded
Дополнительные аксессуары:
  • Multicomp - SB360
На английском языке: Datasheet SR306 - Taiwan Semiconductor DIODE, SCHOTTKY, 3 A, 60 V
