Datasheet GS150TC_25110 - IXYS RF Даташит Диод, GAAS, Шоттки, DE150 — Даташит
IXYS RF GS150TC_25110
Наименование модели: GS150TC_25110
Производитель: IXYS RF
Описание: Диод, GAAS, Шоттки, DE150
data sheetСкачать Data Sheet
GaAs Schottky Diode
Extremely Fast Recovery for RF & MHz Switching Applications January 2003
Description
This new line of High Speed GaAs Schottky Diodes provide extremely fast recovery times, outperforming both Ultrafast and Silicon Carbide technologies.
The recovery times and low junction capacitances combined with their inherently low forward voltages make this new product family ideal for High Frequency Converters, Resonant Converters and Switch Mode Power Supplies operating from the KHz-MHz range. The GaAs devices are packaged in the low inductance, low profile, electrically isolated, surface mount DE-150 package. The matched thermal coefficient of expansion between the aluminum nitride substrate and the GaAs Diode result in improved reliability and power cycling performance. The GaAs Schottky products have an added advantage when used in conjunction with the DE Series Switch Mode & RF Mosfets. Both products utilize the same package profiles resulting in a convenient single plane
  • Diode Configuration: Triple Common Cathode
  • Прямой ток максимальный: 2 А
  • Forward Voltage VF Max: 1.5 В
  • Capacitance Ct: 18 пФ
  • Тип корпуса: DE150
  • Количество выводов: 6
  • Current If @ Vf: 2 А
  • Diode Type: RF Schottky
  • Forward Voltage: 1.5 В
  • Peak Forward Current: 10 А
  • Pin Configuration: Triple, Common Cathode
  • Рассеиваемая мощность максимальная: 15 Вт
  • Repetitive Reverse Voltage Vrrm Max: 250 В
  • Reverse Voltage Vr Max: 250 В
  • Способ монтажа: SMD
На английском языке: Datasheet GS150TC_25110 - IXYS RF DIODE, GAAS, SCHOTTKY, DE150
