Datasheet HSMP-3810-TR1G - Avago Technologies Даташит Диод, ВЧ, PIN, SOT-23 — Даташит
Наименование модели: HSMP-3810-TR1G
![]() 17 предложений от 13 поставщиков Диод RF, BROADCOM LIMITED HSMP-3810-TR1G RF / Pin Diode, Single, 3Ω, 100V, SOT-23, 3Pin, 0.35pF | |||
HSMP-3810-TR1G Broadcom | 27 ₽ | ||
HSMP-3810-TR1G Broadcom | по запросу | ||
HSMP-3810-TR1G Texas Instruments | по запросу | ||
Производитель: Avago Technologies
Описание: Диод, ВЧ, PIN, SOT-23
HSMP-381x, 481x
Surface Mount RF PIN Low Distortion Attenuator Diodes
Data Sheet
Description/Applications
The HSMP-381x series is specifically designed for low distortion attenuator applications.
The HSMP-481x products feature ultra low parasitic inductance in the SOT-23 and SOT-323 packages. They are specifically designed for use at frequencies which are much higher than the upper limit for conventional diodes. A SPICE model is not available for PIN diodes as SPICE does not provide for a key PIN diode characteristic, carrier lifetime.
- SVHC: No SVHC (15-Dec-2010)
- Breakdown Voltage: 100 В
- Capacitance Ct: 0.35 пФ
- Маркировка: E0
- Diode Series Resistance Rs: 3 Ом
- Diode Type: RF
- High Resistance Limit Min: 1500 Ом
- Low Resistance Limit Max: 10 Ом
- Количество выводов: 3
- Тип корпуса: SOT-23
- Способ монтажа: SMD
HSMP3810TR1G, HSMP 3810 TR1G
