Datasheet HSMP-3814-TR1G - Avago Technologies Даташит Диод, ВЧ, аттенюатор, сдвоенный — Даташит
Avago Technologies HSMP-3814-TR1G
Наименование модели: HSMP-3814-TR1G
Диод RF, BROADCOM LIMITED HSMP-3814-TR1G RF / Pin Diode, Attenuator, Common Cathode, 3Ω, 100V, SOT-23, 3Pin, 0.35pF
HSMP-3814-TR1G
Avago Technologies
120 ₽
727GS
HSMP-3814-TR1G
Broadcom
1 231 ₽
HSMP-3814-TR1G
Broadcom
LifeElectronics
HSMP3814-TR1G
Производитель: Avago Technologies
Описание: Диод, ВЧ, аттенюатор, сдвоенный
data sheetСкачать Data Sheet
HSMP-381x, 481x
Surface Mount RF PIN Low Distortion Attenuator Diodes
Data Sheet
Description/Applications
The HSMP-381x series is specifically designed for low distortion attenuator applications.
The HSMP-481x products feature ultra low parasitic inductance in the SOT-23 and SOT-323 packages. They are specifically designed for use at frequencies which are much higher than the upper limit for conventional diodes. A SPICE model is not available for PIN diodes as SPICE does not provide for a key PIN diode characteristic, carrier lifetime.
  • SVHC: No SVHC (15-Dec-2010)
  • Breakdown Voltage: 100 В
  • Capacitance Ct: 0.35 пФ
  • Маркировка: E4
  • Diode Series Resistance Rs: 4 Ом
  • Diode Type: RF
  • High Resistance Limit Min: 1500 Ом
  • Low Resistance Limit Max: 10 Ом
  • Количество выводов: 3
  • Тип корпуса: SOT-23
  • Способ монтажа: SMD
HSMP3814TR1G, HSMP 3814 TR1G
На английском языке: Datasheet HSMP-3814-TR1G - Avago Technologies DIODE, RF, ATTENUATOR, DUAL
