Datasheet HSMS-2855-BLKG - Avago Technologies Даташит Диод, Шоттки, SOT-143 — Даташит
Avago Technologies HSMS-2855-BLKG
Наименование модели: HSMS-2855-BLKG
Диоды Шоттки, Diode RF Detector Schottky 2V 4Pin(3+Tab) SOT-143 Bulk
LifeElectronics
HSMS-2855-BLKG
Avago Technologies
HSMS-2855-BLKG
Broadcom
HSMS-2855-BLKG
Broadcom
HSMS-2855-BLKG
Производитель: Avago Technologies
Описание: Диод, Шоттки, SOT-143
data sheetСкачать Data Sheet
HSMS-285x Series
Surface Mount Zero Bias Schottky Detector Diodes
Data Sheet
Description
Avago's HSMS-285x family of zero bias Schottky detector diodes has been designed and optimized for use in small signal (Pin <-20 dBm) applications at frequencies below 1.5 GHz.
They are ideal for RF/ID and RF Tag applications where primary (DC bias) power is not available. Important Note: For detector applications with input power levels greater than ­20 dBm, use the HSMS-282x series at frequencies below 4.0 GHz, and the HSMS-286x series at frequencies above 4.0 GHz. The HSMS-285x series IS NOT RECOMMENDED for these higher power level applications. Available in various package configurations, these detector diodes provide low cost solutions to a wide variety of design problems. Avago's manufacturing techniques assure that when two diodes are mounted into a single package, they are taken from adjacent sites on the wafer, assuring the highest possible degree of match.
  • Diode Configuration: Unconnected Pair
  • Прямой ток максимальный: 1 мА
  • Forward Voltage VF Max: 250 мВ
  • Capacitance Ct: 0.3 пФ
  • Тип корпуса: SOT-143
  • Количество выводов: 4
  • SVHC: No SVHC (15-Dec-2010)
  • Current If @ Vf: 1 мА
  • Маркировка: P5
  • Diode Type: RF Schottky
  • Forward Current If(AV): 1 А
  • Forward Voltage: 250 мВ
  • Температура перехода максимальная: 150°C
  • Рабочий диапазон температрур: -65°C ... +150°C
  • Pin Configuration: Unconnected Pair
  • Repetitive Reverse Voltage Vrrm Max: 2 В
  • Reverse Voltage Vr Max: 2 В
  • Способ монтажа: SMD
Дополнительные аксессуары:
  • LICEFA - V11-7-6-10
  • LICEFA - V11-7
HSMS2855BLKG, HSMS 2855 BLKG
На английском языке: Datasheet HSMS-2855-BLKG - Avago Technologies DIODE, SCHOTTKY, SOT-143
