Datasheet 1N5282 - Fairchild Даташит Диод — Даташит
Наименование модели: 1N5282
![]() 20 предложений от 14 поставщиков Diode: switching; THT; 80V; 0.2A; reel,tape; DO35 | |||
1N5282TR Fairchild | 5.70 ₽ | ||
1N5282TR ON Semiconductor | по запросу | ||
1N5282_T50R Fairchild | по запросу | ||
1N5282 Fairchild | по запросу |
Производитель: Fairchild
Описание: Диод
Small Signal Transistors & Diodes Selection Guide
Fairchild Semiconductor, a long-time, leading global supplier of high performance semiconductors, offers a broad range of small signal transistor and diode products--from JFets, Schottky, and rectifiers, to RF transistors, tRiAcs and more.
You will not only find the performance that you want, you will also find the right packaging to meet your design needs. in addition, you can be assured that Fairchild offers long-term family support to help extend the life of your design. With our commitment to providing the best customer service in the industry along with one of the largest portfolios of small signal transistor and diode products, Fairchild is the supplier you can rely on, now and into the future. this selection guide provides information for the following categories of products:
Rectifiers: Bridge Recitifiers ....................................................................................................................3 Fa
- Diode Type: Small Signal
- Forward Current, If(AV): 200 мА
- Repetitive Reverse Voltage Max, Vrrm: 80 В
- Forward Voltage Max, VF: 1.3 В
- Reverse Recovery Time, trr: 4 нс
- Forward Surge Current Max, Ifsm: 4 А
- Тип корпуса: DO-35
Дополнительные аксессуары:
- MULTICORE (SOLDER) - MM02104
- SPC Technology - 3613
