Datasheet LT1019CS8-10 - Linear Technology Даташит Voltage Reference ИС — Даташит
Наименование модели: LT1019CS8-10
![]() 38 предложений от 22 поставщиков Интегральные микросхемы Микросхемы управления электропитанием - Опорное напряжение | |||
LT1019CS8-10#TRPBF Analog Devices | от 137 ₽ | ||
LT1019CS8-10#TRPBF Analog Devices | от 642 ₽ | ||
LT1019CS810 | по запросу | ||
LT1019CS8-10 Linear Technology | по запросу |
Производитель: Linear Technology
Описание: Voltage Reference ИС
LT1019 Precision Reference
FEATURES
DESCRIPTIO
Tight Initial Output Voltage: < 0.05% Ultralow Drift: 3ppm/°C Typical Series or Shunt Operation Curvature Corrected Ultrahigh Line Rejection: 0.5ppm/V Low Output Impedance: 0.02 Plug-In Replacement for Present References Available at 2.5V, 4.5V, 5V, and 10V 100% Noise Tested Temperature Output Industrial Temperature Range in SO-8 Available in 8-Lead N8 and S8 Packages
The LT ®1019 is a third generation bandgap voltage reference utilizing thin film technology and a greatly improved curvature correction technique.
Wafer level trimming of both reference and output voltage combines to produce very low TC and tight initial output voltage tolerance. The LT1019 can both sink and source up to 10mA and can be used in either the series or shunt mode, allowing the reference to operate with positive or negative output voltages without external components. Minimum input/ output voltage is less than 1V in the series mode, providing impr
- Topology: Series or Shunt
- Входное напряжение: 11.5 В ... 40 В
- Reference Voltage: 10 В
- Temperature Coefficient: 20
- Voltage Reference Case Style: SOIC
- Количество выводов: 8
- Рабочий диапазон температрур: 0°C ... +70°C
LT1019CS810, LT1019CS8 10
