Datasheet ES3A-E3/57T - Vishay Даташит Диод, FAST, 3 А, 50 В, SMC — Даташит
Наименование модели: ES3A-E3/57T
42 предложений от 17 поставщиков Силовой диод, DIODE 3A, 50V, SILICON, RECTIFIER DIODE, DO-214AB, ROHS COMPLIANT, PLASTIC, SMC, 2Pin, Rectifier Diode | |||
| ES3A-E3/57T Vishay | 13 ₽ | ||
| ES3A-E3/57T Vishay | от 29 ₽ | ||
| ES3A-E3/57T Vishay | 32 ₽ | ||
| ES3A-E3/57T | по запросу | ||
Производитель: Vishay
Описание: Диод, FAST, 3 А, 50 В, SMC
ES3A thru ES3D
Vishay General Semiconductor
Surface Mount Ultrafast Plastic Rectifier
FEATURES · Glass passivated chip junction · Ideal for automated placement · Ultrafast recovery times for high efficiency · Low forward voltage, low power losses · High forward surge capability · Meets MSL level 1, per J-STD-020C, LF max peak of 260 °C · Solder Dip 260 °C, 40 seconds · Component in accordance to RoHS 2002/95/EC and WEEE 2002/96/EC TYPICAL APPLICATIONS For use in high frequency rectification and freewheeling application in switching mode converters and inverters for consumer, computer and telecommunication.
MECHANICAL DATA Case: DO-214AB (SMC) Epoxy meets UL 94V-0 flammability rating Terminals: Matte tin plated leads, solderable per J-STD-002B and JESD22-B102D E3 suffix for commercial grade, HE3 suffix for high reliability grade (AEC Q101 qualified) Polarity: Color band denotes cathode end MAXIMUM RATINGS (TA = 25 °C unless otherwise noted)
PARAMETER Device marking code Maximum repetit
- Diode Type: Fast Recovery
- Repetitive Reverse Voltage Vrrm Max: 50 В
- Forward Current If(AV): 3 А
- Forward Voltage VF Max: 900 мВ
- Reverse Recovery Time trr Max: 20 нс
- Forward Surge Current Ifsm Max: 100 А
- Рабочий диапазон температрур: -55°C ... +150°C
- Тип корпуса: SMC
- Количество выводов: 2
- SVHC: No SVHC (18-Jun-2010)
- Альтернативный тип корпуса: DO-214AB
- Current Ifsm: 100 А
- External Depth: 2.45 мм
- Внешняя длина / высота: 2.62 мм
- Внешняя ширина: 8.13 мм
- Прямой ток максимальный: 3 А
- Forward Voltage: 900 мВ
- Температура перехода максимальная: 150°C
- Reverse Recovery Time trr Typ: 20 нс
- Способ монтажа: SMD
- Diode Configuration: Dual
Дополнительные аксессуары:
- Electrolube - SMA10SL
ES3AE3/57T, ES3A E3/57T
