Datasheet ES3B-E3/57T - Vishay Даташит FAST диод, 3 А, 100 В, DO-214AB — Даташит
Наименование модели: ES3B-E3/57T
|  Купить ES3B-E3/57T на РадиоЛоцман.Цены — от 9.02 до 84 ₽ 51 предложений от 21 поставщиков Быстрый / ультрабыстрый диод, 100 В, 3 А, Одиночный, 900 мВ, 20 нс, 100 А | |||
| ES3B-E3/57T Vishay | 9.02 ₽ | ||
| ES3B-E3/57T Vishay | 19 ₽ | ||
| ES3B-E3/57T Vishay | от 30 ₽ | ||
| ES3B-E3/57T General Semiconductor | по запросу | ||
Производитель: Vishay
Описание: FAST диод, 3 А, 100 В, DO-214AB
ES3A thru ES3D
Vishay General Semiconductor
Surface Mount Ultrafast Plastic Rectifier
FEATURES · Glass passivated chip junction · Ideal for automated placement · Ultrafast recovery times for high efficiency · Low forward voltage, low power losses · High forward surge capability · Meets MSL level 1, per J-STD-020C, LF max peak of 260 °C · Solder Dip 260 °C, 40 seconds · Component in accordance to RoHS 2002/95/EC and WEEE 2002/96/EC TYPICAL APPLICATIONS For use in high frequency rectification and freewheeling application in switching mode converters and inverters for consumer, computer and telecommunication.
MECHANICAL DATA Case: DO-214AB (SMC) Epoxy meets UL 94V-0 flammability rating Terminals: Matte tin plated leads, solderable per J-STD-002B and JESD22-B102D E3 suffix for commercial grade, HE3 suffix for high reliability grade (AEC Q101 qualified) Polarity: Color band denotes cathode end MAXIMUM RATINGS (TA = 25 °C unless otherwise noted)
PARAMETER Device marking code Maximum repetit
- Diode Type: Fast Recovery
- Repetitive Reverse Voltage Vrrm Max: 100 В
- Forward Current If(AV): 3 А
- Forward Voltage VF Max: 0.9 В
- Reverse Recovery Time trr Max: 20 нс
- Forward Surge Current Ifsm Max: 100 А
RoHS: Y-Ex
ES3BE3/57T, ES3B E3/57T
 Скачать Data Sheet
Скачать Data Sheet
