Datasheet S2A-E3/52T - Vishay Даташит STANDARD диод, 1.5 А, 50 В, DO-214AA — Даташит
Vishay S2A-E3/52T
Наименование модели: S2A-E3/52T
32 предложений от 15 поставщиков
Стандартный восстанавливающийся диод, 50 В, 1.5 А, Одиночный, 1.15 В, 2 мкс, 50 А
S2A-E3/52T
9.75 ₽
S2A-E3/52T
от 18 ₽
S2A-E3/52T
39 ₽
S2A-E3/52T
Geyer
Производитель: Vishay
Описание: STANDARD диод, 1.5 А, 50 В, DO-214AA
data sheetСкачать Data Sheet
S2A thru S2M
Vishay General Semiconductor
Surface Mount Glass Passivated Rectifier
FEATURES · Low profile package · Ideal for automated placement · Glass passivated chip junction · Low forward voltage drop · Low leakage current · High forward surge capability · Meets MSL level 1, per J-STD-020, LF maximum peak of 260 °C · Solder dip 260 °C, 40 s · Component in accordance to RoHS 2002/95/EC and WEEE 2002/96/EC TYPICAL APPLICATIONS For use in general purpose rectification of power supplies, inverters, converters and freewheeling diodes for consumer, automotive and telecommunication.
MECHANICAL DATA Case: DO-214AA (SMB) Epoxy meets UL 94V-0 flammability rating Terminals: Matte tin plated leads, solderable per J-STD-002 and JESD22-B102 E3 suffix for consumer grade, meets JESD 201 class 1A whisker test, HE3 suffix for high reliability grade (AEC Q101 qualified), meets JESD 201 class 2 whisker test Polarity: Color band denotes cathode end
DO-214AA (SMB)
  • Diode Type: Standard Recovery
  • Repetitive Reverse Voltage Vrrm Max: 50 В
  • Forward Current If(AV): 1.5 А
  • Forward Voltage VF Max: 1.15 В
  • Reverse Recovery Time trr Max: 2.0 мкс
RoHS: Y-Ex
S2AE3/52T, S2A E3/52T
На английском языке: Datasheet S2A-E3/52T - Vishay STANDARD DIODE, 1.5 A, 50 V, DO-214AA
