Datasheet S2D-E3/52T - Vishay Даташит STANDARD диод, 1.5 А, 200 В DO-214AA — Даташит
Наименование модели: S2D-E3/52T
![]() 29 предложений от 13 поставщиков Диоды - Выпрямители со Стандартным Временем Восста | |||
S2D-E3/52T Vishay | 6.60 ₽ | ||
S2D-E3/52T Vishay | от 10 ₽ | ||
S2D-E3/52T Vishay | от 11 ₽ | ||
S2D-E3/52T | по запросу |
Производитель: Vishay
Описание: STANDARD диод, 1.5 А, 200 В DO-214AA
S2A thru S2M
Vishay General Semiconductor
Surface Mount Glass Passivated Rectifier
FEATURES · Low profile package · Ideal for automated placement · Glass passivated chip junction · Low forward voltage drop · Low leakage current · High forward surge capability · Meets MSL level 1, per J-STD-020, LF maximum peak of 260 °C · Solder dip 260 °C, 40 s · Component in accordance to RoHS 2002/95/EC and WEEE 2002/96/EC TYPICAL APPLICATIONS For use in general purpose rectification of power supplies, inverters, converters and freewheeling diodes for consumer, automotive and telecommunication.
MECHANICAL DATA Case: DO-214AA (SMB) Epoxy meets UL 94V-0 flammability rating Terminals: Matte tin plated leads, solderable per J-STD-002 and JESD22-B102 E3 suffix for consumer grade, meets JESD 201 class 1A whisker test, HE3 suffix for high reliability grade (AEC Q101 qualified), meets JESD 201 class 2 whisker test Polarity: Color band denotes cathode end
DO-214AA (SMB)
- Diode Type: Standard Recovery
- Repetitive Reverse Voltage Vrrm Max: 200 В
- Forward Current If(AV): 1.5 А
- Forward Voltage VF Max: 1.15 В
- Reverse Recovery Time trr Max: 2.0 мкс
RoHS: Y-Ex
S2DE3/52T, S2D E3/52T
