Datasheet US1M-E3/5AT - Vishay Даташит FAST RECOVERY диод, 1 А, 1 кВ, DO-214AC — Даташит
Наименование модели: US1M-E3/5AT
46 предложений от 16 поставщиков Быстрый / ультрабыстрый диод, 1 кВ, 1 А, Одиночный, 1.7 В, 75 нс, 30 А | |||
| US1M-E3/5AT Vishay | от 16 ₽ | ||
| US1M-E3/5AT Vishay | от 29 ₽ | ||
| US1M-E3/5AT | по запросу | ||
Производитель: Vishay
Описание: FAST RECOVERY диод, 1 А, 1 кВ, DO-214AC
US1A thru US1M
Vishay General Semiconductor
Surface Mount Ultrafast Rectifier
FEATURES · Low profile package · Ideal for automated placement · Glass passivated chip junction · Ultrafast reverse recovery time · Low switching losses, high efficiency · High forward surge capability · Meets MSL level 1, per J-STD-020, LF maximum peak of 260 °C · Solder dip 260 °C, 40 s · Component in accordance to RoHS 2002/95/EC and WEEE 2002/96/EC TYPICAL APPLICATIONS For use in high frequency rectification and freewheeling application in switching mode converters and inverters for consumer, computer, automotive and telecommunication.
MECHANICAL DATA Case: DO-214AC (SMA) Epoxy meets UL 94V-0 flammability rating Terminals: Matte tin plated leads, solderable per J-STD-002 and JESD22-B102 E3 suffix for consumer grade, meets JESD 201 class 1A whisker test, HE3 suffix for high reliability grade (AEC Q101 qualified), meets JESD 201 class 2 whisker test Polarity: Color band denotes cathode end
DO-214AC (SMA)
- Diode Type: Fast Recovery
- Repetitive Reverse Voltage Vrrm Max: 1000 В
- Forward Current If(AV): 1 А
- Forward Voltage VF Max: 1.7 В
- Reverse Recovery Time trr Max: 75 нс
RoHS: Y-Ex
US1ME3/5AT, US1M E3/5AT
