Клеммники KEEN SIDE
Datasheet RS1A-E3/61T - Vishay Даташит FAST переключатель диод, 1 А, 50 В DO-214AC — Даташит
Vishay RS1A-E3/61T
Наименование модели: RS1A-E3/61T
34 предложений от 16 поставщиков
RS1AE361T
3.10 ₽
RS1A-E3/61T
от 17 ₽
LifeElectronics
RS1A-E3/61T
RS1A-E3/61T
Производитель: Vishay
Описание: FAST переключатель диод, 1 А, 50 В DO-214AC
data sheetСкачать Data Sheet
RS1A thru RS1K
Vishay General Semiconductor
Surface Mount Fast Switching Rectifier
FEATURES · Low profile package · Ideal for automated placement · Glass passivated chip junction · Fast switching for high efficiency · High forward surge capability · Meets MSL level 1, per J-STD-020, LF maximum peak of 260 °C · Solder dip 260 °C, 40 s · Component in accordance to RoHS 2002/95/EC and WEEE 2002/96/EC TYPICAL APPLICATIONS For use in fast switching rectification of power supply, inverters, converters, and freewheeling diodes for consumer, automotive and telecommunication.
MECHANICAL DATA Case: DO-214AC (SMA) Epoxy meets UL 94V-0 flammability rating Terminals: Matte tin plated leads, solderable per J-STD-002 and JESD22-B102 E3 suffix for consumer grade, meets JESD 201 class 1A whisker test, HE3 suffix for high reliability grade (AEC Q101 qualified), meets JESD 201 class 2 whisker test Polarity: Color band denotes cathode end
DO-214AC (SMA)
  • Diode Type: Fast Recovery
  • Repetitive Reverse Voltage Vrrm Max: 50 В
  • Forward Current If(AV): 1 А
  • Forward Voltage VF Max: 1.3 В
  • Reverse Recovery Time trr Max: 150 нс
  • Forward Surge Current Ifsm Max: 30 А
RoHS: Y-Ex
RS1AE3/61T, RS1A E3/61T
На английском языке: Datasheet RS1A-E3/61T - Vishay FAST SWITCH DIODE, 1 A, 50 V DO-214AC
