Datasheet LM4040DIZ-2.5 - National Semiconductor Даташит ИС, микромощный, VOLT REF, 2.5 В — Даташит
Наименование модели: LM4040DIZ-2.5
49 предложений от 24 поставщиков
LM4040DIZ-2.5
6.72 ₽
LM4040DIZ-2.5/NOPB
от 53 ₽
LM4040DIZ2.5
Zetex
SUV System
LM4040DIZ-2.5/NOPB
Описание: ИС, микромощный, VOLT REF, 2.5 В
data sheetСкачать Data Sheet
LM4040 Precision Micropower Shunt Voltage Reference
April 2005
General Description
Ideal for space critical applications, the LM4040 precision voltage reference is available in the sub-miniature SC70 and SOT-23 surface-mount package.
The LM4040's advanced design eliminates the need for an external stabilizing capacitor while ensuring stability with any capacitive load, thus making the LM4040 easy to use. Further reducing design effort is the availability of several fixed reverse breakdown voltages: 2.048V, 2.500V, 3.000V, 4.096V, 5.000V, 8.192V, and 10.000V. The minimum operating current increases from 60 µA for the LM4040-2.5 to 100 µA for the LM4040-10.0. All versions have a maximum operating current of 15 mA. The LM4040 utilizes fuse and zener-zap reverse breakdown voltage trim during wafer sort to ensure that the prime parts have an accuracy of better than ± 0.1% (A grade) at 25°C. Bandgap reference temperature drift curvature c
  • Тип корпуса: TO-92
  • Количество выводов: 3
  • SVHC: No SVHC (15-Dec-2010)
  • Diode Type: Voltage reference
  • Температура перехода максимальная: 85°C
  • Температура перехода минимальная: -40°C
  • Tolerance: 0.1%
  • Семейство: 4040
  • Количество логических функций: 4040
  • Reference Voltage: 2.5 В
  • Temperature Coeff. +: 150ppm/°C
  • Рабочий диапазон температрур: -40°C ... 85°C
Дополнительные аксессуары:
  • Fischer Elektronik - WLK 5
LM4040DIZ2.5, LM4040DIZ 2.5
На английском языке: Datasheet LM4040DIZ-2.5 - National Semiconductor IC, MICROPOWER, VOLT REF, 2.5 V
