Datasheet LM4120AIM5-4.1/NOPB - National Semiconductor Даташит В REF, SERIES, ADJ, 5 мА, SOT23 — Даташит
Наименование модели: LM4120AIM5-4.1/NOPB
32 предложений от 17 поставщиков
Источник опорного напряжения, прецизионный Micropower, последовательный - фиксированный, LM4120
LM4120AIM5-4.1/NOPB
187 ₽
LM4120AIM5-4.1/NOPB
258 ₽
LM4120AIM541NOPB
SUV System
LM4120AIM5-4.1/NOPB
Описание: В REF, SERIES, ADJ, 5 мА, SOT23
data sheetСкачать Data Sheet
LM4120 Precision Micropower Low Dropout Voltage Reference
March 2005
General Description
The LM4120 is a precision low power low dropout bandgap voltage reference with up to 5 mA output current source and sink capability.
This series reference operates with input voltages as low as 2V and up to 12V consuming 160 µA (Typ.) supply current. In power down mode, device current drops to less than 2 µA. The LM4120 comes in two grades (A and Standard) and seven voltage options for greater flexibility. The best grade devices (A) have an initial accuracy of 0.2%, while the standard have an initial accuracy of 0.5%, both with a tempco of 50ppm/°C guaranteed from -40°C to +125°C. The very low dropout voltage, low supply current and powerdown capability of the LM4120 makes this product an ideal choice for battery powered and portable applications. The device performance is guaranteed over the industrial temperature range (-40°C to +85°C),
  • Тип корпуса: SOT-23
  • Количество выводов: 5
  • SVHC: No SVHC (15-Dec-2010)
  • Способ монтажа: SMD
  • Tolerance: 0.2%
  • Семейство: 4120
  • Входное напряжение максимальное: 12 В
  • Входное напряжение минимальное: 2 В
  • Выходной ток максимальный: 5 мА
  • Reference Voltage: 4.096 В
  • Temperature Coeff. +: 14ppm/°C
  • Рабочий диапазон температрур: -40°C ... 85°C
Дополнительные аксессуары:
  • CHEMTRONICS - 40-2-10
  • Roth Elektronik - RE901
  • STANNOL - 574601
LM4120AIM54.1/NOPB, LM4120AIM5 4.1/NOPB
На английском языке: Datasheet LM4120AIM5-4.1/NOPB - National Semiconductor V REF, SERIES, ADJ, 5 mA, SOT23
