Datasheet LM4040AIM3-5.0 - National Semiconductor Даташит ИС, SM, VOLT REF, 5 В — Даташит
Наименование модели: LM4040AIM3-5.0
![]() 47 предложений от 28 поставщиков Источник опорного напряжения, прецизионный микромощный, AEC-Q100 LM4040, 5В, SOT-23-3 | |||
LM4040AIM3-5.0 TS Microchip | 13 ₽ | ||
LM4040AIM3-5.0/NOPB Texas Instruments | от 167 ₽ | ||
LM4040AIM3-5.0/NOPB Texas Instruments | от 297 ₽ | ||
LM4040AIM3-5.0+ Texas Instruments | по запросу |
Описание: ИС, SM, VOLT REF, 5 В
LM4040 Precision Micropower Shunt Voltage Reference
August 2002
General Description
Ideal for space critical applications, the LM4040 precision voltage reference is available in the sub-miniature SC70 and SOT-23 surface-mount package.
The LM4040's advanced design eliminates the need for an external stabilizing capacitor while ensuring stability with any capacitive load, thus making the LM4040 easy to use. Further reducing design effort is the availability of several fixed reverse breakdown voltages: 2.048V, 2.500V, 3.000V, 4.096V, 5.000V, 8.192V, and 10.000V. The minimum operating current increases from 60 µA for the LM4040-2.5 to 100 µA for the LM4040-10.0. All versions have a maximum operating current of 15 mA. The LM4040 utilizes fuse and zener-zap reverse breakdown voltage trim during wafer sort to ensure that the prime parts have an accuracy of better than ± 0.1% (A grade) at 25°C. Bandgap reference temperature drift curvature
- Тип корпуса: SOT-23
- Количество выводов: 3
- SVHC: No SVHC (18-Jun-2010)
- Diode Type: Voltage reference
- Dynamic Resistance: 0.3 Ом
- Forward Current If(AV): 45 мкА
- Forward Surge Current Ifsm Max: 60 мкА
- Температура перехода максимальная: 85°C
- Температура перехода минимальная: -40°C
- Power Disspation Pd @ Tc = 25C Max: 306 мВт
- Способ монтажа: SMD
- Tolerance: 0.1%
- Семейство: 4040
- Количество логических функций: 4040
- Reference Voltage: 5 В
- Reference Voltage & Age Tolerance: 0.1%
- Reference Voltage Tolerance: 5 мВ
- Temperature Coeff. +: 100ppm/°C
- Temperature Coefficient: 100ppm
- Тип стабилизатора: Shunt
- Рабочий диапазон температрур: -40°C ... 85°C
LM4040AIM35.0, LM4040AIM3 5.0
