Datasheet ADC081S021CIMF - National Semiconductor Даташит 8 бит ADC, 1CH, POWERWISE, SOT-23-6 — Даташит
Наименование модели: ADC081S021CIMF
![]() 45 предложений от 21 поставщиков Микросхема Преобразователь AD, TEXAS INSTRUMENTS ADC081S021CIMF/NOPB Analog to Digital Converter, 8Bit, 200KSPS, Single, 2.7V, 5.25V, SOT-23 | |||
ADC081S021CIMF/NOPB Texas Instruments | от 22 ₽ | ||
ADC081S021CIMF/NOPB Texas Instruments | 53 ₽ | ||
ADC081S021CIMF Texas Instruments | 127 ₽ | ||
ADC081S021CIMF/NOPB Texas Instruments | по запросу |
Описание: 8 бит ADC, 1CH, POWERWISE, SOT-23-6
ADC081S021 Single Channel, 50 to 200 ksps, 8-Bit A/D Converter
January 2006
General Description
The ADC081S021 is a low-power, single channel CMOS 8-bit analog-to-digital converter with a high-speed serial interface.
Unlike the conventional practice of specifying performance at a single sample rate only, the ADC081S021 is fully specified over a sample rate range of 50 ksps to 200 ksps. The converter is based upon a successiveapproximation register architecture with an internal trackand-hold circuit. The output serial data is straight binary, and is compatible with several standards, such as SPITM, QSPITM, MICROWIRE, and many common DSP serial interfaces. The ADC081S021 operates with a single supply that can range from +2.7V to +5.25V. Normal power consumption using a +3.6V or +5.25V supply is 1.3 mW and 7.7 mW, respectively. The power-down feature reduces the power consumption to as low as 2.6 µW using a +5.25V supply. Th
- Разрешение: 8 бит
- Input Channel Type: Single Ended
- Data Interface: Serial, SPI
- Supply Voltage Range - Analogue: 2.7 В ... 5.25 В
- Supply Voltage Range - Digital: -0.3 В ... 5.25 В
- Ток потребления: 1.47 мА
- Количество выводов: 6
- Рабочий диапазон температрур: -40°C ... +85°C
- SVHC: No SVHC (15-Dec-2010)
- Количество каналов: 1
- Тип корпуса: SOT-23
- Семейство: 081
- Время преобразования: 5 мкс
- Тип входа: Single Ended
- Linearity Error ADC / DAC +: 0.4 LSB
- Linearity Error ADC / DAC -: 0.4 LSB
- Количество битов: 8
- Частота выборки: 200 kSPS
- Диапазон напряжения питания: 2.7 В ... 5.25 В
- Способ монтажа: SMD
Дополнительные аксессуары:
- BONKOTE - BON102
- Electrolube - SMA10SL
- Roth Elektronik - RE901
