Datasheet SM72240E/NOPB - National Semiconductor Даташит — Даташит
Наименование модели: SM72240E/NOPB
10 предложений от 10 поставщиков IC SUPERVISOR 1 CHANNEL SOT23-5. Supervisor Open Drain or Open Collector 1 Channel SOT-23-5. PMIC - Supervisors | |||
| SM72240E/NOPB Texas Instruments | по запросу | ||
SM72240 SolarMagic 5-Pin Microprocessor Reset Circuits
February 25, 2011
General Description
The SM72240 microprocessor supervisory circuit monitors the power supplies in microprocessor and digital systems.
It provides a reset to the microprocessor during power-up, power-down, brown-out conditions, and manual reset. The SM72240 asserts a reset signal whenever the supply decreases below the factory-programmed reset threshold. Reset will be asserted for at least 100ms even after VCC rises above the reset threshold. The SM72240 has an active-low open-drain RESET output. The SM72240 is suitable for monitoring 5V. With a low supply current of only 6µA, the SM72240 is ideal for use in portable equipment. The SM72240 is available in the 5-pin SOT23 package.
- Threshold Voltage: 4.63 В
- Number of Supervisors / Monitors: 1
- Диапазон напряжения питания: 1 В ... 5.5 В
- Reset Type: Active-Low
- Ток потребления: 8 мкА
- Delay Time: 20 мкс
- Тип корпуса: SOT-23
- Количество выводов: 5
Купить SM72240E/NOPB на РадиоЛоцман.Цены
