Datasheet SM72295E/NOPB - National Semiconductor Даташит — Даташит
National Semiconductor SM72295E/NOPB
Наименование модели: SM72295E/NOPB
IC PHOTO FULL BRIDGE DR SOIC-28. Photovoltaics PMIC 28-SOIC. PMIC - Power Management - Specialized
SM72295E/NOPB
Hi-Tech Circuit Group
SM72295E/NOPB
SM72295E/NOPB
SM72295E/NOPB
data sheetСкачать Data Sheet
SM72295 Photovoltaic Full Bridge Driver
February 25, 2011
General Description
The SM72295 is designed to drive 4 discrete N type MOSFET's in a full bridge configuration.
The drivers provide 3A of peak current for fast efficient switching and integrated high speed bootstrap diodes. Current sensing is provided by 2 transconductance amplifiers with externally programmable gain and filtering to remove ripple current to provide average current information to the control circuit. The current sense amplifiers have buffered outputs available to provide a low impedance interface to an A/D converter if needed. An externally programmable input over voltage comparator is also included to shutdown all outputs. Under voltage lockout with a PGOOD indicator prevents the drivers from operating if VCC is too low.
  • Device Type: MOSFET
  • Module Configuration: Full Bridge
  • Peak Output Current: 3 А
  • Input Delay: 22 нс
  • Output Delay: 26 нс
  • Диапазон напряжения питания: 4.75 В ... 5.25 В
  • Тип корпуса: SOIC
  • Количество выводов: 28
На английском языке: Datasheet SM72295E/NOPB - National Semiconductor
