Datasheet SM72442E/NOPB - National Semiconductor Даташит — Даташит
National Semiconductor SM72442E/NOPB
Наименование модели: SM72442E/NOPB
7 предложений от 7 поставщиков
SolarMagic? Controller, Photovoltaic Solar Panels Voltage Regulator IC 4 Output 28-TSSOP
SM72442E/NOPB
65 ₽
SM72442E/NOPB
SM72442E/NOPB
727GS
SM72442E/NOPB
data sheetСкачать Data Sheet
SM72442 Programmable Maximum Power Point Tracking Controller for Photovoltaic Solar Panels
February 25, 2011
General Description
The SM72442 is a programmable MPPT controller capable of controlling four PWM gate drive signals for a 4-switch buckboost converter.
The SM72442 also features a proprietary algorithm called Panel Mode which allows for the panel to be connected directly to the output of your power optimizer circuit. Along with the SM72295 (Photovoltaic Full Bridge Driver) it creates a solution for an MPPT configured DC-DC converter with efficiencies up to 99.5%. Integrated into the chip is an 8channel, 12 bit A/D converter used to sense input and output voltages and currents, as well as board configuration. Externally programmable values include maximum output voltage and current as well as different settings on slew rate, soft-start and Panel Mode.
  • Диапазон напряжения питания: 4.75 В ... 5.25 В
  • Рабочий диапазон температрур: -40°C ... +105°C
  • Тип корпуса: TSSOP
  • Количество выводов: 28
  • Тактовая частота: 220 кГц
  • Выходной ток: 1 мА
  • Входное напряжение: 5 В
На английском языке: Datasheet SM72442E/NOPB - National Semiconductor
