Datasheet SM72480E/NOPB - National Semiconductor Даташит — Даташит
National Semiconductor SM72480E/NOPB
Наименование модели: SM72480E/NOPB
9 предложений от 6 поставщиков
Датчик температуры, Thermostat ±2.3℃ Push-Pull/Open Drain SMD 6Pin WSON T/R
727GS
SM72480E/NOPB
от 23 ₽
SM72480E/NOPB
75 ₽
SM72480E/NOPB
SM72480E/NOPB
data sheetСкачать Data Sheet
SM72480 SolarMagic 1.6V, LLP-6 Factory Preset Temperature Switch and Temperature Sensor
May 11, 2011
General Description
The SM72480 is a low-voltage, precision, dual-output, lowpower temperature switch and temperature sensor.
The temperature trip point (TTRIP) is set at the factory to be 120°C. Built-in temperature hysteresis (THYST) keeps the output stable in an environment of temperature instability. In normal operation the SM72480 temperature switch outputs assert when the die temperature exceeds TTRIP. The temperature switch outputs will reset when the temperature falls below a temperature equal to (TTRIP - THYST). The OVERTEMP digital output, is active-high with a push-pull structure, while the OVERTEMP digital output, is active-low with an open-drain structure. The analog output, VTEMP, delivers an analog output voltage with Negative Temperature Coefficient -- NTC. Driving the TRIP TEST inp
  • Тип выхода: Open Drain / Push Pull
  • Ток потребления: 8 мкА
  • Диапазон напряжения питания: 1.6 В ... 5.5 В
  • Тип корпуса: LLP
  • Количество выводов: 6
На английском языке: Datasheet SM72480E/NOPB - National Semiconductor
