Datasheet MUN5111DW1T1G - ON Semiconductor Даташит BRT транзистор, 50 В, 10K/10KOHM, SOT-363 — Даташит
Наименование модели: MUN5111DW1T1G
Производитель: ON Semiconductor
Описание: BRT транзистор, 50 В, 10K/10KOHM, SOT-363
MUN5111DW1T1G Series
Preferred Devices
Dual Bias Resistor Transistors
PNP Silicon Surface Mount Transistors with Monolithic Bias Resistor Network
The Bias Resistor Transistor (BRT) contains a single transistor with a monolithic bias network consisting of two resistors; a series base resistor and a base-emitter resistor.
These digital transistors are designed to replace a single device and its external resistor bias network. The BRT eliminates these individual components by integrating them into a single device. In the MUN5111DW1T1G series, two BRT devices are housed in the SOT-363 package which is ideal for low-power surface mount applications where board space is at a premium.
- Полярность транзистора: PNP
- Collector Emitter Voltage V(br)ceo: 50 В
- Рассеиваемая мощность: 187 мВт
- DC Collector Current: -100 мА
- DC Current Gain: 60
- Рабочий диапазон температрур: -55°C ... +150°C
