Datasheet LTC2632ACTS8-LZ12 - Linear Technology Даташит — Даташит
Наименование модели: LTC2632ACTS8-LZ12
32 предложений от 16 поставщиков
IC DAC 12BIT V-OUT TSOT23-8. 12 Bit Digital to Analog Converter 2 TSOT-23-8. Data Acquisition - Digital to Analog Converters (DAC)...
Зенер
Россия и страны ТС
LTC2632ACTS8-LZ12#TRMPBF
от 383 ₽
Эиком
от 915 ₽
Элитан
LTC2632ACTS8-LZ12
922 ₽
МосЧип
Производитель: Linear Technology
data sheetСкачать Data Sheet
FEATURES
n
LTC2632 Dual 12-/10-/8-Bit SPI VOUT DACs with 10ppm/°C Reference DESCRIPTION
The LTC®2632 is a family of dual 12-, 10-, and 8-bit voltageoutput DACs with an integrated, high-accuracy, low-drift reference in an 8-lead TSOT-23 package.
It has rail-to-rail output buffers and is guaranteed monotonic. The LTC2632-L has a full-scale output of 2.5V, and operates from a single 2.7V to 5.5V supply. The LTC2632-H has a full-scale output of 4.096V, and operates from a 4.5V to 5.5V supply. Each DAC can also operate with an external reference, which sets the full-scale output to the external reference voltage. These DACs communicate via a simple SPI/MICROWIRE compatible 3-wire serial interface which operates at clock rates up to 50MHz. The LTC2632 incorporates a power-on reset circuit. Options are available for reset to zero-scale or reset to mid-scale in internal reference mode, or reset to mid-scale in external reference mode after power-up.
L, LT, LTC, LTM, Linear Technology and the
  • Разрешение: 12 бит
  • Input Channel Type: Serial
  • Data Interface: 3-Wire, Serial
  • Supply Voltage Range - Analog: 2.7 В ... 5.5 В
  • Ток потребления: 400 мкА
  • Тип корпуса: TSOT-23
  • Количество выводов: 8
LTC2632ACTS8LZ12, LTC2632ACTS8 LZ12
На английском языке: Datasheet LTC2632ACTS8-LZ12 - Linear Technology
