Datasheet LTC2633ACTS8-LI12 - Linear Technology Даташит — Даташит
Наименование модели: LTC2633ACTS8-LI12
Купить LTC2633ACTS8-LI12 на РадиоЛоцман.Цены — от 134 до 924 ₽23 предложений от 15 поставщиков IC DAC 12BIT V-OUT TSOT23-8. 12 Bit Digital to Analog Converter 2 TSOT-23-8. Data Acquisition - Digital to Analog Converters (DAC)... | |||
| LTC2633ACTS8-LI12#TRPBF Analog Devices | 242 ₽ | ||
| LTC2633ACTS8-LI12#TRPBF Linear Technology | 270 ₽ | ||
| LTC2633ACTS8-LI12#TRPBF Analog Devices | 307 ₽ | ||
| LTC2633ACTS8-LI12#TRMPBF Analog Devices | от 904 ₽ | ||
Производитель: Linear Technology
Features
n
LTC2633 Dual 12-/10-/8-Bit I2C VOUT DACs with 10ppm/°C Reference Description
The LTC®2633 is a family of dual 12-, 10-, and 8-bit voltage-output DACs with an integrated, high accuracy, low drift reference in an 8-lead TSOT-23 package.
It has rail-to-rail output buffers and is guaranteed monotonic. The LTC2633-L has a full-scale output of 2.5V, and operates from a single 2.7V to 5.5V supply. The LTC2633-H has a full-scale output of 4.096V, and operates from a 4.5V to 5.5V supply. Each DAC can also operate with an external reference, which sets the full-scale output to the external reference voltage. These DACs communicate via a 2-wire I2C-compatible serial interface. The LTC2633 operates in both the standard mode (clock rate of 100kHz) and the fast mode (clock rate of 400kHz). The LTC2633 incorporates a power-on reset circuit. Options are available for reset to zero-scale, reset to mid-scale in internal reference mode, reset to mid-scale in external reference mode, or reset
- Разрешение: 12 бит
- Input Channel Type: Serial
- Data Interface: 2-Wire, I2C, Serial
- Supply Voltage Range - Analog: 2.7 В ... 5.5 В
- Ток потребления: 400 мкА
- Тип корпуса: TSOT-23
- Количество выводов: 8
LTC2633ACTS8LI12, LTC2633ACTS8 LI12
