Datasheet MAX813LESA+ - Maxim Даташит ИС, микропроцессор SUPERVISOR, 150 мкА, 5.5 В, 8-SOIC — Даташит
Maxim MAX813LESA+
Наименование модели: MAX813LESA+
75 предложений от 31 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Супервизоры питания
ICdarom.ru
MAX813LESA+T
Maxim
от 28 ₽
MAX813LESA+T
Maxim
39 ₽
MAX813LESA
Maxim
46 ₽
MAX813LESA+T
Maxim
Производитель: Maxim
Описание: ИС, микропроцессор SUPERVISOR, 150 мкА, 5.5 В, 8-SOIC
data sheetСкачать Data Sheet
19-4334; Rev.
8; 3/10
Low-Cost, µP Supervisory Circuits
_______________General Description
The MAX705-MAX708/MAX813L microprocessor (µP) supervisory circuits reduce the complexity and number of components required to monitor power-supply and battery functions in µP systems. These devices significantly improve system reliability and accuracy compared to separate ICs or discrete components. The MAX705/MAX706/MAX813L provide four functions: 1) A reset output during power-up, power-down, and brownout conditions. 2) An independent watchdog output that goes low if the watchdog input has not been toggled within 1.6 seconds. 3) A 1.25V threshold detector for power-fail warning, low-battery detection, or for monitoring a power supply other than +5V. 4) An active-low manual-reset input. The MAX707/MAX708 are the same as the MAX705/ MAX706, except an active-high reset is substituted for the watchdog timer. The MAX813L is the same as the MAX705, except RESET is provided instead of RESET. Two supp
  • Threshold Voltage: 4.65 В
  • Number of Supervisors / Monitors: 1
  • Диапазон напряжения питания: 1.2 В ... 5.5 В
  • Reset Type: Active-High
  • Ток потребления: 150 мкА
  • Delay Time: 200 мс
  • Тип корпуса: SOIC
На английском языке: Datasheet MAX813LESA+ - Maxim IC, MPU SUPERVISOR, 150 µA, 5.5 V, 8-SOIC
