Datasheet STK392-110 - NTE Electronics Даташит MODULE — Даташит
Наименование модели: STK392-110
Купить STK392-110 на РадиоЛоцман.Цены — от 102 до 4 042 ₽18 предложений от 16 поставщиков Гибридная схема на безкорпусных транзисторах с лазерной подгонкой сопротивлений.Используется для изготовления усилителей мощности. | |||
| STK392-110 Sanyo | 102 ₽ | ||
| Транзистор биполярный STK392-110 orig Sanyo | 544 ₽ | ||
| STK392-110 | 4 042 ₽ | ||
| STK392-110E ON Semiconductor | по запросу | ||
Производитель: NTE Electronics
Описание: MODULE
NTE7178 thru NTE7181 Integrated Circuit Module-3 Channel Convergence Correction Circuit for Video Projection Televisions
Description: The NTE7178 thru NTE7181 are convergence correction circuits designed for use in video projectors.
These devices incorporate three output amplifiers in a single package, making possible the construction of CRT horizontal and vertical convergence correction output circuits for each of the RGB colors using just two hybrid ICs. The NTE7178 is available in an 18-Lead SIP package while the NTE7179 thru NTE7181 is packaged in a 22-Lead SIP. Features: D 3 Output Amplifier Circuits in a Single Package D High Maximum Supply Voltage D Low Thermal Resistance D High Temperature Stability (TC max = +125°C) D Seperate Predriver and Output Stage Supplies D Output Stage Supply Switching for High-Performance Designs D Low Inrush Current when Power is Applied Applications: D Video Projectors (Both Standard and High Definition) Absolute Maximum Ratings: (TA = +25°C unless
STK392110, STK392 110
