Datasheet USB-SMBUS-CABLEZ - Analog Devices Даташит — Даташит
Наименование модели: USB-SMBUS-CABLEZ
5 предложений от 5 поставщиков
Набор разработчика, 3Pin USB SMBUS CABLE(ROHS)
USB-SMBUS-CABLEZ
4 826 ₽
USB-SMBUS-CABLEZ
USB-SMBUS-CABLEZ
USB-SMBUS-CABLEZ
Производитель: Analog Devices
data sheetСкачать Data Sheet
USB-to-I2C Interface Dongles USB-SMBUS-CABLEZ, USB-5PSMBUS-CABLEZ
GENERAL DESCRIPTION
This data sheet provides details of the USB-to-I2C® interface dongles.
The USB-SMBUS-CABLEZ is a 3-pin version designed for use with the ADM1062/ADM1063/ADM1064/ADM1065/ ADM1066/ADM1067/ADM1068/ADM1069 (hereafter referred to as ADM1062 to ADM1069) family of programmable super sequencers. The USB-5PSMBUS-CABLEZ is a 5-pin version for use with the ADM1175/ADM1176/ADM1177/ADM1178 family of hot swap controllers and ADM1191x power monitoring devices. The dongles are designed to connect a standard PC or notebook USB port to a 3-pin or 5-pin header on an evaluation board, system board, or preprogramming module. The dongles can
SCL SDA GND 3-PIN HEADER ON ADM1062 TO ADM1069 EVALUATION BOARD SCL SDA GND 3-TERMINAL CRIMP HOUSING USB-SMBUS-CABLEZ
then be used to access and program a supported I2C device using the appropriate PC software. Note that a suitable power supply must also be provided to the device. Bot
  • Accessory Type: USB SMBUS Cable
  • For Use With: ADM1062 ... ADM1069 Family of Programmable Super Sequencers
  • Основные особенности: Can Used ... Access & Program А Supported I2C Device Using the Appropriate PC Software
  • Pb-Free: Yes
USBSMBUSCABLEZ, USB SMBUS CABLEZ
На английском языке: Datasheet USB-SMBUS-CABLEZ - Analog Devices
