Линейка продуктов KEEN SIDE
Datasheet Texas Instruments BQ76PL536TPAPRQ1 — Даташит
СерияBQ76PL536-Q1
МодельBQ76PL536TPAPRQ1
Стекируемый сотовый монитор с защитой от перенапряжения и балансировкой 64-HTQFP от -40 до 105
Lithium-Ion Battery Monitor and Secondary Protection IC for EV and HEV Apps datasheet
PDF, 1.3 Мб, Файл опубликован: 2 май 2011
Pin64
Package TypePAP
Industry STD TermHTQFP
JEDEC CodeS-PQFP-G
Package QTY1000
Маркировка76PL536Q1
Width (мм)10
Length (мм)10
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Рекомендуемая замена
ReplacementBQ76PL536ATPAPRQ1
Replacement CodeQ
  • Evaluation Modules & Boards: BQ76PL536PGM-1
    Programming Board for BQ76PL536A/BQ76PL536A-Q1 Lithium-Ion Battery Monitor and Secondary Protection
  • Improving Communications With the bq76PL536
    PDF, 158 Кб, Файл опубликован: 11 авг 2010
    The bq76PL536 is designed to communicate at high speed in noisy conditions present in automotive and industrial large-format battery applications. This document presents specific steps to maximize the integrity of communications with the bq76PL536 and reduce susceptibility to noise to a minimum, thereby reducing the bit-error rate to an acceptable level.
  • bq76PL536/536A/536AQ1 Communication Basics (Rev. B)
    PDF, 71 Кб, Версия: B, Файл опубликован: 5 июл 2011
    This application report discusses the communication basics of addressing, reading, and writing for the Texas Instruments bq76PL536, a stackable 3-to-6 series battery pack protector and analog front end.
  • Multi-Cell Li-Ion Battery Management System Using MSP430F5529 and bq76PL536
    PDF, 118 Кб, Файл опубликован: 16 дек 2010
    This application report explains the implementation of a multi-cell lithium-ion battery management system using an MSP430(tm) microcontroller and the bq76PL536. The battery manager is implemented using the standard evaluation boards for the MSP430 MCU and the bq76PL536.The bq76PL536 can be stacked vertically to monitor up to 192 cells without additional isolation components between ICs. A high-s
Серия: BQ76PL536-Q1 (2)
  • Semiconductors > Power Management > Battery Management Products > Battery Monitor, Protection & Authentication Solutions
На английском языке: Datasheet Texas Instruments BQ76PL536TPAPRQ1
