Datasheet Texas Instruments OPA2188AIDGKT — Даташит
Серия | OPA2188 |
Модель | OPA2188AIDGKT |
0.03ВµV/В°C, 6ВµV Vos, Low Noise, Rail-to-Rail Output, 36V Zero-Drift Operational Amplifier 8-VSSOP -40 to 105
OPA2188 0.03-ОјV/В°C Drift, Low-Noise, Rail-to-Rail Output, 36-V, Zero-Drift Operational Amplifiers datasheet
PDF, 1.3 Мб, Версия: C, Файл опубликован: 16 май 2016
![]() 38 предложений от 17 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS OPA2188AIDGKT Operational Amplifier, Dual, 2 Amplifier, 2MHz, 0.8V/µs, ± 2V to ± 18V, MSOP, 8Pins | |||
OPA2188AIDGKT Texas Instruments | 120 ₽ | ||
OPA2188AIDGKT Texas Instruments | 153 ₽ | ||
OPA2188AIDGKT Texas Instruments | от 459 ₽ | ||
OPA2188AIDGKT Texas Instruments | 764 ₽ |
Pin | 8 |
Package Type | DGK |
Industry STD Term | VSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | 2188 |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .97 |
Pitch (мм) | .65 |
Max Height (мм) | 1.07 |
Mechanical Data | Скачать |
Additional Features | EMI Hardened,Zero Drift |
Архитектура | CMOS |
CMRR(Min) | 106 дБ |
CMRR(Typ) | 114 дБ |
GBW(Typ) | 2 МГц |
Input Bias Current(Max) | 850 pA |
Iq per channel(Max) | 0.44 мА |
Iq per channel(Typ) | 0.385 мА |
Количество каналов | 2 |
Offset Drift(Typ) | 0.03 uV/C |
Рабочий диапазон температур | от -40 до 105 C |
Output Current(Typ) | 18 мА |
Package Group | VSSOP |
Package Size: mm2:W x L | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG |
Rail-to-Rail | In to V-,Out |
Rating | Catalog |
Slew Rate(Typ) | 0.8 V/us |
Total Supply Voltage(Max) | 36 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 4 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 8.8 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 0.025 мВ |
- Evaluation Modules & Boards: OPAMPEVM
Universal Operational Amplifier Evaluation Module
- DC Controlled Low Pass FilterPDF, 410 Кб, Файл опубликован: 9 мар 2017
This application report describes a dc controlled low-pass filter circuit using LM3046. The cut off frequency can be varied by varying the capacitance of the low-pass filter. - EMI Rejection Ratio of Operational Amplifiers (With OPA333 and OPA333-Q1 as an E (Rev. A)PDF, 372 Кб, Версия: A, Файл опубликован: 1 июл 2015
This application report introduces the concept of electromagnetic interference rejection ratio (EMIRR IN+) as a measure of the immunity of an operational amplifier to responding to electromagnetic interference (EMI). Texas Instruments has developed the ability to accurately measure and quantify the immunity of an operational amplifier over a broad frequency spectrum extending from 10 MHz to 6 GHz. - Analog linearization of resistance temperature detectorsPDF, 152 Кб, Файл опубликован: 9 ноя 2011
- 4Q 2011 Issue Analog Applications JournalPDF, 943 Кб, Файл опубликован: 9 ноя 2011
- Offset Correction Methods: Laser Trim, e-Trim, and Chopper (Rev. A)PDF, 795 Кб, Версия: A, Файл опубликован: 20 июл 2017
- Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2188 (4)
- OPA2188AID OPA2188AIDGKR OPA2188AIDGKT OPA2188AIDR
