Datasheet RH4B-ULCAC120V - IDEC Даташит Мощное реле, 4PDT, 120 VAC, 10 А, установка в розетку — Даташит
Наименование модели: RH4B-ULCAC120V
Производитель: IDEC
Описание: Мощное реле, 4PDT, 120 VAC, 10 А, установка в розетку
RH Series RH Series -- General Purpose Midget Relays
Key features of the RH series include: · Compact midget size saves space · High switching capacity (10A) · Choice of blade or PCB style terminals · Relay options include indicator light, check button, and top mounting bracket · DIN rail, surface, panel, and PCB type sockets available for a wide range of mounting applications Contact Material Contact Resistance Minimum Applicable Load Operating Time
Silver cadmium oxide 50m maximum (initial value) 24V DC/30mA, 5V DC/100mA (reference value) SPDT (RH1), DPDT (RH2): 20ms maximum 3PDT (RH3), 4PDT (RH4): 25ms maximum SPDT (RH1), DPDT (RH2): 20ms maximum 3PDT (RH3), 4PDT (RH4): 25ms maximum 110% of the rated voltage
Relays
E
- Тип реле: Miniature
- Coil Voltage VAC Nom: 120 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 220 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 7.36 кОм
- Конфигурация контактов: 4PDT
Дополнительные аксессуары:
- IDEC - SH4B-05C
RH4BULCAC120V, RH4B ULCAC120V
