Datasheet MC25140 - Multicomp Даташит Мощное реле SPDT-1NO/1NC 12 В постоянный ток, 16 А, PCB — Даташит
Multicomp MC25140
Наименование модели: MC25140
Реле Мощности, MULTICOMP MC25140 Power Relay, SPDT, 12VDC, 16A, MC25 Series, Through Hole
MC25140
Multicomp
214 ₽
MC25140
Multicomp
214 ₽
Производитель: Multicomp
Описание: Мощное реле SPDT-1NO/1NC 12 В постоянный ток, 16 А, PCB
data sheetСкачать Data Sheet
Relay
Contact Data
Contact form Contact material Contact rating Maximum switching voltage Maximum switching current Maximum switching power Minimum switching load Maximum contact resistance Life Electrical Mechanical General Data Minimum insulation resistance Dielectric strength Operate time Release time Operate temperature Shock Resistance Endurance Misoperation Vibration Resistance Endurance Misoperation Humidity : 10 to 55Hz, 1.5mm double amplitude.
: 10 to 55Hz, 1.5mm double amplitude. : 35% to 95%RH, +40°C. : 1000m/s2. : 100m/s2. : 10,000M 500V dc. : 1000V ac, 1 min between open contacts 5000V ac, 1 min between coil and contacts. : Maximum 10ms. : Maximum 5ms. : -40 to +85°C. : 100,000 operations. 50,000 operations (Resistive: Cos Ш = 0.4, L/R = 7ms). : 20,000,000 operations. : 1 form C. : Ag Alloy. : Resistive: 16A 250V ac/30V dc. Inductive: 8A 250V ac Cos Ш = 0.4. : 380V ac/30V dc. : 16A. : 4000VA, 240W. : 5V dc, 100mA. : 100m (6V dc 1A).
Coil Data Chart
Nominal Voltage V dc 1
  • Тип реле: General Purpose
  • Coil Voltage VDC Nom: 12 В
  • Contact Current Max: 16 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 360 Ом
  • Конфигурация контактов: SPDT
На английском языке: Datasheet MC25140 - Multicomp POWER RELAY SPDT-1NO/1NC 12 V DC, 16 A, PCB
