Datasheet MKS1TIN-10 AC110 - Omron Даташит Реле, SPST-NO, 15 А, 110 VAC, AC LOADS — Даташит
Наименование модели: MKS1TIN-10 AC110
MKS1TIN-10-AC110 Omron | 8 161 ₽ |
Производитель: Omron
Описание: Реле, SPST-NO, 15 А, 110 VAC, AC LOADS
New Product
Power Relays
MK-S(X)
MK-S-series Relays with DC-switching Models That Can Switch 220 VDC, 10 A (Resistive Load).
· Switch a DC load of 220 VDC, 10 A (resistive load).
· Models for AC Loads can switch 250 VAC, 15 A (resistive load). · Lineup includes models with SPST-NO and SPST-NO/SPSTNC contact forms. · Using a SPST-NO/SPST-NC contact form enables detecting contact welding. (When the NO contacts become welded, the NC contacts will maintain a minimum distance of 0.5 mm.) · Models available with operation indicators and built-in test buttons. · RoHS compliant. · Standards: UL, IEC (TЬV certification) (Application for the above standards has been made using the P7MF-06 and P7MF-06-D Sockets (sold separately).)
- Тип реле: Power
- Coil Voltage VAC Nom: 110 В
- Contact Current Max: 15 А
- Coil Resistance: 932 Ом
- Coil Type: AC
- Coil Current: 24.2 А
- Operating Power Nom: 2.7 VA
- Способ монтажа: Plug-In
- Габариты: высота: 44 мм
- Внешняя ширина: 34.5 мм
- External Depth: 34.5 мм
- Конфигурация контактов: SPST-NO
MKS1TIN10 AC110, MKS1TIN 10 AC110
