Datasheet HC2E-H-DC24V-F - Panasonic Даташит Мощное реле, 24 В, 10 А, DPDT, PLUG-IN — Даташит
Наименование модели: HC2E-H-DC24V-F
![]() 7 предложений от 7 поставщиков Реле Мощности, Relays 24VDC 650Ω 7A DPDT(27.2x20.8x35.2)mm Plug-In Signal Relay Automotive | |||
HC2E-H-DC24V-F Panasonic | 1 169 ₽ | ||
HC2E-H-DC24V-F Matsushita | 4 178 ₽ | ||
HC2E-H-DC24V-F Panasonic | по запросу | ||
Производитель: Panasonic
Описание: Мощное реле, 24 В, 10 А, DPDT, PLUG-IN
HC
SEALED CONSTRUCTION High reliability ensured in challenging environments.
HC RELAYS AMBER SEALED TYPE
TYPICAL APPLICATIONS
1.
Where surrounding atmosphere is bad Cotton mills, flour mills, chemical works, traffic signals, etc. 2. In situations where high reliability is required Safety equipment, alarms, copiers, telecommunications devices, computers, etc. About Cd-free contacts We have introduced Cadmium free type products to reduce Environmental Hazardous Substances. (The suffix "F" should be added to the part number. The Suffix "F" is required only for 1 Form C, 2 Form C contact type. The 4 Form C and 4 Form C bifurcated (twin) contact type is originally cadmium-free, the suffix "F" is not required.) Please replace parts containing Cadmium with Cadmium-free products and evaluate them with your actual application before use because the life of a relay depends on the contact material and load.
- Тип реле: General Purpose
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 250 В
- Coil Resistance: 650 Ом
- Конфигурация контактов: DPDT
- Coil Type: DC
- Coil Current: 37 мА
HC2EHDC24VF, HC2E H DC24V F
